belugawhaleman Posted May 11, 2023 Posted May 11, 2023 Nice work! That kit intrests me....I think it's now on my list.
Irishman1 Posted May 11, 2023 Author Posted May 11, 2023 10 hours ago, belugawhaleman said: Nice work! That kit intrests me....I think it's now on my list. It’s been the best fitting airfix kit I’ve built yet. Including the P-51,FW-190,BF-109,Mosquito,Hurricane,Ju-87, Hellcat.. it kinda seems simple in a detailed way. I really like this build, can’t wait to paint it. Next up is the 1/24 Typhoon!! 1
Irishman1 Posted May 12, 2023 Author Posted May 12, 2023 Well I was happy to replace the very little detailed spinner with one I have from model monkey but…. It’s a three prop spinner🥲. got the props sanded down and ready for paint and got the exhaust pipes finished and installed , I was hard to keep the weld lines on the exhaust stacks without sanding them off but I think enough is still there. 2
Irishman1 Posted May 19, 2023 Author Posted May 19, 2023 Starting to paint. Trying different ways to get a soft edge. Trying the putty method after I paint the dark green. On my airfix 1/24 fe-190 I used paper cut to the cami shape then roll taped it so it was lifted off the surface, then held the airbrush at 90 degrees to the surface, like it should be with the putty. I also started to detail the engine with hoses and cables 4
Irishman1 Posted May 22, 2023 Author Posted May 22, 2023 Top colors sprayed on today. Hit the bottom color tomorrow. Not sure if I’ll paint the markings or use the decals on this one…. 5 1
Irishman1 Posted May 22, 2023 Author Posted May 22, 2023 Installed the top decals to see if I like them or I’m going to spray all the markings on. Not sure yet…made a canopy lock mechanism for the top of the sliding glass 5 1
Irishman1 Posted May 24, 2023 Author Posted May 24, 2023 Well I’m going to remove the decals and paint the markings. Just don’t like the look of the different finishes between the paint and decals. I’ve always used decals on almost all of my other 1/24 builds but I’ve got the 1 man army stencils so this will be hood practice for the typhoon. The hellcat was my first model that I painted all the markings on and I’m happy with that one. The main problem is finding the correct color for the reddish roundel, I tried RAF hill red and it was not even close. I use water based paints to spray, mainly Vallejo 4
Irishman1 Posted May 25, 2023 Author Posted May 25, 2023 Trying different methods for the red locking mechanism on the outside of the canopy. The smallest rod I had was way to big so I tried stretched sprue and I think it’s a good diameter. Now I just need to clean up the painting and the canopy 3
Irishman1 Posted May 25, 2023 Author Posted May 25, 2023 1 minute ago, Irishman1 said: Trying different methods for the red locking mechanism on the outside of the canopy. The smallest rod I had was way to big so I tried stretched sprue and I think it’s a good diameter. Now I just need to clean up the painting and the canopy
Irishman1 Posted May 26, 2023 Author Posted May 26, 2023 Just a few more details. I decided to just use the decals from the kit instead of the 1 man army stencils. I’ll save them for the typhoon. I also need to rig the antenna and the IFF wire, paint the rear fuselage strip, get the squad letters on. then weather it and call it done. Here’s a few pictures from today 4
Irishman1 Posted May 26, 2023 Author Posted May 26, 2023 Also got the door on the correct way too!! 1
Irishman1 Posted May 28, 2023 Author Posted May 28, 2023 Almost there!!! Got the squadron and plane lettering masked and painted along with the rear stripe. Ran out of paint as I was just finishing the stripe… a antenna and FFL wire, a few more decals where the painted items were and I’m done 5
HubertB Posted May 28, 2023 Posted May 28, 2023 Good-looking Spit 👍 ! (Dare I say that the infamous crow-bar was pained red only after the war ?) Hubert 2
Irishman1 Posted May 30, 2023 Author Posted May 30, 2023 Painted the yellow guard stripes on the wings., re-doped the barrel ends. Now on to the 1/24 Typhoon!!! 4 1
KevinM Posted May 30, 2023 Posted May 30, 2023 She came out looking Great and you blew right through that one! 1
Irishman1 Posted May 30, 2023 Author Posted May 30, 2023 On 5/28/2023 at 4:27 AM, HubertB said: Good-looking Spit 👍 ! (Dare I say that the infamous crow-bar was pained red only after the war ?) Hubert I’ve heard that a couple times now, I guess I’ve only seen color pictures of restored aircraft with the red crowbar. It makes sense that the ww2 crowbars would be Soler or bare steel color. I’ll repaint it !!! 1
Irishman1 Posted May 31, 2023 Author Posted May 31, 2023 Drilled several 1mm by 1mm holes in the cowling covers and engine framework, then installed magnets to hold them on when I don’t want to have engine visible.e 3 1
