HobbyBoss T-34/85 | No. 82602 | 1:16
T-34 had 3 different settings, normal surface, one for hard surface and last one for mud and loose surface. This was done by moving the idler wheel up and down.
image.jpeg.e91c9de909fa6d60da53fd48b1755ac9.jpeg1. Body of wheel
2. Rubberized tyre
3. Crank
4. Toothed ring
5. Bracket
6. Worm wheel
7. Worm
8. Flange
9. Nut
10. Stop bolt
11. Casing of track adjuster
12. Roller bearing
13. Ball bearing
14. Spacer bush
15. Armoured cap
16. Armoured plug
17. Cover with gland
18. Castellated nut
19. Adjusting packing
20. Ring
Also the T-34 had floating trucks,  where the pins were not secured in the links and as the tracks move they are passing a point on the hull that presses the loose pins back in.
Check out the loose pins.  Simple, smart and effective
2. Rubberized tyre
3. Crank
4. Toothed ring
5. Bracket
6. Worm wheel
7. Worm
8. Flange
9. Nut
10. Stop bolt
12. Roller bearing
13. Ball bearing
14. Spacer bush
15. Armoured cap
16. Armoured plug
18. Castellated nut
20. Ring
Ok. Good to know. Thank you for this info.👍
Simple indeed. Also easy to remove because pins are never stuck.
I bet the pins striking that plate contributes to a lot of the track noise on the ones I've heard in person. There is definitely a load "clacking" sound noticeable - that's probably what I'm hearing.
Looks really good. Personally being also an avid game player I use WarThunder for images and ideas of things like how stuff should look. The tanks are modeled really well and you can preview anything in any nation so gives a good 3D model you can look at. Might be helpful might not.
Some stowage added:
-Log taken from trumpeter T-72 kit.
-Metal assault rifle SVT40 in 1/16 from https://www.rctank.de/Metal-assault-rifle-SVT40-in-1-16-unpainted
-SOL - 1/16 water canister, 20l from https://www.rctank.de/SOL-1-16-water-canister-20l
-Metal MP 717 / PPSh 41 with magazine, 2 pcs in 1/16 from https://www.rctank.de/Metal-MP-717-PPSh-41-with-magazine-2-pcs-in-1-16-unpainted
This is wehrmacht item but perhaps soviets have stolen it in campaign 😉
SVT40 too big to fit well inside and thus left outside🧐
PPSh 41 is fine but perhaps not using it. Because it wouldn't make sense to leave this outside. 🧐
I will save this my trumpeter SU-100 build which has interior.
A very nice build with lots of attention to detail, which somehow skipped my attention until now. I would have imagined better detail on a kit in this scale, but on the other hand, it´s a pleasure to follow your modifications and detailing.
