Spent a few evenings getting the nose guns to fit and sit properly. Also took some elbow grease to get a clean fit of the windshield. Getting close to paint!
A bit further with the engine and oil tank.
Took more measurements from the model and moved a few bearers around for a better fit.
Still figuring out. how the oil tank was attached to the firewall?
The oil tank annoyed the crap out of me after taking a good look at these.
The oil tank should extend more forward. And the shape is more flattened, with a negative sloping front.
Meaning a downward slope to the front?If so hard to see from here almost looks like a + front to back pitch to me though ever so slight tops 3/5' which would make sense for flow to the engine.A car engine is done the same also to allow oil drain back holes that flow through the cylinder head through the block back to the oil pan for the pump to pick up.:hsmack:getting a little winded.
I see what your reference the very front facing the engine got it.
Spent the afternoon fiddling with Chitubox, Lychee and Photon Workshop. The latter worked best with my M7 Pro printer. Printed the exhausts and spinners.
Note: there are four different exhausts on this plane. The inner exhausts are different from the outer. I have spent so many hours tweaking on the engine 3d model that i decided to push forward, or this will never get finished!
Isolated the engine bearers and did some final research. Will print a set of 3 because I'm expecting some print flaws.
Prints turned out great.
Next print will be the engines themselves. The first ones were printed on a 4K printer as a test.
Jeroen, I don't remember if I've asked, what resin are you using? Basic Anycubic resin or something else?
Thanks
Printed the engines over. Some tubes that were actually hollow in my model were too fragile. Even ingnitions wires and spark plugs came through on the print. The detail is amazing. The engine bearers in grey resin aRe too brittle for my taste. Printing them now in a different resin flavour.
Pfffff. Reprinted the engines, exhausts and engines in beige resin. It’s a bit more flexibele so less likely to break or chip.
The small wiring on the engines are all intact and getting the supports off is a challenge. The oil tank and support ls fit great but that’s logical since it all fits in my 3d program. Geez. Getting there. The last pic is a pile of testshots.
This weekend i’ll hope to have all the parts cleaned up and smoothed out. Getting nearer to paint!
To make life more difficult I want to build this Norton 16H in 1939 RAF blue alongside to pose with the Whirlwind.
The extreme detail I am apparently managing to squeeze from this printer makes me confident.
I do however have to modify this 3D model extensively to get it to print, build and paint properly.
2 hours ago, JeroenPeters said:
Good grief, the wiring detail is ridiculous. Just shows what can be achieved now with these printers
First paint is on. This reveals more detail And some print layers, but all acceptable. Even the Rolls Royce lettering appears.
Decided to paint one block in the later all black colour and the other in the earlier half metal. Like the Kestrel engine.
Makes it a bit more interesting to look at.
