BlrwestSiR Posted January 26, 2024 Posted January 26, 2024 Ok, I'm in with something unexpected but from the stash. Box contents: Just kidding, The AM in the mix. 9
Martinnfb Posted January 26, 2024 Posted January 26, 2024 Amazing I am thinking Schwalbe as well, but I am probably further in then 25% 2 1
BlrwestSiR Posted January 26, 2024 Author Posted January 26, 2024 And we're off! First thing was to sand/remove the surface detail in preparation for the Red Fox 3D panels. Then I started gluing the cockpit panels together. The fit is not perfect. Lots of dry fitting was needed to get it together. It's definitely a different way to build a cockpit. 8
Martinnfb Posted January 26, 2024 Posted January 26, 2024 Nice , very inspiring, considering the considerable amount of 262s in my stash 3
BlrwestSiR Posted January 26, 2024 Author Posted January 26, 2024 34 minutes ago, Martinnfb said: Nice , very inspiring, considering the considerable amount of 262s in my stash I've never finished a 262. Came close with the Tamiya 1/48 kit when it was first released. So I'm hoping I can finally crops this off the list. 4
PanzerWomble Posted January 26, 2024 Posted January 26, 2024 Interesting one , can't remember seeing one of these built for a long time . 5
BlrwestSiR Posted January 27, 2024 Author Posted January 27, 2024 Some of these sprue connection points are a bit huge. I ended up using a razor saw to cut these off. I've started work on the engines to and have been building up some subassemblies. 4
BlrwestSiR Posted January 27, 2024 Author Posted January 27, 2024 Last thing I did last night was start on the paint. A quick test fit of some of the cockpit parts show they go together. I may have to do some remedial paint work on the onion. The Xtreme Metal jet exhaust didn't come out the way I expected. 8
Martinnfb Posted January 28, 2024 Posted January 28, 2024 I like the metal effect , looks convincing. 1 1
ScottsGT Posted January 29, 2024 Posted January 29, 2024 Love the subject. I built that kit when I was an about 13. Always wanted another to do it right. 5
BlrwestSiR Posted January 29, 2024 Author Posted January 29, 2024 17 hours ago, ScottsGT said: Love the subject. I built that kit when I was an about 13. Always wanted another to do it right. That's the old kit. This one is from 2016 or that's what the copyright says on the inside of the wing. 4
BlrwestSiR Posted January 29, 2024 Author Posted January 29, 2024 Speaking of wings, I got the main gear bay assembled and glued in. I forgot to take pics until it was fitted to the wing. Slight tweaking was needed. The engines are together as well. I've left off most of the detail bits since I'm going to have the nacelles closed up. 9
ScottsGT Posted January 29, 2024 Posted January 29, 2024 2 hours ago, BlrwestSiR said: That's the old kit. This one is from 2016 or that's what the copyright says on the inside of the wing. Yea, very old! Were talking 48 years ago. 😳 4 1
biggtim Posted January 29, 2024 Posted January 29, 2024 Certainly makes me seem old at 55 then, doesn't it? 2 3
BlrwestSiR Posted January 30, 2024 Author Posted January 30, 2024 15 hours ago, biggtim said: Certainly makes me seem old at 55 then, doesn't it? Well I'm 52 so not far behind you. 4
biggtim Posted January 30, 2024 Posted January 30, 2024 2 hours ago, BlrwestSiR said: Well I'm 52 so not far behind you. Naw, we're still young'uns compared to most of the other codgers that frequent this place! 1 6
PanzerWomble Posted January 30, 2024 Posted January 30, 2024 Inspo from Hendon , thought I had more sadly 3 1
Administrators Clunkmeister Posted January 31, 2024 Administrators Posted January 31, 2024 On 1/26/2024 at 11:46 PM, BlrwestSiR said: Some of these sprue connection points are a bit huge. THAT has to be the Group Build understatement of the 21st Century so far. Caught me absolutely flat footed, Carl. So much so that I laughed like a drooling fool for an hour. And for that reason, LSM is sending you a ZM 190A-4 to go with your 109G. Nothing like unexpected comedy at the end of a dreary day. Inbound from Sprue Brothers. 6 1
Administrators Clunkmeister Posted January 31, 2024 Administrators Posted January 31, 2024 Good old Bob Uecker. Long time Brewers radio announcer. AKA Harry Doyle in the movie. 2
Administrators Clunkmeister Posted January 31, 2024 Administrators Posted January 31, 2024 4 minutes ago, Clunkmeister said: Good old Bob Uecker. Long time Brewers radio announcer. AKA Harry Doyle in the movie. 2
dodgem37 Posted January 31, 2024 Posted January 31, 2024 Inspo from Hendon , thought I had more sadly More: https://www.ipmsstockholm.se/home/messerschmitt-me-262b-in-detail/ Sincerely, Mark 2 2
BlrwestSiR Posted January 31, 2024 Author Posted January 31, 2024 9 hours ago, Clunkmeister said: THAT has to be the Group Build understatement of the 21st Century so far. Caught me absolutely flat footed, Carl. So much so that I laughed like a drooling fool for an hour. And for that reason, LSM is sending you a ZM 190A-4 to go with your 109G. Nothing like unexpected comedy at the end of a dreary day. Inbound from Sprue Brothers. Wow, Ernie. Thanks! I'm glad I was able to make you laugh. I've never built a 190 before so thanks for giving me a shot at one. 2
BlrwestSiR Posted February 1, 2024 Author Posted February 1, 2024 Progress on the cockpit. First up was the Red Fox 3D decals. The IP dials have a nice gloss finish to them. Very much like they're under glass. Then it was time to add the sides. Having done some dry fitting, I knew there would be some issues due to warping. The problem is the assembly is too flimsy to clamp it. So I used masking tape instead. Turns out I needed different strips going in different directions to get the warp out. It looks like a mummy or something. 4
