ScottsGT Posted June 8, 2024 Author Posted June 8, 2024 You left out “curse”. Multiple times. Over and over. I whine a lot, but I’m still having fun. I did forget how time consuming these resin projects can be. Off to the next rudder now and then I might start adding some legs to it. 4
Peterpools Posted June 8, 2024 Posted June 8, 2024 Scot Nice progress on the rudders and completely agree all should have been one solid piece. 3
ScottsGT Posted June 9, 2024 Author Posted June 9, 2024 They’re just sitting in place. I’ll glue them in when I have a fresh start tomorrow sometime. 5
BlrwestSiR Posted June 9, 2024 Posted June 9, 2024 That gear looks a lot more solid than what I've got on the Kai Eagle. 2
ScottsGT Posted June 9, 2024 Author Posted June 9, 2024 The mains are G-Factor. (I’m sure you knew this because it was your kit at one time 🤣) Front is resin and I’m assuming Paul made it with an internal wire like he did on the Cougars gear. 5
ScottsGT Posted June 12, 2024 Author Posted June 12, 2024 Slow progress. Well, it is summertime and too many distractions. House guests, floating in the lake and filtering beer through my body, taking the boat out… Elevators, flaparons or elevons or whatever they are called. Wiggly things on the back of the wing are up next. Then I’ll do the slidy things on the front of the wings. 5
ScottsGT Posted June 12, 2024 Author Posted June 12, 2024 Found a little “Oopsie!” Paul made. The wing extension at the tail on each side was about 3/16” too short. Had to glue up some Evergreen stock and CA it in place and then shape it. 7
HubertB Posted June 13, 2024 Posted June 13, 2024 One comment about another « oopsie » (from you this time, I am afraid) : the front LG shaft is not perpendicular to the fuselage line, but to the ground … Hubert 3
ScottsGT Posted June 13, 2024 Author Posted June 13, 2024 3 hours ago, HubertB said: One comment about another « oopsie » (from you this time, I am afraid) : the front LG shaft is not perpendicular to the fuselage line, but to the ground … Hubert Dadgummit! You are so right! I was confused or in a hurry when I glued this all together and I even questioned myself because it didn’t make sense. But here it is, right in the instructions…..”This leg sits vertical to the ground, while the airframe sits at a high angle of attack.” I probably got confused where it said the mains are “hanging at 90 degrees to the plane of the wing.” Thanks Hubert. I really appreciate you catching my eff-up. Even more appreciated that you pointed it out to me! Now off to try and get this epoxied in leg to move…. 5 1 1
ScottsGT Posted June 13, 2024 Author Posted June 13, 2024 Popped right out with a little wiggle added in. Cleaned up the cured epoxy and now on to plan B. Build out the gear with wheels and tires and everything painted then set the nose gear. 6
BlrwestSiR Posted June 13, 2024 Posted June 13, 2024 (edited) Wow, it's coming together. Good thing with the nose gear that you were able to fix it. Edited June 15, 2024 by BlrwestSiR Fix typo 4
Peterpools Posted June 13, 2024 Posted June 13, 2024 Scott So glad Hubert helped point out the nose gear problem and you were able to take action. Nice going for sure. 4
Martinnfb Posted June 13, 2024 Posted June 13, 2024 Catching up with your exceptional work Scott, great and fast progress. 3 1
ScottsGT Posted June 14, 2024 Author Posted June 14, 2024 Hey Hubert, any better? I did have an issue with the nose leg having a twist to it. Wheels were slightly cocked to the right. I had to modify the top of it and the pocket it sits in to get it pointing straight. 5
BlrwestSiR Posted June 15, 2024 Posted June 15, 2024 5 hours ago, ScottsGT said: Looking at the pic of the Cutlass in primer, it almost looks like it's done in TPS camo. Which would be kinda cool/interesting. 3
Peterpools Posted June 15, 2024 Posted June 15, 2024 Scott Nice fix and the Cutlass is looking mighty good, now that she is up on her legs. 3
ScottsGT Posted June 15, 2024 Author Posted June 15, 2024 Funny thing is, it almost needs nose weight. Fingers crossed the flappy things on the wing don’t lift the front wheels when I glue them on. 3
ScottsGT Posted June 16, 2024 Author Posted June 16, 2024 Flappy/wiggly things installed! Starting to look like it’s LEX time! 6
ScottsGT Posted June 16, 2024 Author Posted June 16, 2024 She’s definitely tail heavy. Still sitting on the nose, but the tiniest bit of pressure and its nose up. If I need to I can hide a little lead in the canopy fairing that slides back. 5
belugawhaleman Posted June 16, 2024 Posted June 16, 2024 Looking good! The Cutlass was surely one odd bird! 2
Peterpools Posted June 17, 2024 Posted June 17, 2024 Scott Looking mighty good as you're taming the Cutlass for sure. Any chance of finding a way to add a bit more weight to the nose are to help prevent her from falling back to being a tail sitter? 🤞
ScottsGT Posted June 17, 2024 Author Posted June 17, 2024 Hey Peter, I mentioned above I could hide some in the canopy fairing if it needs it. Maybe a little under the pilots seat too. Honestly though, I still have to add the LE flaps/extensions, canopy and fairing, pilots seat and gear doors. Out back I just need to add the exhausts. It should be okay. 1
