Administrators JeroenPeters Posted October 29, 2024 Author Administrators Posted October 29, 2024 Starting to look like a pit 7 1
PanzerWomble Posted October 29, 2024 Posted October 29, 2024 Wow Jeroen , thats damn fine even by your high standards ! 6
Martinnfb Posted October 30, 2024 Posted October 30, 2024 Not sure about the yellow release handle, I would go with red. Yellow is dedicated to fuel lines, but I can be mistaken. here is an useful linkie . 1
Administrators JeroenPeters Posted October 30, 2024 Author Administrators Posted October 30, 2024 On 10/30/2024 at 1:58 AM, Martinnfb said: Not sure about the yellow release handle, I would go with red. Yellow is dedicated to fuel lines, but I can be mistaken. here is an useful linkie . Expand You are correct! But the release handle is still on my PE fret. I will install it after fitting the pit, since it will be easily knocked off. The handle you see is red as well, but looks yellow since you see it from the top in the pic and shines metal. I’ll add some extra red to that as well. Cheers! 3
FullArmor Posted October 30, 2024 Posted October 30, 2024 On 10/30/2024 at 5:38 AM, JeroenPeters said: You are correct! But the release handle is still on my PE fret. I will install it after fitting the pit, since it will be easily knocked off. The handle you see is red as well, but looks yellow since you see it from the top in the pic and shines metal. I’ll add some extra red to that as well. Cheers! Expand Super tiny parts😬. Be carefull not to lose them 2
Administrators JeroenPeters Posted October 30, 2024 Author Administrators Posted October 30, 2024 More work on the pit. Seatbelts done, wrinkled and weathered with pigments. More levers installed. Getting there. 10
Administrators JeroenPeters Posted October 31, 2024 Author Administrators Posted October 31, 2024 Really was not liking the KG13C control stick Aires provides. Downloaded a decent file for the handle and drew the rest myself. Jist picked them out of the printer and they are curing right now. Picture below is the resin Aires version i abandoned. 5
Administrators JeroenPeters Posted October 31, 2024 Author Administrators Posted October 31, 2024 Better. 6
Administrators JeroenPeters Posted November 1, 2024 Author Administrators Posted November 1, 2024 Hard to capture in a decent photo, but all the detail is there 7
GusMac Posted November 1, 2024 Posted November 1, 2024 Looks good, definitely more substantial than the Aires one. It looks like it's been on a diet. 4
Administrators JeroenPeters Posted November 5, 2024 Author Administrators Posted November 5, 2024 Stick installed. Wheelbay painted in aircraft aluminum from Alclad2. 6
Administrators JeroenPeters Posted November 6, 2024 Author Administrators Posted November 6, 2024 So… not being happy with the resin MDC transparent parts, i 3D printed a mold for the upper canopy. I bought Evergreen transparent sheets in 0.2 and 0.4 mm. I’ll heat up a piece and pull it over my mold. 7
Administrators JeroenPeters Posted November 6, 2024 Author Administrators Posted November 6, 2024 Painting and fitting the Aires parts. Shite fit. Probably due to shrinkage and it being… well.. Aires. Also remade the sanded away detail in the MDC interior. Almost fits. Almost. 8 1
Administrators JeroenPeters Posted November 7, 2024 Author Administrators Posted November 7, 2024 Mind the gap! This whole set is A JOKE. Every single part needs to be seriously altered or completely remade. The rear upper part has serious shrinkage OR the side parts have. Either way: more scratching is needed. 5 2 3
BlrwestSiR Posted November 8, 2024 Posted November 8, 2024 Wow, that part looks like it should be 1/48. Some serious shrinkage for sure. 2
HubertB Posted November 8, 2024 Posted November 8, 2024 Looks more like s#&!!y design than shrinkage at this level 😱 ! Hubert 3 1
Administrators JeroenPeters Posted November 8, 2024 Author Administrators Posted November 8, 2024 Even this pushrod needs to be lengthened 3
GusMac Posted November 8, 2024 Posted November 8, 2024 On 11/8/2024 at 8:47 PM, JeroenPeters said: Even this pushrod needs to be lengthened Expand It's either extremely cold or that's a lot of shrinkage! 1 5
Administrators JeroenPeters Posted November 10, 2024 Author Administrators Posted November 10, 2024 Instructions say nothing about seatbelts for the bombardier, but i gave him some. 9
Administrators JeroenPeters Posted November 14, 2024 Author Administrators Posted November 14, 2024 Vacuform machine arrived. Can’t wait to tey it out 5
FullArmor Posted November 15, 2024 Posted November 15, 2024 On 11/14/2024 at 8:42 PM, JeroenPeters said: Vacuform machine arrived. Can’t wait to tey it out Expand Nice! Please share more pictures when tested. Are you making canopy screen? 2
Administrators JeroenPeters Posted November 15, 2024 Author Administrators Posted November 15, 2024 On 11/15/2024 at 4:37 AM, FullArmor said: Nice! Please share more pictures when tested. Are you making canopy screen? Expand Yes. Indeed. Already made a master for the large hatch on the nose, but will also make the glass nose. The resin on the set is brittle, thick and yellow… I’ll do a first test run this weekend 6
