Last night when I was moving some model kits I accidentally knocked this P-400 off the shelf. A cuss factor for sure! I'll rebuild it at some point. ☹️
  • Sad 6
5 minutes ago, Spitfire said:
Now that is really sad, hope you can rebuild it.
Dennis
Fingers crossed I can make it look "okay". 😐
Wow, nice recovery there John. I guess the clean break at the tail helped. Hope the gear legs aren't as bad as they look.
12 hours ago, CANicoll said:
John,  What tail is that?  did you graft a resin tail on the P-400?  Nice recovery!
That's just the kit tail Chris. Remember, I always add a 3/8" plastic "insert" to get the correct fuselage length. The kit fuselage is a little short. 🙂 (I've done that on ALL my SH P-39/P-400 builds.)
Thanks Carl. I got lucky on the tail as it was a clean break and everything fit back nicely with just a couple of spots needing some filler. I've got the gear sorted out and reattached but had to use some scrap plastic to replace a couple of small missing pieces. I'll post a photo in a bit. I figure I'll have it finished later today. 🙂
1 hour ago, HubertB said:
Great save, John !
Thank you Hubert! Much appreciated. 🙂
1 hour ago, Spitfire said:
Nice one
Dennis
Thanks Dennis! 🙂
Well done!
Thank you Paul. It had it's moments! LOL 🙂
4 hours ago, CANicoll said:
I forgot you did that to the SH P-39's.  Beautiful fix, John.  Wow!
Thanks Chris. It came out okay I think. 🙂
