1/32 P-51 D/K
I am moving this from the Pacific GB just so I can keep on keeping on. As I said earlier, I had cause to drop out of that GB so I can build this for a friend of mine. More on the scheme later.
This is a way better kit than the ZM P-51. I am thoroughly enjoying this build. So far I have the pit done, the side walls done, engine done and the inter cooler/radiator done and then test fit. I monged out and tried to close up a gap behind the pit but after about 30 minutes of squeezing things together and them not fitting did I come to the realization that maybe it was supposed to be like that. Really?
I really like this oil wash technique. I am glad I finally decided to work it.
this pic is quite a bit over exposed and grainy
Here you maybe able to see that I wrinkled the cushion.
thanks for watching.
Nice one! Only seeing this build now.
Can you get the seat belts draped some more?
I assume they're PE?
Love to see more. Great work.
Yes I could but they are the kits stainless and not brass so it may be quite difficult now.
Well quite a bit of the Fuselage and the engine compartment are done. I reeeelly love this kit. Did I mention how much I love this kit?
so far seams and gaps are nonexistent and the only issue I have is from a mistake I made assembling the engine and that caused it not to line up straight. Now the top frame strap didnt follow suit so it may have some sort of a fit issue there.
right and left front frame pieces here.
Not as many hoses and pipes as the Tamiya Spitfire kit but this time it ran fairly well for me in its assembly.
I also had time to put the tail plane together and it fit like a glove.
I am going to attempt the Hurry Home Honey (early) which was in the Dragon kit. I kept the decals and tossed the kit because the tail was short shot.
Got the wings assembled and installed plus I only displayed one gun bay and ammo belt, I figured that's good enough. All through out this build I have wondered what it is like to have your best and I think with the way this kit is going so far, I may find out in out a couple of weeks.
The wings went on pretty well with only a small gap in the fit but it still does fit like a glove. Really, Dollar signs are flashing past my eyes as I think of other Tamiya kits yet to build.
I even feel cocky enough to attempt another figure but this time with a bit more attention to detail and not rushing to get any thing done. I could use some pointer on this guy. I still have to get the paint stripped off and re applied and filler in.
I did a bit of an experiment with  three paints. Alclad polished alum, Vallejo Alum and Vallejo Chrome. Lets see what you think.
The control is the base coat that I applied. Humbrol gloss black acrylic over Vallejo grey poly primer.
I love Alclad.  Important to have good surface prep.  Your Humbrol Gloss Black base worked really good.
I have had success with this base:
  • Tamiya Black X-1: 1
  • Tamiya Clear X22: 1
  • Mr. Leveling Thinner: 2
Applied using thin multiple layers.
I took my time and applied thin coats.  This is almost a dozen passes until I was comfortable with coverage.  I let mine cure for a week.
First overall base of Alclad.
Then various Alclad shades for the panels.
Pre weathering.
Flory Dark Dirt wash applied.
Good luck with your Stang!  Looking forward to see this.
I really am not trying to dispute the quality of alclad Rick. I just dont have the ventilation to shoot that stuff much and I yet have been able to get such a pristine surface prep that it takes. Thats why I use Vallejo and the Tamiya weathering system to get my metal effects. I want to do one one of these days but I guess I am a bit C.S. about the whole thing.
yes, ventilation is a must with Alclad.
watching for more...
Alllllll righty then. I decided to go with the rattle can, Tamiya TS-83 for the metal finish and some dark OD for the top. I know it looks a bit bright but I am figuring after weathering it will have some sort of a "used" but not used up look to it.
the spitfire prop is there just because...
Looks great. I always shy away from metal finishes, so kudos to you!
I know what you men about the Tamiya vs ZM kit. The Tamiya fits great, but the ZM needs a rake of filler and a prayer book.
Nice work so far. If your feeling brave and your confident the decals have adheared properly I would suggest to carefully mask off the offending area in small sections at a time ie one point at a time and spray some pretty well thinned white, two bits of masking tape with no cuts and your away. Just my two cents worth..... cheers Bevan
