Hi guys,
spoke to Huub at the aviation mega store and he warned me about masking fluid.
I use the very thin Vallejo one. I tested it on a window that i won't be using and it works perfect! smooth and tight demarcation.
Removing mask with a toothpick.
036FC21F-49FD-4F2C-AD65-6907148D9357_zps
Very nice work Jeroen,
Forgive the bloody obvious but how did you apply the fluid? I see a brush so is that dipped or is the fluid "squirted/dropped" on and then the brush settles it into place?
Regards
Regards
The Vallejo masking fluid is really thin but can be applied with a thin brush. It flows just enough the creep into and along the panel lines.
@Cor Verbeek: Is the Talens fluid thin or thick?
Besides, some masking fluids contain (traces of) ammonia. That wreaks havoc on your Tamiya, Gunze or Vallejo paints.... So be sure to use an ammonia-free fluid!
JP i also use Tallens and is quite fluid! A great liquid mask! I never work with Vallejo liquid mask so I cannot tell you if its similar... but i work with Tallens and i like it! :)
Here's a look at the formation lights on the underside of the fuselage.
HK Models provide 3 fine fitting clear lenses, but I'm taking a slightly different route.
Sprayed the base Alclad chrome. The used AMMO red, green and amber lens clear. Bot too much, so the Alclad shines through. These lenses weren't bright red through and through. And then filled the voids with Micro Klear.
Hope to mate the fuselage with the wings today...
B13CE490-15DA-446D-B4B0-0994A9430D4E_zps
433D9038-F733-4410-ABD0-84542106C1CF_zps
Beautiful work Jeroen! Splendid job!
I have my old Revell kit hanging in my office--I think I am going to have to replace it!
Tom
  • 1 month later...
my HK Mossie just arrived 'sans customs charges' courtesy of LuckyModel :)
any updates Jeroen?
Sorry sorry!
Got a little distracted...
Today sprayed the pre shade and first of the medium idea gray for the underside:
D0E80AD1-4FDE-46EE-901C-C505E4FB8BF3_zps
Doesn't look like a fatally flawed, cartoon-like monstrosity to me ;)
Loving it so far!
Will you Haggo this model?
