Thanks for noting the differences between the two kits. I've managed to get a G-6 kit ordered. Oddly, Australia was the cheapest I found, even with shipping to Canada.
A little update for you.
Cockpit painted and the resin nose is now more or less fitted, with some careful reshaping of the profile and stuff. It's not been too easy in places, but some careful perseverance, continual test-fitting and a little plastic shimming here and there, things do go together as planned.
Jim,
I note that before attaching the wings; you've added the wing spar, that has notches to keep the fuselage at the correct spacing.
Do you recommend this as the best way to get the resin nose aligned for those attempting this conversion?
9 hours ago, Wumm said:
Jim,
Without a doubt.
Firstly, you need to do a lot of work to make the new belly align in all the right places. I found mine needed shortening a little so it laid flat with the root leading edges lining up. Second, there are other modifications I needed to do to the resin belly piece which involved slicing away at some of the internals so it would fit properly. I would only have been able to decipher that if I'd glued the rear belly panel and spars in place. It's so much easier that way.
Thirdly, I found that you need that firm edge to be able to make a complete connection with the new nose.
The instructions are a little lacklustre and you need to think ahead with this one.
AND....the wings still easily slide on at this point too!
Thank you Jim, I thought as much. All very logical, and as usual you make it look easy.
Looks like a really nice conversion. The pic of it balanced on the Extra Thin makes it look the lovechild of a 109 and a pelican. :D
The model is actually painted and decaled now, but here are a couple of photos of what I have on my Mac before I dump and edit the other photos.
Got to say this is a very enjoyable project!
Guest DannyVM
Flown by Ray.......??? Was this the machine in which Mark Hanna crashed in Sabadell, Spain James???
That looks awesome!  I'm curious:  What was the armament of these Spanish birds?
Gaz
 Very clean build James. Fantastic presentation as always. :unworthy: Is there any indication of the Spanish version to be released , if so when?
Martin
On 3/28/2019 at 5:58 AM, Martinnfb said:
80mm rockets
Wow!  Those 20mm cannon sleeves look very penis-like
9 hours ago, coolboxx said:
So neat, any tips on your gloss work.
Low pressure, work closely and I always draw the needle a little further back to allow a wetter flow.
