Peterpools Posted December 27, 2021 Posted December 27, 2021 Harv Looking so good ...a gem in the making Keep ‘em comin Peter 1
harv Posted December 29, 2021 Author Posted December 29, 2021 Trying g my hand at making wire harnesses. What do you think ?.....harv 6
shark64 Posted December 29, 2021 Posted December 29, 2021 Harv. Please dont take this wrong way, this is only my opinion but your box looks out of scale in my opinion and a bit crooked. Also are you leaving enough space for the ceiling piece to be inatalled...air duck looks too tall. 2
harv Posted December 29, 2021 Author Posted December 29, 2021 Thanks Oliver. I appreciate you input. Nothing glued.im on the fence with the box. The air ducting to me looks OK. There is pieces that attract to the bottom going to the sides. Have any suggestions you can give me would be great. I'm following your build and learning from you....harv 1
Peterpools Posted December 29, 2021 Posted December 29, 2021 Harv Not sure which harness you are talking about: the ones going into and out of the panel (a bit too messy and have a few problems) or the ones running along the top of the fuselage wall, which look fine. Keep 'em comin Peter 1 1
shark64 Posted December 29, 2021 Posted December 29, 2021 24 minutes ago, harv said: Thanks Oliver. I appreciate you input. Nothing glued.im on the fence with the box. The air ducting to me looks OK. There is pieces that attract to the bottom going to the sides. Have any suggestions you can give me would be great. I'm following your build and learning from you....harv The box is a great idea for your interior but maybe cut it in half and make two boxes side by side. I see you have pencil marks on your box, i would bring them closer to each other since in my opinion they are too far apart. Dont abandon the box idea it works. 2 1
shark64 Posted January 6, 2022 Posted January 6, 2022 Harv. The little hole(barely visible) in the fuselage for the placement of the winch is wrong(its too low) . The bracket should go just below the transmission cowling. Use the 2 brackets provided in the kit to measure the right angle ..i made a mistake with mine so i have to improvise on mine. 2 1
harv Posted January 6, 2022 Author Posted January 6, 2022 Thank you Oliver. Much appreciated. I'll be home tomorrow and will check it out. I'm still on the fence with the box.....harv 2
shark64 Posted January 6, 2022 Posted January 6, 2022 19 minutes ago, harv said: Thank you Oliver. Much appreciated. I'll be home tomorrow and will check it out. I'm still on the fence with the box.....harv 3 1
harv Posted January 23, 2022 Author Posted January 23, 2022 Yes, it's been awhile. I'm stopping on the wiring to make a start on cockpit because some of the wiring will end up there. How's this for detail ?....harv 2
Kaireckstadt Posted January 23, 2022 Posted January 23, 2022 Looking quite good and the details are amazing Harv ! 2 1
harv Posted January 23, 2022 Author Posted January 23, 2022 I got the one window I needed to installed and masked. Might be a mistake. It pops out awfully easy. I still need more interior work to do....harv 3
shark64 Posted January 24, 2022 Posted January 24, 2022 Harv, You need to make a frame out of styrene or something else that you tape around your windows from outside once all the windows are in to protect them from popping in or out while you handle your helo. Your cockpit is moving forward i see. Dont forget to paint your fuselage color around your windows first before you glue them so you will an even paint job once its time to paint the fuselage. oliver 2 1
harv Posted January 24, 2022 Author Posted January 24, 2022 Thank you Oliver ! Yes, I've thinking of that very thing....harv 1
shark64 Posted January 24, 2022 Posted January 24, 2022 22 minutes ago, harv said: Thank you Oliver ! Yes, I've thinking of that very thing....harv I just made one for mine. Hows the inside box coming along? 2
harv Posted January 24, 2022 Author Posted January 24, 2022 I kinda set it aside for now. I want to get a basic pit in for wireingwiring...... What did you make for yours.....harv 1
shark64 Posted January 24, 2022 Posted January 24, 2022 5 minutes ago, harv said: I kinda set it aside for now. I want to get a basic pit in for wireingwiring...... What did you make for yours.....harv I used soft wires from Detailmaster. They do stuff for cars mostly but it works for us Helo modelers too. 1
harv Posted January 24, 2022 Author Posted January 24, 2022 I have lots of wire for tying Flys. Lots of sizes. I'll be using some next. What did you do for your windows....harv
shark64 Posted January 24, 2022 Posted January 24, 2022 2 hours ago, harv said: I have lots of wire for tying Flys. Lots of sizes. I'll be using some next. What did you do for your windows....harv Will preshade around windows first. A dip in future to make them sparkle more. I did not change the size but will be using the bulged ones. 2
Peterpools Posted January 24, 2022 Posted January 24, 2022 Harv Terrific progress and looking mighty good. With Oliver’s help and coaching, you’re off to the races. Keep ‘em comin Peter 1
harv Posted March 11, 2022 Author Posted March 11, 2022 Hello Oliver. Haven't done very much at all for a couple months. Keep looking at it and getting a few ideas. Thanks for asking. Yours is amazing my friend ! ....harv 1
shark64 Posted March 25, 2022 Posted March 25, 2022 Harv, i don’t know if u have the Adriatic model piece for the main rotor but if u do some trimming is needed since it sits too tall. Here’s what needs to be done. 4 1
