Administrators JeroenPeters Posted August 22, 2023 Author Administrators Posted August 22, 2023 Just noticed I screwed up with the screws. Fixed. 3 1
Administrators JeroenPeters Posted August 22, 2023 Author Administrators Posted August 22, 2023 Succes. The pressure air tanks came out nice. 6 1
KevinM Posted August 22, 2023 Posted August 22, 2023 You have a small model going on just there Jeroen 2
Administrators JeroenPeters Posted August 25, 2023 Author Administrators Posted August 25, 2023 Getting there. Basic colours are on. Needs more wiring and a few more details. 7 1
Administrators JeroenPeters Posted August 26, 2023 Author Administrators Posted August 26, 2023 Aaand the mk103 gun is done. Printed another piece. A connector box at the rear that houses a number of wires. Reference from the proper angle is scarce. also printed a shitload of hatches in various shapes. You cannoot scratch this kind of detail. 7 1
Administrators JeroenPeters Posted September 1, 2023 Author Administrators Posted September 1, 2023 Got a new 3D printer. Old 4k one on the right, new 12k one on the left. 8
Mo_GSP Posted September 1, 2023 Posted September 1, 2023 Please let me know how you like the new 12k printer. I'm using the Phrozen sonic mini 8k and on the fence on getting a 12k. Nice work! Those 3d parts really add to a build 3
Administrators JeroenPeters Posted September 2, 2023 Author Administrators Posted September 2, 2023 This will be a great little test for the new printer. The Ratier 1527/1528 prop with the spinner removed shows this intricate prop hub. Diameter will be 1cm. 8 1
Administrators JeroenPeters Posted September 3, 2023 Author Administrators Posted September 3, 2023 First prints. Also designed a new spinner backplate since the ZM one lacks all detail. 6 1
Bomber_County Posted September 4, 2023 Posted September 4, 2023 Jeroen, the little I’ve read on resin printers is that resin, washing, curing etc is time consuming. Are the reel type PLA printers, are they not as good? 1
Administrators JeroenPeters Posted September 4, 2023 Author Administrators Posted September 4, 2023 On 9/4/2023 at 12:36 PM, Bomber_County said: Jeroen, the little I’ve read on resin printers is that resin, washing, curing etc is time consuming. Are the reel type PLA printers, are they not as good? Expand As far as i know PLA printers are great for printing household objects and engineering / industrial design mock ups. There is a reason model companies all use resin printers for small detail prints. You simply can’t match the detail in resin with PLA. 3 1
Administrators JeroenPeters Posted September 4, 2023 Author Administrators Posted September 4, 2023 Ps. It takes me about 30 mins to draw up a part in 3d and approx. 1 hour to print it. I do however have a lot of failed prints, but theyre all to blame on my inexperience. 6
Administrators JeroenPeters Posted September 6, 2023 Author Administrators Posted September 6, 2023 This should do 7 1
Administrators JeroenPeters Posted September 21, 2023 Author Administrators Posted September 21, 2023 Started painting the props. One prop will have damage as per this photo i found. 11 1
Administrators JeroenPeters Posted October 4, 2023 Author Administrators Posted October 4, 2023 Adding rivets to the engine covers. not much longer before paint… 6 1
Administrators JeroenPeters Posted October 7, 2023 Author Administrators Posted October 7, 2023 Adding wires to the guns as per reference photo’s. It’s slow going but the painting stage is getting closer. 4 1
Administrators JeroenPeters Posted October 9, 2023 Author Administrators Posted October 9, 2023 Here we go. First paint is on. Semi gloss black marbling. Gives me a good idea of small imperfections too. 6 1
Administrators JeroenPeters Posted October 11, 2023 Author Administrators Posted October 11, 2023 Tedious work! 6 2
Administrators JeroenPeters Posted October 15, 2023 Author Administrators Posted October 15, 2023 Almost done with the marbled base coat. Polishing the whole thing now creates some nice contrasts. 8 1
Administrators JeroenPeters Posted October 15, 2023 Author Administrators Posted October 15, 2023 Getting there 4 1
Administrators JeroenPeters Posted October 17, 2023 Author Administrators Posted October 17, 2023 I’m going for a winter scheme (white K) so the bottom recieves rlm65 4 1
