8 hours ago, JeroenPeters said:
More paint on the engines.  Still a lot more painting and wiring to be added.
That looks great🙂👍
Adding more wires with lead 0,3mm lead wire. Not much to go by in terms of reference, but just enough and some common sense.
Sooo… printed the Norton and what i expected happened. The proper diameter of the spokes are too thin to print in 32nd scale. But… only a little. I’ll make the 1.3 times thicker and see what happens. The engine and all the other oarts are really there. You can’t keep see the translucency of the chain cover and even the engine parts through the thin walls.
Also printed more small parts for the Peregrine engines.
Altered the 3d file A LOT.
The fenders are so thin they are translucent. Spokes are a bit thicker and came out good this time. We’ll see after a cure.
Also started painting the wheels for the Whirlwind.
Can't believe how thin those fenders are. Do you use a razor saw for the print supports or just snip them? I'd be terrified whatever method I chose.
Geeez! Even the tiny valve is there. A bit of small cleanup to do. Printing a few bikes more now. I’ll pose two under the Whirlwind. Double engine, so to speak.
Hope the Norton 16H doesn’t bore you, but i need to get it printed properly and ready for paint before i continue the Whirlwind. The text on the base will see: it wasn’t the engines…
The ones that know what killed the Whirlwind will understand.
And here's the Brough Superior SS100.
It will take a few hours of more work to get this prepped for 3d printing.
Cutting the parts free from the supports is nerve wrecking. Lot more small connection points to be cleaned up. The rear wheel actually turns. And the kickstand works too.
That's ridiculous that the wheels actually turn. Is that something you deliberately modelled in the files or just a happy accident?
I knew how i was breaking up subassemblies so i knew the wheel would fit and turn. The same goes for the stand.
Thanks Jeroen. Kind of makes me glad I've never got into 3D printing as I have enough obsessions rattling around in my head without adding something like this! 😁
  • Haha 2
The gun camera was situated under the center fuselage, next to the empty shell container.
It had a side opening hatch, showing the G42B gun camera. I couldn't resist drawing it up in order to print it.
First steps.
I'm pretty shitty at 3D drawing, but I do what I can with what I've got.
Anyway. This part is 1,3cm long, so most of this detail will be lost.
