2 hours ago, belugawhaleman said:
Sorry to hear that Rob.
Thank you Paul, no need to feel sorry, sometimes you win, sometimes, you loose, that´s the way with challenges. There is still a chance to finish the Cobra halfway decently, but not how I wanted to finish it. I should have chosen a simpler kit, but the success with the Crocker motorcycle made me greedy. The Cobra is not the easiest choice, but others got it done, so I hopefully will pull through, however the outcome.
Some real challenges there Rob. Sorry to hear of the fit trouble. Especially this point in the build.
Don't think I have any real advice I can offer you. I'm hoping you persevere and finish it.
Hang in there Rob.  The level of build may not be up to your usual standards, but the work you've already done is masterful.
Regarding the CA fingerprint - oh yeah, been there, done that, smacked my head out of frustration.  Can you polish it out?  BTW, I use CA as the coating on my wood pens and I wet sand the CA to an amazingly clear finish.  Maybe you will be able to do the same?  Dry sanding seems to result in a frosted surface, but wet sanding provided a clear and hard finish.
Thanks for your supportive words, Carl and Chris. It´s nerve wrecking to prepare and finish all the sub assemblies, only to partly destroy them again and again during test fitting. Tolerances are extremely tight and that there is everything made up like in the real car doesn´t help either in the way of complexity. I will try to do my best salvaging the build.
For some reason, the primer and paint doesn´t adhere well on white metal and resin. Scratching and paint lifting is easily done, even with Kabuki masking, which I always de-tacked thee times.
One of the CA marks on the body, I might be able to polish out. but the other resulted in a paint lift down to the resin. I oversprayed it carefully and will clear coat later, but it will remain visible.
I had white CA fogging onto black painted parts, which look ugly. I will see, how much I can overspray there later on with a minimum of masking, because of the risks of paint lifting.
Rob, That is amazing that the primer didn't take.  ugh. I am feeling your pain, my friend.  Regarding the CA fogging - how about using a marker to redo the black parts? No need to mask.  Potentially.  Good luck!
Thank you Chris, I will respray, where possible. The Tamiya LP-5 semi matte black has a distinctive sheen and a marker would be visible. In some delicate areas, I will use a brush.
To do something productive and without destruction, I added details to the rear area. The rear lights were painted with Tamiya clear red, have a turned aluminum base and a small rubber ring around.
Next was the feared addition of the firewall, which fitted after a lot of sanding and grinding and is held in place wit a screw. Of course, there are a lot of scratches to be repaired. I also knocked off some parts during the process, which will be added later.
Then, I added the dashboard, which luckily was an easy task. Concerning CA fumes, if you are spotting into the foot wells, you notice chalky white residue. I never experience this kind of CA-fogging before and I always use the same glue and used the semi matte black often. Strangely the fogging reaches very far from the gluing area.
Hang in there Rob - it's looking spectacular!
Take a look at VMS products.  They offer a number of CA products, some I believe are designed not to fog.
It's looking really good there Rob.
I wonder if the fogging is because the fumes are trapped in a confined area and are thus a bit more concentrated.
13 hours ago, CANicoll said:
That really is a mystery.  But the dash looks amazing as does the firewall.
Muchas gracias amigos, The fumes of CA are not really trapped into the body. There are openings everywhere, there is no windshield and no rear window and the chassis is still missing. I never had an effect that strong. Maybe it has something to do with a very high humidity here, it´s about 95%. I use the same CA (Colle 21) since years for everything from wooden ships over plastic, resin and metal. Even with normal plastic kits, I often use it for ready painted parts and had no issues so far.
I will look into the VMS products
Rob,  still looks great even with the setbacks.  Concentrate on completion and ignore the boogers.  Come back later and fix those. Don’t let them play a mind game with you.
When I was an autobody tech/painter the hardest thing to learn during a paint job was if we hung a run in the paint was to ignore it and move on.  There’s no fixing it in in the paint booth with wet paint.  Focus on finishing the car as best as you can and address the little stuff later.  If we let a run get into our head, the entire paint job could easily be ruined.
Pro tip for your next metal model or anyone reading this that is planning on a metal project.  DON’T USED PLASTIC MODEL PRIMERS AS YOUR FIRST COAT!
Go get a self etching primer for metal.  Even a cheap rattle can of automotive etching primer is 100X better for your base coat primer.  If you cannot source it, we use to use etching fluid we would spray on bare metal and the wipe it dry with a clean cloth.  I’m sure it’s probably a common chemical anyone can find. ( I think it’s copper sulphate)
Another option, but not as effective is to completely sand the surface with a 220 grit sand paper (we used 80 grit on an DA sander on cars) and then prime it and build the primer up and sand smooth.  The problem here though is primer can shrink over time and sand scratches will appear in the paint.
Now the best option is an automotive etching epoxy primer.  Highly toxic if you breathe it in, so a charcoal filter respirator is mandatory.  And unfortunately it only comes in larger quantities than the modeler needs.  If you have a bodyshop near by, stop in and see if they would be willing to sell you 2-3 oz of primer and the catalyst. It’s usually a 1:1 mix.  Spray it on, let it sit 24 hours then spray on a primer on top to work out for paint.  But being an epoxy, it’s just like glue.  You’re gluing the primer to the metal with it as long as you stay within the recoat window.
  • Thanks 4
Thank you Scott, always great to hear some pro tips. I have not a lot of experience with car bodies, be it in real size or large scale. I will try to lay my hand on some etch primer, being it in small bottles from Tamiya or Mr. Hobby or from my mechanic, who also does body repairs.
It´s fantastic, to read about how the stuff works, I had no idea. Unfortunately, the adherence on resin isn´t great either. I cleaned all the parts with alcohol, to get rid of cast residues, but I didn´t sand the parts. I will test the etching primer for sure.
Poco a poco, I grind my way through the Cobra build. Today, I assembled the tank filler cap, a seemingly small task, but it involved about twenty parts and is functionally. I polished the cap itself with Autosol metal polish and added the numerous etched parts and rivets.
Then I started with the steering wheel, which got primed, airbrushed in a mix of red brown color and sand. After drying, I applied several layers of dark brown and red brown oil colors, thinned with fast drying thinner for a realistic looking wood texture. Tomorrow, I will apply a clear coat as finish.
Finally, I repaired the damages to the firewall and pinned the lower side to the door fairings with brass rods for enforcement, to close the gaps in this area.
Ah, I forgot that’s a resin body and not Diecast. Derp moment on my part.  But my comment on epoxy primer, pardon the pun, really “sticks” here.  LOL.  I ran into the same issues building my Fisher Cutlass.  The entire time all I could think was my next resin build will get a 1st coat of epoxy primer.   Thankfully my son goes through gallons of this stuff with his 1:1 scale cars he builds.  I’m going to get some bottles and have him pour me off some for my next resin build.
That tank filler cap is TWENTY PARTS????  Rob you have the patience of a saint. OMG.  Looks terrific.  Does it actually flip open?
I will dig deeper into the primer thing, Scott. Thanks a lot for your explanations and sharing of experiences. The primer easily lifts off the white metal parts and a bit less easy from the resin. A light sanding job might help, where possible.
You are absolutely right about letting painting mistakes happen and forget about them temporarily. There is nothing you can do, when the paint is wet. I try to minimize airbrushing errors due to proper preparation, but yeah, there is Murphy lurking around the corner :D.
3 hours ago, BlrwestSiR said:
Incredible detail on that filler cap. The steering wheel looks to be coming along nicely as well.
Thank you Chris and Carl. You can call me a liar, there are only 18 parts involved :D. The tank filler cap is really working, just open the tiny latch on the left and put in the juice - errr - not now, because the tank isn´t installed right now.
After priming some interior parts for later stages, I had an idea about how to deal with the wheels. They are made from cast white metal and were cleaned in the tumbler polisher at the beginning of the build.
I thought, I have to give them a bit more shine, to keep the eyes trained on the wheels, letting some other mistakes skip :D. Hand polishing proved difficult and I found, a conical head M4 screw holds the rims in place in my accumulator drilling machine. Then I sanded the wheels with fine grit sanding sponges, followed by polishing with Autosol polishing paste on a cotton rag.
Now, I like the result. Later the wheels will be airbrushed in black and then I polish off the higher parts which are now shiny. Of course, before airbrushing the rims will be cleaned properly. the polished left one on the pic has a lot of dirt accumulated.
Today, I made the first attempt of a very crucial step, with marrying the body to the chassis. As you can imagine, there are a lots of contact points on the chassis, around the firewall, under the instrument panel, the rear body framing, the rollcage, ...., to cut it short, I failed. Now I´m inspecting everything for color abrasion, which might show problematic areas, which may need to be tweaked. Fortunately, I didn´t brake too many parts, but the rear hatch framing needs to be reinstalled.
I´m very happy, that I didn´t follow the manual with the rear hatch window and windshield installed. before joining the chassis and body. It would have been a nightmare to handle the heavy kit with these mounted.
Before all this, I finished the shoulder straps of the seat belts, which is an easy task with the supplied PE buckles, belt material and double sided tape, which holds the belts perfectly  together and in place.
I finished the steering wheel with a coat of Tamiya´s clear orange onto the dried oil colors and then assembled the PE and center knob. That was more difficult then expected, but finally it worked. The clear center part is made from resin and was not clear at all from the beginning and had some tiny scratches. I polished the lens with Tamiya´s polishing compounds and adhered it with Pledge on the decals.
Next were the wheels, which were sprayed with Tamiya´s semi matte black (LP-5). After two hours of drying time, I didn´t want the paint to cure too much, I swiped the rims with cotton swabs and cotton cloth, slightly dampened with Tamiya lacquer thinner and cleaned off the polished areas.
Even with the hiccups Rob she will be fine seldom do I have a build without the "Persian Rug Flaw":unworthy:
Forum been slow of late?:hsmack:
I hope, the hiccups don´t lead to not being able to join chassis to the body, Kevin.
Everybody is building quietly at home, not posting their secret projects :D.
BTW: Wasn´t there a Sandbox GB ending some month ago, without any results? Well the Twins GB wasn´t officially ended either.
The steering wheel looks great as do the rims.
Good idea on leaving the glass out until you can sort the body fit. Hope it doesn't require too much tweaking.
I haven't had much time at the bench lately. Last night was the first time in almost two weeks where I was able to get to spend time there. Of course, I ended up starting something(s) new...
I love your progress, Rob, even with the hiccups, which I’m sure you’ll overcome. The kit is challenging, but most likely, given MFH’s reputation, it has been designed to be doable …
After my own hiccup with my compressor blowing a connecting hose, I have resumed the painting of my Cutlass.  I have chosen a NMF finish of VA-83, with a blue and white chevron on the fuselage, and blue wing tips and fins’ leading edges. It is a lot of masking, and re-masking, so nothing secret, but nothing spectacular to show, yet … Soon, though …
