12 hours ago, DocRob said:
The speedy little Honda was a fast project indeed. It took me only two weeks to accomplish and leaves me with a "is it really done ?" expression.
The fairing was the most problematic part of the build. I sprayed it with AK´s Extreme Metal flat aluminum and when I added some mild Tamiya decal fluid, I got a bad paint surface. The fairing needed respraying and then, I glossed over the flat aluminum with Alclad aqua gloss, after my Mr. Color GX100 clear wasn´t working. Not for the first time, it produced a candy cotton effect, equal, which mixing ratio I took. When it works, GX100 is perfect, but often it doesn´t for me and I don´t know why.
Then I applied the decals which were generally nice to work with. They contoured well with Tamiya Mark Fit Strong fluid applied on top, using a hairdryer as well.
For some reason, the 1 of the #16 deformed a tiny bit with the Mark Fit, but I corrected this with a marker.
The numerous tiny metal rivets were applied, using a flat cut toothpick with low tack double sided adhesive tape. Before, the molded rivets were cut away with a sharp blade and after marking the center with a steel needle, I drilled 0,5 mm holes.
Really nicely built👍🏆. You could think the motorcycle was real. If I may suggest, I would add some fine wire to handlebars grips to represent as safetywire.
16 hours ago, belugawhaleman said:
A great finish Rob! Well done!
15 hours ago, HubertB said:
She's a beauty :unworthy: !
14 hours ago, Landlubber Mike said:
Quick but spectacular build Rob!!  Really nicely done!
13 hours ago, KevinM said:
Yeah you breezed right through that one Rob came out looking really Nice you must be on Holiday?;)
13 hours ago, BlrwestSiR said:
Wow, that looks stunning. Can't believe how quickly it went together.
Muchas gracias amigos, a phase of bad weather helped to finish the Honda quickly. On the islands of eternal spring, spring is the worst of all seasons and seemingly lasts forever :D.
The other determining factor was fun. It was a pure joy to put this perfect engineered kit together. the extra set are the salt in the soup, detailing wise and to add a bit of challenge.
@FullArmor, I thought about safety wires, which are everywhere on the Honda, but skipped it, as I wanted a oob build with only the extra detail sets added. You are allowed to call me lazy :D.
They are only separated by one year and two cylinders. Even the top speed doesn´t differ that much, but what a difference my last two builds have in appearance.
Here, I picked my very first motorcycle build out from the shelf and sided it to the tiny Honda
Thank you Kurok, the finish is one of the most delicate tasks to master with car and bike kits. I learned a lot through these builds, but are far from perfect.
