coolboxx Posted May 14, 2017 Posted May 14, 2017 All done thank you all so much for your kind comments walts and all. https://forum.largescalemodeller.com/topic/5117-hasegawa-fw-190-a8-walther-dahl-jg-300/#comment-65885 8
Administrators JeroenPeters Posted May 14, 2017 Administrators Posted May 14, 2017 LOVE IT! Love the rivets, paint job, scheme. Supercool. 1
GusMac Posted May 14, 2017 Posted May 14, 2017 Beautiful finish, just worn enough to look realistic. 1
Members Mikester Posted May 15, 2017 Members Posted May 15, 2017 Gorgeous, really well executed all the way around! 1
BevanBrooks Posted May 15, 2017 Posted May 15, 2017 I feel the urge to build somthing Luftwaffe now, dam! Great work on the Wurger. Cheers Bevan. 1
ophthoidoug Posted May 17, 2017 Posted May 17, 2017 Beautiful! Only those of us who've tried, know how difficult it is to achieve that kind of finish... Can I ask you to share some painting details? *which paints you use for the grey/green wing surfaces (specific brand & ID)? *did you use any kind of surfacing or priming agent before painting? *what final satin coat you finished with (specific brand & ID or custom mix)? Thanks for posting this one! 1
coolboxx Posted May 17, 2017 Author Posted May 17, 2017 4 hours ago, ophthoidoug said: Thank you all for the great feedback. Bevan I look forward to seeing your next work. Ophthoidoug, great questions my mixes are mixed lighter then the colours i am trying to copy. My washes at the end blend these colours they also darken them. Wash mix 1 sludge mix black, brown pastel various shades. Wash mix 2 enamel black/brown (humbrol) pin wash, the 2 mix is also blended with brush down the side (darker to lighter to the tail) I blend with white spirit very lightly. Holts grey primer (auto spray paint) very smooth finish. Good plastic preparation before I spray. RLM 74 mix tamiya acyclic = XF-22 + XF-1 /approximately 80:1 this mix is the Base mix, XF-63 added to lighten if required. RLM 75 mix tamiya acyclic = XF-19 + XF-1 approximately 80:1,now I add my violet mix which is tamiya XF-7 & XF-8 =1drop. RLM 76 mix tamiya acyclic =XF-2 x1 jar + X5 between 5 and 8 drops (looks peppermint green when mixed) again Base mix, I will add XF-63 to darken if required. All mixes are tweaked very slightly either darker or lighter. Once mixed I use Mr. Color LEVELING THINNER 50/50 approx. All washes are applied after I have airbrushed humbrol Clear gloss varnish The satin is Humbrol spray can. I am still tweaking these but these are getting very close to what I am after. Hope this helps you. Darren
rkranias Posted May 29, 2017 Posted May 29, 2017 lovely Wurger. great finish and resolute on the slightly faded camo colors. you pulled it off quite well. 1
