Michaelscarborough Posted April 16, 2018 Posted April 16, 2018 Breath deeply and repeat after me, "Ommmmmmmm......" (Lookin' good!!) 2
GusMac Posted April 16, 2018 Posted April 16, 2018 That looks ridiculous. Are you soldering them? There doesn't seem to be much of an attachment point for glueing them. 1
Administrators JeroenPeters Posted April 17, 2018 Author Administrators Posted April 17, 2018 6 hours ago, GusMac said: That looks ridiculous. Are you soldering them? There doesn't seem to be much of an attachment point for glueing them. Well spotted!! I’m using Zap a Gap, but indeed, the attatchment points are very small. A great test for my PE skills..
Wouter Posted April 17, 2018 Posted April 17, 2018 Hnnnnngggg... eye twitch... That's some serious test for your patience 1
GusMac Posted April 17, 2018 Posted April 17, 2018 Thanks Jeroen. Do you use the brush on version or just small spots from the standard applicator? 1
Administrators JeroenPeters Posted April 29, 2018 Author Administrators Posted April 29, 2018 Hi Gus, i use fine solder wire to apply the glue. When it builds up too mich at the end, i cut it off. here’s the finishes nose turret. Only needs the doors, but i’ll install them at the end. I’m posing the nose turret in a 90 degree angle so the doors will point outside the fuselage. 9
Wingco57 Posted May 1, 2018 Posted May 1, 2018 Very nice, but don't forget to fit the turrets before you close the fuselage, otherwise well you get my drift..... Cees 2
Administrators JeroenPeters Posted May 14, 2018 Author Administrators Posted May 14, 2018 Started work on the props and spinners. Please note that the proper spinners and rotol prop for the mkX version are not included in this kit. This means broadening the props with Evergreen strips. I added putty and mr Surfacer and am smoothing them out now. The spinners i fashioned from 32nd scale Luftwaffe bombs. 7
Michaelscarborough Posted May 15, 2018 Posted May 15, 2018 Yeah, baby...this is MODEL BUILDING..at its finest! Asses being kicked in Neederland...... 2
Administrators JeroenPeters Posted May 22, 2018 Author Administrators Posted May 22, 2018 Props are done! Started work on the gear. Lots of PE in this department as well. Also fitted tge resin wheels. Just need to lesten the weighted tire effect a little. 4
Wingco57 Posted May 22, 2018 Posted May 22, 2018 Lovely Jeroen, but I still hate those wheels, they look very anorexic.
Administrators James H Posted May 22, 2018 Administrators Posted May 22, 2018 That gear work is insane. Just wait till you get the Lanc 1
Administrators JeroenPeters Posted May 23, 2018 Author Administrators Posted May 23, 2018 22 hours ago, Wingco57 said: Lovely Jeroen, but I still hate those wheels, they look very anorexic. I know... but if i fix those too this thing will never get done! .... 2
Administrators JeroenPeters Posted May 23, 2018 Author Administrators Posted May 23, 2018 After a long search I found a 1944 aerial RAF recon photo of Wilnis. Bought it for 50€ and is worh every pixel. 6000x6000 pixels in size. Taken a little over a year after the crash. this photo will be printed onto wood and form the base. The crash site (now marked in red) will be marked by a silver pin. 3
GusMac Posted May 23, 2018 Posted May 23, 2018 Wow, that's a real find Jeroen. Great image. People sometimes are shocked by what was possible 'pre-digital' but those photo-recon cameras were the best around. 1
Wingco57 Posted May 24, 2018 Posted May 24, 2018 We still use these photographs to locate aircraft wrecks on land. 4
Administrators JeroenPeters Posted May 25, 2018 Author Administrators Posted May 25, 2018 On 24-5-2018 at 8:33 AM, Wingco57 said: We still use these photographs to locate aircraft wrecks on land. I can imagine. The detail is amazing. Just ordered a 40x60cm print of this photo on aluminium. I will have this aluminium plate mounted on a thick wooden base. The location of the crash will be marked by a silver pin. The model will be placed on top. Along with the cowling engine flap 1
Michaelscarborough Posted May 28, 2018 Posted May 28, 2018 Just catching up here.....Bravo to you for persevering and finding the print, JP. What a connection to the reality of what happened it makes. I love what you've done with the prop blades. Cheers from NYC, Michael 1
Administrators JeroenPeters Posted June 3, 2018 Author Administrators Posted June 3, 2018 Working on the bomb bay. Man... this stuff is impressive!! and here’s the aluminium plate that will go onto the wooden base. 3
Administrators James H Posted June 3, 2018 Administrators Posted June 3, 2018 That PE is insane. I don't think I saw anything as complex as that before. Serious kudos...
