I'm trying to do my B-25 seatbelts and can not figure out assembly. Can anyone show or tell me how its done ? TIA......Harv
Harv, do these pics help at all? These are the instructions from Wako for their US belts.  I used these for my belts as the HGW ones ddidn't make any sense to me.
As the part numbers aren't the same, I used the parts layout diagram to match up and compare the two different belts. Also, HGW don't give you enough buckles and belts to make a full complement of belts. Go figure.
If you need more help, let me know.
do you guys crinkle ( that's a technical term by the way )  them up with your fingers, I still can't figure out how to make them look like real ones and get them to lay down like you guys do......:hsmack:
I don't crinkle them up. I find that I can't thread them through the buckles if I do. I'll sometimes wrinkle them a bit after assembly. Mostly though I glue them in a wrinkled/disheveled position like below.
oh, ok thanks Carl, I was always under the impression that they had to be worked with your fingers etc... to make them look real.... your way makes perfect sense...
Thanks Harv, I probably won't bother, but I sure do like the idea of leaving the buckle on the fret, I think Carl mentioned that a long while ago, on one of his older builds, I tried it and it sure works
I think that leaving the PE on the fret while you thread material is the single best tip for working with harnesses!
I totally agree, when I read that is was an "Ah-HA" ( cue the angels signing) moment for me....
Leaving the buckles on the fret is a big help. If you look at the pictures on the instructions I posted, you'll see that Wako even lays out their fret in a way to make it easier to do so. It's too bad we can't get HGW to do something similar.
One other thing you may want to do. I usually paint the backside of the belts as they're usually white. This helps with jumbled up look. It's also easier to paint them while they're still attached.
HGW belts are truly amazing. I use Radu’s as well, but ahagaw (typo, but for Harv: HGW. I sure love autocorrect) has belts for everything, and they look awesome when done.
Carl filled me in on the leaving the buckles on the frets, and it’s taken 95% of the stress out of assembly.
