6 minutes ago, Peterpools said:
Mark
Nothing like progress  and for me this is the least fun part of any build - sanding, sanding and sanding
yes indeed no fun part but when done it will look beter
still a few hours to go
Mark
small update on the pit
next up more filling and sanding to do on the other half off the feuselage
im going to try to close it at the end off the week
Mark
more things done and for me a mile stone in the build
and didt a test setup
now more filling,sanding and scribbing to go
Mark
small update
sanding done on the engine covers
first feultank in place
more sanding,filling and scribbing to go
Mark
more things done
still needs some sanding and polishing before primer then i can check off everyting is good
Mark
17 hours ago, Peterpools said:
Mark
Amazing progress . filing, sanding and riveting and you still keep coming back for more.
Looking mighty good
Keep 'em coming
Thanks Peter
still not there but getting closser
14 hours ago, Martinnfb said:
Mark what putty are you using to fill the small rivets? It looks flawless .:unworthy:
im using tamiya white putty and it warks great for me
14 hours ago, GazzaS said:
Those raised rivets make it look great!
Not yet rivets in place the one you are seeing are the fild ones
still a bit more filling and sanding to go
its now in the primer still a few mistakes to cleanup before the rivets will be added
stay tunned
Mark
Tremendous work on the Hip. The riveted surfaces will look great under some flaking paint. Can't wait to see how your project turns out.
