FME erk Posted March 7, 2019 Posted March 7, 2019 I know its not an aircraft but its certainly not an AFV but it does relate to the 32nd Lancaster that I intend to build once the workbench is clear, (one needs a lot of space ) I have also built some engine trestles to compliment the Lancaster build Thanks for looking in David 14
Bomber_County Posted March 10, 2019 Posted March 10, 2019 David, is this scratch built or a kit? We need more 32nd support accessories..... 1
FME erk Posted March 10, 2019 Author Posted March 10, 2019 Phil I scratch built it from a sketch and measurements that I had drawn on a sheet of paper done in the early 1980's. Along with numerous photographs. The wheels I got from an overseas producers , I had to modify the hub, they are the correct diameter overall but the wheel/tyre ratio is slightly out but despite this I think it looks the part. If you are not aware, I scratch built some engine trestle and just completing a 32nd Nissen hut, again they are constructed from drawings of measurements taken from the real thing along with photographs. I have also done some wheel chocks. (I intend to display my HK Lancaster on a small diorama). I have built the Tamiya 35th Austin Tilly, converted to a Hillman Tilly, and in the final throws of the IBG 35th Bedford QL. You can purchase a 32nd Trolley acc. from IconicAir and I believe he is going to produce some bomb trolleys and a David Brown tractor ??? David 2
Bomber_County Posted March 10, 2019 Posted March 10, 2019 I saw your trolley etc, the Nissen hut sounds intriguing. Really looking forward to the David Brown, I was speaking to Graham at Telford and it sounded like the David Brown was next in the list..... 1
FME erk Posted September 25, 2020 Author Posted September 25, 2020 Talking of the David Brown tractor kit mentioned above kinda sent me rushing to my photo album to copy this here . . . The OIL bowser in tow with the Iconicair DB tractor . . . completed September 2020 and the completed DB tractor pulling a set of bomb trolleys (scratch-built) 2
FME erk Posted July 30, 2021 Author Posted July 30, 2021 Just re-inserted the photos of the Iconicair David Brown tractor in 32nd scale . . . Ian 3
Vandy1 VX-4 Posted August 3, 2021 Posted August 3, 2021 I’d like to see some of your photos of your Nissen hut!!! 1
FME erk Posted August 4, 2021 Author Posted August 4, 2021 I posted the detail under its own heading 'Nissen hut' (scratch build)
