Hi Guys,
    I have a bunch of Master Barrels .50 cal barrels in 1/48 scale that I'll never use.  And I need 4 .30 cal barrels (in 1/32 scale) that in photographs look identical to the .50 cal barrels.  Mathematically, how far are the two apart?
Thanks for your thoughts!
Gaz
Visually ? To go from 1/48 scale to 1/35-1/32 scale makes quite a difference. Here is a picture demonstrating the size in 1/35 scale.
MH13262-2.jpg?1533738074
A .30 cal barrel in 1/32 is .009375 internally, a 1/48 .50 internally is .010416.
A .30 cal in 1/35, it’s .008576.
1/32 is pretty close, other than the barrel design, it would be hard to tell.
I failed math............ well sorta......................... one is bigger and the other is smaller.................. see I AM Management Material !
:rofl:
.50 inches in 1/48 is 0.0104 inches  (0.5/48)
0.0104 inches equates to .333 inches in 1/32 scale (0.0104*32)
Keep in mind that's bore size, not OD. As long as the length is OK, I'd run with it.
A true 30 cal bore in 1/32 would be .009375 inches
Thanks for your help, fellas!
Alas, I've found a feature on the m1919 .30 cal that doesn't exist on the .50 cal:
d88f0e9f-d74d-5587-beed-15f71d1bfbde_5a0
The slots at the muzzle end.
Gaz
