recon Posted June 20, 2019 Posted June 20, 2019 I am getting ready to decal my dauntless. After the decals have been applied, what is the best dull coat to use? Mike 2
Ryan Posted June 20, 2019 Posted June 20, 2019 Brace yourself for many opinions. I am really liking Vallejo Satin right now, but have used almost all of the brands out there. Watch your humidity and test test test. 2
JohnB Posted June 20, 2019 Posted June 20, 2019 Alclad Kleer Kote Flat is my go-to matt coat. Works great. 1
Administrators Clunkmeister Posted June 28, 2019 Administrators Posted June 28, 2019 The one I started using 2 years ago is Model Master clear lacquers. Not Testors main brand, bu MM in the glass jars, thin them slightly with levelling Thinner and airbrush on your model. It is almost impossible to apply too much, and unlike other dullcoats, if you do happen to apply too much it never, ever has left white spots. I used Alclad dullcoats for years, and although they look great, I had a problem with them never really completely drying. They always stayed a bit tacky, enough that you could almost leave fingerprints in the clear. The MM lacquer dries hard as a rock in a few minutes. I can't take credit for this, the one who clued me in is Brian Outagtcha on the other site. 2 1
DocRob Posted June 29, 2019 Posted June 29, 2019 My go to variant is using Future combined with Tamiya flat base. The benefit is, that you can determinate the dullness by adjusting the mix. I had no issues with tackiness or whitening, which might appear if you use way too much of the flat base. Cheers Rob 2
Members Mikester Posted June 29, 2019 Members Posted June 29, 2019 Mr. Color and Tamiya are both great.
