SapperSix Posted March 29, 2020 Posted March 29, 2020 Do you have one? If so do you use it? Any advice? I am about to have a few projects that will have a considerable amount of PE. I m looking to ease the pain.....Any thoughts and input is appreciated. 2
HubertB Posted March 29, 2020 Posted March 29, 2020 I bought mine from Micro-Mark. It was made of hard PA66 (a plastic type) at the time. It works well, and I am happy with it. Nowadays, you get some in machined metal, which is better as you get sharper edges at the bending point. From Micro-Mark : https://www.micromark.com/Etch-Buddy-Photo-Etch-Bending-Fixture And the top items, quality-wise, from RP Toolz. If you peruse their site, and are a tool-geek like me, you can easily spend a few kits’ worth on their site, but you won’t regret it. http://rptoolz.unas.hu/en/spl/450289/PIRANHA-PE-tools HTH Hubert 4
DocRob Posted March 29, 2020 Posted March 29, 2020 Bending PE is much easier and less dreading with the right tools. I got some different ones depending on what is to bend size ways, shape ways and complexity wise. For tiny parts I have a Tamiya made tweezer with a flat head, perfectly for e.g. optics in tank cupolas and other tiny stuff. Then there are flat pliers with differently shaped heads in my tool box. With a bending tool, you should first analyse your requirement size wise. If you plan to bend lets say landing flaps in 1/32 or large armor sheets you need a bigger tool. For these bigger tools you should get an equally long bending blade, smaller parts can be bend with a scalpel blade. It's always more fun to work with well designed tools made out of appropriate materials. I have this 5'' tool from the Small Shop since years and can recommend it highly. https://thesmallshop.com/collections/photo-etch-bending-tools/products/sms004-5-5-inch-hold-and-fold-the-5-speed Cheers Rob 3
Bomber_County Posted March 29, 2020 Posted March 29, 2020 I have an ancients Mission Models Etchmate 3C, I agree with Hubert the new generation are metal so can be a little more precise. I’m happy with the 3C and a tool box full of straight pliers for all of the other tiny or complex bend jobs...... 3
Old Dog Posted March 29, 2020 Posted March 29, 2020 I guess it depends on what you are doing, I bought the Etch Mate 3C years ago but never had much luck with it but I seldom do any PE work larger than cockpit size stuff and I find I have better luck nailing bend points using single edge razor blades and chisel tip X-acto blades. For airframe parts like flaps or large pieces used on armor a bending tool is probably the best way to go. 2
SapperSix Posted March 30, 2020 Author Posted March 30, 2020 Thank you gentlemen for your welcome advice. Hubert, Thank you for reminding me of RP. I have ordered there in the past and have always missed the big Piranha PE bender or decided at the last minute it wasn't worth the coin. I bought the 195MM Piranha and am looking forward to getting better at my PE. I bought it for flexibility in regards to the add length. I have a two 1/35 Strykers kits with full PE RPG cages and what not. I also have full PE sets for a 1/32 Super Stallion and CH-47. They are a ways out there but I am working my way to them. 2
SapperSix Posted March 30, 2020 Author Posted March 30, 2020 20 hours ago, DocRob said: Bending PE is much easier and less dreading with the right tools. I got some different ones depending on what is to bend size ways, shape ways and complexity wise. For tiny parts I have a Tamiya made tweezer with a flat head, perfectly for e.g. optics in tank cupolas and other tiny stuff. Then there are flat pliers with differently shaped heads in my tool box. With a bending tool, you should first analyse your requirement size wise. If you plan to bend lets say landing flaps in 1/32 or large armor sheets you need a bigger tool. For these bigger tools you should get an equally long bending blade, smaller parts can be bend with a scalpel blade. It's always more fun to work with well designed tools made out of appropriate materials. I have this 5'' tool from the Small Shop since years and can recommend it highly. https://thesmallshop.com/collections/photo-etch-bending-tools/products/sms004-5-5-inch-hold-and-fold-the-5-speed Cheers Rob I was laughing as I read this as I do this myself. I am taking your advice to heart I sure appreciate the input. 3
DocRob Posted March 30, 2020 Posted March 30, 2020 I don't get the laughing part Sapper, but looked up the RP tool. Nice stuff, but I recommend to add an evenly long sharp blade for e.g. landing flaps. It makes sharp bendings of big parts much easier. Some time ago I added this little gem to my tools repertoire and use it a lot for tiny parts. Cheers Rob 1 1
harv Posted March 30, 2020 Posted March 30, 2020 On 3/29/2020 at 5:41 AM, Bomber_County said: I have an ancients Mission Models Etchmate 3C, I agree with Hubert the new generation are metal so can be a little more precise. I’m happy with the 3C and a tool box full of straight pliers for all of the other tiny or complex bend jobs...... Have the same. It is used on occasion. I agree with statements about the newer ones.....harv 1
SapperSix Posted March 30, 2020 Author Posted March 30, 2020 11 hours ago, DocRob said: I don't get the laughing part Sapper, but looked up the RP tool. Nice stuff, but I recommend to add an evenly long sharp blade for e.g. landing flaps. It makes sharp bendings of big parts much easier. Some time ago I added this little gem to my tools repertoire and use it a lot for tiny parts. No Worries Doc. I found it humorous that worlds apart we found the same solution to form handles. As you described it, I was able to visualize it succinctly. I hadn't thought too much about the blade. Looks like I will need to revisit that one. Much appreciated. 1
SapperSix Posted March 30, 2020 Author Posted March 30, 2020 2 hours ago, harv said: Have the same. It is used on occasion. I agree with statements about the newer ones.....harv It wont be long before I am swearing up a storm when I start messing up parts. I am glad to know you have also used one.
