They should have done the F model to begin with so as to broaden market appeal instead of that late model.I'm sure more people would already be on the hook for 1 or 2 instead so many of us are waiting till april or march.
I totally agree. Had they done an F model first, they may have sold a lot more. Just my opinion. Heck, an E model would have been awesome if that was released first as well. If I'm not mistaken, when they do release the F model, you can also make an E model as well as they are supposed to have parts for both.
I am sure they have their reasons releasing the G first... Like Tamiya releasing the Birdcage F4U prior to the 1A/D kit/s...
I totally agree Dave. However, I'm glad that Tamiya released the F4U Birdcage first as that is my favorite model of F4U. It saw quite a bit of action in the Solomons. I may be in the minority here about the F4U-1 Birdcage Corsair.
At least this way, they can correct the fat fuselage issues when they tool the new fuselage for the F model :)
Doug
Doug
I don't think they will do that considering the tooling cost would be too large for just the fuses...
It depends whether it's an early or late E model.
The early Es had the three small windows in the nose, as well as the periscope sighted ventral turret. The cowlings are also different on the earlier E model as they were fitted with narrower propeller blades than the later Es through to the G. When the wider paddle blade props were introduced the front of the cowling had to be redesigned as the wider props couldn't go to the full feather position with the original cowling - hence the late E models had the blunter type of cowling fitted.
Towards the end of B-17E production the larger F style cheek windows were introduced (as seen on the early production block F models) and I believe after the first 100 or so (the exact number escapes me) the Sperry Ball Turret was introduced as the original unmanned ventral turret was very difficult to sight effectively.
If HK go for a late production E model they were almost identical to the F model externally, bar the heavily framed nose piece. That would be the easiest route for them!
Tom
  • 6 months later...
David, that is some amazing work. Your scratch building skills are top notch. Hold on their buddy...I better grab me a note pad and a pen to take some cool trips/tricks that you are using/sharing ;) Well, you keep it going strong my friend...keep it going strong. :)
Mike
