Hey guys
 Small update, I finished the passenger side fuel tank and reworked/scratch built a new headache rack.
20210124_182726.jpgthis view shows the passenger side fuel tank with steps.
20210124_182547.jpgthis view shows the whole truck and tank.
20210124_182518.jpgthis view shows the tank from the front.
20210124_182457.jpgthis view shows the new headache rack.
20210124_182435.jpgthis view shows the whole truck and headache rack.
20210124_182402.jpgrear view of the headache rack.
20210124_182747.jpgthis view shows the driver side fuel tank. Well that's it for now be back with more soon.
Ron G
Hey guys
  Kind of a update, but not. I'm starting another project. Before you all go WHAT!!! it's a load for the XL 130 HD drop nose lowboy trailer. I'm  going to start a new post for it. It's going to be a Cat 374F L large excavator.
20210127_131948.jpghere is the temporary undercarriage sitting on the trailer.
20210127_133000.jpgmore of a top view of the tracks. These are from Bruder toys, there for there mini excavator, but are perfect for the Cat 374F L. So check out my post on this new project.
Ron G
My old man would love that truck model!   I think it looks excellent, too...  though I'm not so keen on trucks as the olds man.
Hey guys
  Here's another update for you all. I received some 3D printed air suspensions from Shapways, but I guess I s#%*^ed up and got ones for a regular height trailer, not a lowboy. It would have been way to much work to rework them, so I went on line and looked around to see what I could find that might work. I went to Moluminums site and found just what I needed.
20210216_173205.jpgthis view shows the air suspension in place on the trailer. All that needs to be done now is add the shocks.
20210216_173146.jpganother view of the air suspension from the rear.
20210216_173130.jpgthis view shows all the axles...WHOOPS!!!...:angry::brickwall::brickwall::censored::omg: I put the axle on the rear on upside down...#^*•☆... damn! Well tomorrow I'm going to have to fix it. This was not a good day, from the first part I dropped on the floor, to the second, to the third, etc., etc. to messing up the axle, so I decided to give up and go eat dinner.
HT250us_001_5-16-07.pngthis view shows the real suspension that the model parts copy, Hendrickson 30ton. Well that's it for now be back soon.
Ron G
Hey guys
  I got the rear axle situation fixed and the front air suspension arms modified to fit around the trailer frame.
20210217_162321.jpgthis view shows the rear axle with the air brakes now on the correct side.:hsmack:duh!
20210217_162406.jpgthis view shows the center axle.
20210217_162425.jpgthis view shows the front axle and the modifications I had to make to the frame and the Moluminum parts so that they fit around the trailer frame.
20210217_162209.jpgthis view shows all of them.
20210217_162013.jpgthis view shows all of them with the wheels/tires added on.
20210217_161948.jpgview of the bottom if the trailer rear.
20210217_161753.jpgview from the top of the trailer rear.
20210217_161817.jpgside view of the rear of the trailer.
20210217_161452.jpgthis view shows the trailer sitting on my Kenworth W925 and the Cat 374FL on it for perspective. I ordered some more Moluminum air suspensions for the jeep and the stinger/booster, so until I receive them in the mail there on hold. well that's it for now be back with more updates soon.
Ron G
Wow, nice catch and excellent repair......I notice that on the brake pots there are no spring brakes? For parking.... I'm sure you know that and there is a plan afoot... Ron, your scratch building skills are incredibly good, I LOVE what you did to the suspension.... the low bed itself is spot on, bud... and looks WAY better with a shorter tractor....
Hey Jeff
 Spring brakes? Don't know what you mean can you post a picture or two?
Thanks Ron G
5 hours ago, CrankyCrafstman said:
Hey Jeff
Thanks Ron G
Sure, Ron, this is the type of spring brake chamber we have on ALL axles, except for the steering axle, so here in B.C. all drive axles on the tractor, and all the axles on the trailer and jeep and booster would have these brake chambers.... rather than the single  ones depicted on your trailer, those would be good for active braking only and there would be nothing to hold the trailer.
44 minutes ago, Jeff said:
So basically all you have on the trailer are 'service' brakes....
Got it, I have a fix, I still have the brake air chambers from the  Moluminum set up, I can make them work.
Ron G
Hey all
 Today was a lot of small tedious work. I mounted one side of the outriggers to the trailer frame. Cut the two long outrigger boards and I have all the deck boards cut and sized, but didn't get any pictures of those.
20210218_171641.jpgthis view shows the outriggers folded in.
20210218_171703.jpgthis view shows them folded out.
20210218_171724.jpgthis view shows the outrigger board in place. I wish the outriggers were printed in the white detail plastic, because in the fine detail resin/plastic they are VERY!!!! brittle, and the whole weight of the excavator will be sitting on them.:omg: well that's it for now be back with more soon.
Ron G
I was kind of hoping you would 3D print a bunch, I would buy some from you, glad you have a plan, I am looking forward to seeing this come together. The Mo'luminum stuff sure is nice eh? I like his stuff, I sure hope he casts the Holmes wrecker body.... that would be cool....
Hey Jeff
  I have the brakes fixed and plumbed. I also took some pictures of the trailer with the deck boards in place.
20210219_152311.jpgview from the side.
20210219_152228.jpgview of  the bottom. You can see the "tee" fittings that I added to the rear axle pivot brackets in order to connect the center brakes and the rear brakes to the air control valve.
20210219_152206.jpgview from the rear. This view shows how I added the Moluminum brake chambers to the ones I had on the axles already.
20210219_152056.jpgfront air valve.
20210219_152030.jpgrear air valve.
20210219_151955.jpgboth air tanks and connection pipe. I still need to add the supply and control lines.
20210219_152125.thumb.jpg.5074889cfe1234bd8a61fa566a734e37.jpgView from the top with the tires added.
20210219_153451.jpgthis view shows the deck boards in place.
20210219_153759.jpgthis view shows the deck boards and the outrigger boards added. Well that's it for now be back with more updates soon.
Ron G
wow, lookin good ,Ron..... make sure on your spring brake pots , you nip off the 'caging rod', or it's possible that you may still have no brakes at all on the trailer :rolleyes:
28 minutes ago, CrankyCrafstman said:
Thanks guys
 Jeff are you talking about the rods prtruding from the rear of the air chambers? If so how much should be sticking out?
Ron G
Yes, Ron that is what I was referring to, BUT ,Please .... this is YOUR model, and you build it as you see fit, I DO NOT want to come across as a 'rivet counter' or overly critical, what you are doing and building is nothing short of fabulous, and is spot on, I absolutely love this project , and you are nailing it......
