GazzaS Posted February 2, 2021 Posted February 2, 2021 This was done with a straight edge, can you believe it? There is just no room for my fingers to operate. When the line is out in the open I can fix and refix until I make a passable straight line. I need an idea to get over this hump... Anyone got one? 1 2
DocRob Posted February 2, 2021 Posted February 2, 2021 I use Dymo tape for these occasions. Cheers Rob 4
Bomber_County Posted February 2, 2021 Posted February 2, 2021 I use a flexible erasure shield, very thin stainless steel, was used on drawing boards...... 1 2
Spitfire Posted February 2, 2021 Posted February 2, 2021 Dymo tape for me also, plus Lion Roar scribing templates and Airwaves radius scribing templates, for the actual scribing I use a Bare Metal Scriber. I have also use the flexible Tamiya masking tape with some sucess. Cheers Dennis 2 1
Administrators Fran Posted February 2, 2021 Administrators Posted February 2, 2021 I have to do a master degree soon, as Im going to rescribe a 1:48 B-29. I have been using Dymo tape and some Scale Modelling Aircraft rule with some templates and a chinese (unbrand) scriber. Now, I got Hasegawa tools (several templates) and a scriber. I got them at a good price at www.sealmodel.com Fran 1
Bill_S Posted February 3, 2021 Posted February 3, 2021 What are you using as a scribe, Gaz? I got the UMM ones and I love them. I use dymond tape with them. 1
GazzaS Posted February 3, 2021 Author Posted February 3, 2021 18 hours ago, DocRob said: I use Dymo tape for these occasions. Cheers Rob 13 hours ago, Bomber_County said: I use a flexible erasure shield, very thin stainless steel, was used on drawing boards...... 8 hours ago, Spitfire said: Dymo tape for me also, plus Lion Roar scribing templates and Airwaves radius scribing templates, for the actual scribing I use a Bare Metal Scriber. I have also use the flexible Tamiya masking tape with some sucess. Cheers Dennis 1 hour ago, Bill_S said: What are you using as a scribe, Gaz? I got the UMM ones and I love them. I use dymond tape with them. Thank you for your replies everyone. I must have failed to make myself clear. I have all kinds of straight edges, flexible metal as well as Dymo tape and Tamiya flexible tape. I have an UMM scriber, razor saw blades, pin vise with needle. What I don't have is steady, or small hands. The proximity to the fuselage is kicking my ass. In open areas, I can fix and refix my faults as long as I have patience. I'm sure I'm not alone with this problem. There must be an answer. 2
BlrwestSiR Posted February 3, 2021 Posted February 3, 2021 I will often tape the metal ruler I have to the model. This keeps it in place and I don't have my fingers in the way. Also, are you using light passes with the scriber or doing a single heavy pass? Doing multiple light passes gives you better control if you're not doing that already. Otherwise, lasers? Carl 3
GazzaS Posted February 3, 2021 Author Posted February 3, 2021 6 hours ago, BlrwestSiR said: I will often tape the metal ruler I have to the model. This keeps it in place and I don't have my fingers in the way. Also, are you using light passes with the scriber or doing a single heavy pass? Doing multiple light passes gives you better control if you're not doing that already. Otherwise, lasers? Carl I guess I'm not really doing anything different from anyone else. Thank you for the help. 1
krow113 Posted February 4, 2021 Posted February 4, 2021 All I could add is physical suggestions. Secure the model some how , so you hands are free. Stabilize your forearms , lay them flat or somehow get them relaxed in a solid position. It takes 30-60 seconds to scribe that line, if ya gotta glue your arms to the table for that then ....what are you waiting for! 2
GazzaS Posted February 5, 2021 Author Posted February 5, 2021 On 2/4/2021 at 11:54 AM, krow113 said: All I could add is physical suggestions. Secure the model some how , so you hands are free. Stabilize your forearms , lay them flat or somehow get them relaxed in a solid position. It takes 30-60 seconds to scribe that line, if ya gotta glue your arms to the table for that then ....what are you waiting for! Those are great suggestions I hadn't hear before. Will give them a try. Thank you, 1
