Thank you friends for your kind support.  It has helped me get back to work on this project.  I was at an aimless point for the last couple days.  Here is the current status:
Wing control surfaces glued into place and wings nominally cleaned/filled/scribed.  I will check again with another coat of paint, soon.  But don't expect me to make any major fixes due to the recent revelations.
I've also added the tailwheel...   and made a toilet-tissue 'leather-boot' around the tailwheel oleo.
I used toilet paper and PVA glue to make the shape.  It needs to dry overnight.
I also assembled and partially attached the ETC 50 rack under the fuselage.  The pins don't fit snugly into place, so they are drying before I move on.
No Reichsluftverteidigung 109 would be complete without it's external drop tank.  On mine, I have used my Dremel to mill out sections of the inside so I can dent from the outside.  I used a 4mm engraver bit at 5k RPM until I could see the pink of my flesh through the plastic.  I have hit my fingers with the engraver before without bloodloss.
So...   in the future I must consider my Revell Bf 109G-10.  I've already bought AM for it.  What ever should I do?
Gaz
Right with Phil - nothing the kit can throw at you has kept you from overcoming the issues and moving on. You're mighty lucky no bleeding issues from the engraver hitting your finger. I know if it were me, it always turns into a medical mess 😷
  • Haha 2
Big progress on the 109 Gary.
Gorgeous work and I especially like how you imitated the leather cover of the tailwheel strut.
You are not the only one to have accidents with tools. I always have a box with sticking plaster close to my workbench…;)
9 hours ago, Bomber_County said:
Gaz, your tolerance to adversity is amazing …..looking very good indeed……and then you want a G10……..is that more pain?
Thank you, Phil.  "Want" is becoming a measurable term regarding these Revell kits.  I've already invested in it.  So it's either build it or sell it.
8 hours ago, Peterpools said:
Gaz
Peter, Fingertip skin is pretty thick, and the engraving bit is pretty benign.  I have a Dremel drill press which holds the tool in shape...  so the bit pushes me aside if we meet.
Thank you, Kai.  Yes, I've been pretty lucky.  Once, my knife rolled of the bench...  but it was a glancing slice that didn't produce much blood from the side of my foot.
Today was one of those days spent doing little things that results in looking like you've done nothing at all.  I assembled, dented, painted, and applied decals to the external fuel tank.  Unfortunately, in the process I burned a hole in it.
So, I plugged the hole with sprue and CA.  I'll show the drop tank again once it's weathered.
I also did some work getting the canopy ready for installation.  But there aren't any photos of the tiny little PE parts stuck in an ugly fashion to clear parts.  I do have my shame, after all.  Hopefully all of the ugly joins will be hidden by canopy framing.
The one thing I can show you photos of is the Revi reflector site fully installed.  Well...  I guess you get a bonus...  I've attached the rearmost portion of the canopy.
I don't know if I mentioned it....   but this will be an open canopy display.  As the pilot is nearby, at readiness...
I still have to fabricate his parachute...  which will end up sitting on the empennage where it could be grabbed quickly.
Happy modelling!
Maybe you don’t see much of the little  things you did at the end of a bench-session but in the end they make the difference.
The REVI looks amazing with the 2 glasses on. Even the mechanism for rising the second anti blending glass is visible.
Great detail work overall!
Curious to see how the finished drop-tank will look like!
Thank you, Kai.  As this is my fist time trying it...   I am curious how it will look, too.
These are the most important days in modelling, they are the foundation to cash in at the previous work the next day and have great results.
Like Kai said, the gunsight looks perfect.
Gaz
It's the details, as some might be so small, that raise the level of the build and added together, brings the model up to a whole new level. Gun sight looks amazing and even the yellow fuel plumbing on the cockpit wall adds to the over effect - everything works together so well. Fantastic work.
19 hours ago, Kaireckstadt said:
I found a parachute for you Gary:
It’s still available:
Kai
Thank you for the recommendation, Kai.  Is that a FW190 chute?  The description says backpack, while the 109 used a seat parachute.02bd0339e631607c3253737354551b7a.jpg.b5e88f91cbb6035008545503b62168cc.jpgWW-II-German-Aviation-Sitzfallschirm-MODEL-30-SEAT-PARACHUTE-Me109-Ju87-RARE-233910078963.thumb.jpg.b916e97150b9f3f563f1b04ee08e8b60.jpg
Though there is some resemblance.
I was just going to make mine with putty and aluminum foil.
Thank you!
16 hours ago, Peterpools said:
Gaz
Thank you!
I am really curious to see your scratched version!
Though I have some ideas, I'm curious about how it will look, too.  I want to think of how the man on the ground will have it placed, so that he can pick it up to place the straps over the pilots shoulders with a minimum of effort and messing around with crossed straps etc.  I don't want it to look like a bundle laying atop a Tintenfisch.
Hi Gary,
I have a cheap solution for your topic.
Master Box has a set of pilot figures in which one figure is included with a separate back-pack and one with a seat-parachute:
Backpack version
and the seat-parachute.
This should be a good basis for your parachute.
I used this set for my Ju-87G diorama. The figures are plastic (no resin) and beautifully detailed.
HTH
Kai
Thank you Kai, that is a great recommendation.  I just ordered a set.  I can use them on future builds as I already have a pilot for this one.  I started on the parachute last night.  I don't know how realistic it will look once finished.   But it is an interesting thing to try to make.
Well....    don;t say I didn't warn you.  I don't know that it will ever look like a leather and canvas creation...   Here is the basis of my construct.  A small piece of balsa wood trimmed and sanded to represent the casing and silk folds inside.
Now...  I don't have all of the things that would have been useful.  I didn't have any lead foil so I used masking tape to make the straps and cover the backpiece.  I also used a small piece of aluminum sheet to form the backpiece before it was encased in tape.
Now...  I built the entire thing, strap for strap.  And then I folded it in a way that I think it might have been laid on the tailplane.  Then I painted it.
There will have to be weathering to give shadows and shape to the straps.  But who knows what it will look like when done.
Another thing will be required...  Herr Weiroster's lawn chair:
I can fabricate it from balsa, wire, sheet, and maybe milliput.  Who knows.
17 hours ago, Bomber_County said:
I’d be very happy with it Gaz……..the lawn chair is going to be a tad more of a challenge….
OMG...   you're right!  I'm about ready to commit seppuku in frustration.  Balsa just isn't the answer.  Gonna see what BNA has in strip form.  I have some thin sheet...  but no way it is rigid enough to stay straight after cutting.
Great looking parachute Gary! No need to take one out of the set you ordered!
You are really taking the long way: Nice idea to scratch the chair too. Will be a stunning little diorama in the end!
Looking forward to seeing the next update!
Thank you, Kai.
I think Herr Weiroster deserves a full diorama...  at the least.  And the lounge chair was a common item to German pilots at readiness near their aircraft, so maybe there'll be a reason for future lounge chairs.
I had to order some styrene for the chair.  The materials I have here just won't work.
I have an E7, too.  Someday, I would like to remember these men at their game of Skat in plastic.
Messerschmitt-Bf-109E7Trop-2.JG27-Black-
Is it still played in Germany?  I have no idea how it's played.  The only card game I'm any good at is hearts.  I suck at poker.
Hey Gary,
I don’t want to :stirthepot: (well in fact, maybe a little :) ), but it seems Zoukei-Mura got the underbelly shape right on their future 109 …
Oh well, by the time it’s released, your scars from this one will have healed ;) …
Great work and admirable persistence :popcorn:
