JohnB Posted November 17, 2021 Posted November 17, 2021 Okay guys, this one is out of my comfort zone as I seldom build armor. I really like this version of the Sherman and this looks to be a very good kit so I think I will take the plunge. The main thing that puts me off is the tracks. As you can see, they are made up of a butt-load of small fiddly pieces that have to be assembled just right. I'm going to give it a try but am making no promises! LOL Maybe I should call this my "Out of my friggin' mind build!" We will see! (It's likely this will be one I work on from time to time.) 13
Peterpools Posted November 17, 2021 Posted November 17, 2021 John Holy cow - right out of left field and easily the unexpected. Nice change of pace and will be following all the way. Keep 'em comin Peter 4
JohnB Posted November 17, 2021 Author Posted November 17, 2021 6 minutes ago, Peterpools said: John Holy cow - right out of left field and easily the unexpected. Nice change of pace and will be following all the way. Keep 'em comin Peter LOL Agreed Peter! I'll work on this one along with a ZM Skyraider (whenever it shows up!). Two on the bench at the same time. 4
BlrwestSiR Posted November 17, 2021 Posted November 17, 2021 John, the tracks aren't that bad. They include a jig to help you get them together. I generally only used the bottom part of the jig and didn't bother with the upper half. I put a small drip of Tamiya Extra Thin in the locating hole on part F3 and then press F6 into place. Once you get started, you fall into a rhythm building them. One thing to remember. Leave F2 on the small runners until after you have the pads joined together. Hope that helps. Carl 5
JohnB Posted November 17, 2021 Author Posted November 17, 2021 39 minutes ago, BlrwestSiR said: John, the tracks aren't that bad. They include a jig to help you get them together. I generally only used the bottom part of the jig and didn't bother with the upper half. I put a small drip of Tamiya Extra Thin in the locating hole on part F3 and then press F6 into place. Once you get started, you fall into a rhythm building them. One thing to remember. Leave F2 on the small runners until after you have the pads joined together. Hope that helps. Carl Thanks for the info Carl! I'm sure it will be of help. 2
Bomber_County Posted November 17, 2021 Posted November 17, 2021 Yummy……John doing armour….we’re all here to support…..has this one got an interior? 2
JohnB Posted November 17, 2021 Author Posted November 17, 2021 9 hours ago, GazzaS said: Fantastic change, John! A change of pace Gaz. I haven't build a tank in years. 1
JohnB Posted November 17, 2021 Author Posted November 17, 2021 2 hours ago, Bomber_County said: Yummy……John doing armour….we’re all here to support…..has this one got an interior? Thanks Phil. No interior on this one. 😀 2
biggtim Posted November 17, 2021 Posted November 17, 2021 That's how I like my tanks - no interior. I love tanks, I just don't have the patience to build something I can't see. I have a Tamiya M4 Easy 8 half built, and a Dragon Early Tiger I, but can't seem to get back to them. I look forward to seeing this one come together, as I have not done an RFM kit yet. That Panther kit you have for sale is very tempting. Tim 3
JohnB Posted November 17, 2021 Author Posted November 17, 2021 34 minutes ago, biggtim said: That's how I like my tanks - no interior. I love tanks, I just don't have the patience to build something I can't see. I have a Tamiya M4 Easy 8 half built, and a Dragon Early Tiger I, but can't seem to get back to them. I look forward to seeing this one come together, as I have not done an RFM kit yet. That Panther kit you have for sale is very tempting. Tim Thanks Tim. The Panther is still available. 2
JohnB Posted November 17, 2021 Author Posted November 17, 2021 Instead of using the fiddly kit track parts I'm going to substitute vinyl tracks from a Tamiya M4A3E8. It looks like they will work okay and spare me the high cuss-factor of the RF tracks. Fingers crossed. 2 1
Peterpools Posted November 17, 2021 Posted November 17, 2021 John Fingers crossed the track switch works out Keep 'em comin Peter 2
JohnB Posted November 17, 2021 Author Posted November 17, 2021 10 minutes ago, Peterpools said: John Fingers crossed the track switch works out Keep 'em comin Peter Same here Peter! 2
Bomber_County Posted November 17, 2021 Posted November 17, 2021 John, it’s a good idea if the tracks are daunting, believe me I’ve walked away from many sessions of track building. The Tamiya band are probably the best out therein that format…….also if it means it’s not sent to to the SOD even better…… 3
JohnB Posted November 17, 2021 Author Posted November 17, 2021 16 minutes ago, Bomber_County said: John, it’s a good idea if the tracks are daunting, believe me I’ve walked away from many sessions of track building. The Tamiya band are probably the best out therein that format…….also if it means it’s not sent to to the SOD even better…… Agreed Phil!!! I bought a Tamiya kit on ebay earlier today so for now I can concentrate on other parts of the build. (It turns out I built a Tamiya one some years back. I had forgotten about it but it is in one of my cases.) 2
JohnB Posted November 17, 2021 Author Posted November 17, 2021 Just for grins, here's the Tamiya kit I built something like 20 years ago. (Now I might just put the RF kit on hold and turn to something else.) Click on the pics for best resolution and slide show. 7
biggtim Posted November 17, 2021 Posted November 17, 2021 3 hours ago, JohnB said: Thanks Tim. The Panther is still available. Stop tempting me, damn you! 1 3
BlrwestSiR Posted November 17, 2021 Posted November 17, 2021 For someone who says they don't do armour, that Sherman and base looks really good. Hope you change your mind and take a crack at the Sherman. As for the tracks, since the Sherman's have live tracks that are under tension, the rubber band style won't be that noticable. Saggy track like on a Tiger would be more obvious. Carl 3
JohnB Posted November 17, 2021 Author Posted November 17, 2021 8 minutes ago, BlrwestSiR said: For someone who says they don't do armour, that Sherman and base looks really good. Hope you change your mind and take a crack at the Sherman. As for the tracks, since the Sherman's have live tracks that are under tension, the rubber band style won't be that noticable. Saggy track like on a Tiger would be more obvious. Carl Thanks Carl! I went through it this AM and clipped off the MANY little molding tabs. I'll keep it on the bench to work on while I'm building the ZM Skyraider. A bit here and a bit there, etc. 3
Peterpools Posted November 17, 2021 Posted November 17, 2021 2 hours ago, JohnB said: Just for grins, here's the Tamiya kit I built something like 20 years ago. (Now I might just put the RF kit on hold and turn to something else.) Click on the pics for best resolution and slide show. John Holy Cow, awesome build for sure. Perfect weathering Keep 'em comin Peter 3
JohnB Posted November 17, 2021 Author Posted November 17, 2021 45 minutes ago, Peterpools said: John Holy Cow, awesome build for sure. Perfect weathering Keep 'em comin Peter Thank you Peter. It might could use a little more but I'll leave it as is. 3
GazzaS Posted November 18, 2021 Posted November 18, 2021 You should do more armor, John. That one looks great! And takes up a lot less space. 3
Bomber_County Posted November 18, 2021 Posted November 18, 2021 John, Gaz is right….more armour please……. 3
JohnB Posted November 18, 2021 Author Posted November 18, 2021 8 hours ago, GazzaS said: You should do more armor, John. That one looks great! And takes up a lot less space. Thanks Gaz. I just might do that as it would be a nice change of pace, etc. 3
