KevinM Posted January 25, 2023 Posted January 25, 2023 On 1/21/2023 at 11:08 AM, Sasha As said: Continuing work . "Double the Fun" looking good Sasha. 2 1
Sasha As Posted January 25, 2023 Author Posted January 25, 2023 28 minutes ago, KevinM said: "Double the Fun" looking good Sasha. Kevin thank you !!! 2
Sasha As Posted January 25, 2023 Author Posted January 25, 2023 Finished the cockpit work. Now everything is assembled and can be closed in the fuselages. 8 3
RockieYarwood Posted January 25, 2023 Posted January 25, 2023 Exquisite work on that cockpit Sasha! As an aside, I've always liked this photo, and think it would make a great vignette to display with an aircraft. Can anyone ID the make and model of the car? On 12/29/2022 at 9:07 AM, Sasha As said: Cheers, Rockie 3 2
Peterpools Posted January 25, 2023 Posted January 25, 2023 Sasha Awesome work on the front office - looks so good and your style of weathering and detail painting is simply exceptional. 3 1
Sasha As Posted January 25, 2023 Author Posted January 25, 2023 1 hour ago, RockieYarwood said: Exquisite work on that cockpit Sasha! As an aside, I've always liked this photo, and think it would make a great vignette to display with an aircraft. Can anyone ID the make and model of the car? Cheers, Rockie Rockie thank you! The diorama idea is really good! As for the car in the photo, most likely it's a Buick. 3 2
Sasha As Posted January 25, 2023 Author Posted January 25, 2023 1 hour ago, Peterpools said: Sasha Awesome work on the front office - looks so good and your style of weathering and detail paint is simply exceptional. Peter thank you so much for the review!!! 3
GazzaS Posted January 25, 2023 Posted January 25, 2023 Very sharp work on those interiors, Sasha. 4 1
Sasha As Posted January 26, 2023 Author Posted January 26, 2023 8 hours ago, GazzaS said: Very sharp work on those interiors, Sasha. GazzaS thank you ! 3
Sasha As Posted February 3, 2023 Author Posted February 3, 2023 After fitting and a little adjustment, I glued the fuselage to the wing. Given my misgivings, everything fell into place very well. I restored the strips and rivets. 7 1
Sasha As Posted February 4, 2023 Author Posted February 4, 2023 2 hours ago, RockieYarwood said: Nice progress, looks great. -R Rockie thank you ! 3
Peterpools Posted February 6, 2023 Posted February 6, 2023 Sasha Some mighty fine work - every part of the model fits perfectly. 2 1
Sasha As Posted February 11, 2023 Author Posted February 11, 2023 On 2/6/2023 at 3:52 PM, Peterpools said: Sasha Some mighty fine work - every part of the model fits perfectly. Peter thank you! 2
Sasha As Posted February 11, 2023 Author Posted February 11, 2023 I continue my work. That to understand the final result in the painting of the model started with the radar. It is easier to determine with further technique of painting and the general view. "Twinmustangs" were operated quite intensively in the early period of the Korean War and the first air victories belong to them. 7 1
Sasha As Posted February 11, 2023 Author Posted February 11, 2023 1 minute ago, harv said: Nice !.....harv 🤘 harv thank you ! 3
Martinnfb Posted February 11, 2023 Posted February 11, 2023 Absolutely stunning weathering and detail, museum quality. Sasha, did you use pencils for the chipping, or is it brush painted? Cheers Martin 1 1
Sasha As Posted February 11, 2023 Author Posted February 11, 2023 43 minutes ago, Martinnfb said: Absolutely stunning weathering and detail, museum quality. Sasha, did you use pencils for the chipping, or is it brush painted? Cheers Martin Martin thank you! Mixed technology application of operational traces. Starting with airbrush work with highlighting panels and hatches, then sponging where necessary with light and dark areas, brushing, and pencils. Zincchromate applied before the main paint, then masking oil paint areas where there will be chips, applying carefully with a sponge. After painting, I remove it with a cotton swab. 4 2
Peterpools Posted February 13, 2023 Posted February 13, 2023 Sasha Some mighty fine and realistic weathering on the radar assembly - looks spot on the money 2 1
Sasha As Posted February 13, 2023 Author Posted February 13, 2023 1 hour ago, Peterpools said: Sasha Some mighty fine and realistic weathering on the radar assembly - looks spot on the money Peter thank you! 1
Sasha As Posted February 13, 2023 Author Posted February 13, 2023 Primed the model. Before priming, I thoroughly abraded the surface with a foam based abrasive from 1500 to 3000. Added 60 gloss varnish to the primer, the surface should be extremely smooth with an excellent film on the surface before further painting. However, before that I had to remove the strange semicircles on the surface of the wings above and below (three per wing), on the fuselage they are almost not visible, but the same their traces are. Most likely something is wrong with the shape. 6 1
Sasha As Posted February 13, 2023 Author Posted February 13, 2023 3 minutes ago, harv said: Nice !!....harv harv thank you ! 2
