Gaz, are you using the kit gun covers, or the Eagle Editions part?   Somewhere, I KNOW I have Henri Dahne prop for this kit.
I can’t believe that after all these years, the only 190s I ever built were the long with 152H’s. 🤡
All OOB Ernie except for gun barrels and seat belts...   and a tailwheel winging it's way to me from Michigan.
Alright...   after the first round of HGW rivets.
All I can say about HGW rivets is that I am unable to get consistent results with them.  One panel will come out perfectly...   and it's mirror image will have floaties...   rivets that have drifted away from their allotted position.  But they are so fine...   that if you don't sand to make them show...   they won't be seen.  Here are some pics:
I still prefer them to the rivet wheel.
I amen that, to nearly all HGW products, I ever used. Wet transfers, masks and sometimes even the seatbelts need adjustment, special care and whatever it takes, but it's easy to bust with their products, like the wet transfers. I guess, the process is the same with the rivets, having a carrier film, later to be removed. To finish my rant about HGW-products, their masks rarely fit and some detail sets, I bought were partly unusable, like the paper wood inserts for the Hansa Brandenburg or their wood decals :wallbash:. The seatbelts, I do like mostly, but some needed extra trimming of the width for fiddling them through the buckles. I don't understand it with HGW, they do have a very interesting portfolio, but a bit more of testing would help to improve their quality.
Sorry for the rant Gary, your riveting job looks absolutely fantastic and I can't wait to see it under paint and maybe slightly sanded. I have  no idea, how the Eduard rivets behave, which I have for my P-38. They may be produced by HGW too. I will give them a try soon.
Thanks, Rob.  The worst thing about the rivets is they sometimes just float off.  It is even more likely to happen if you trim close to the rivet.  As a consequence, I leave at least 5mm between the rivets and the trimmed edge of the carrier film.  It's not like a decal where you want to get rid of the carrier film.  But it really makes it difficult to get the sheets to lay correctly if your extended edge happens to lay over a raised detail.  Removing the carrier film is a tedious process as well with this batch.  On the 109, the carrier film came off pretty easily.  But on this 190 it is a struggle.
Great rivet work Gary. Interesting to hear from you and Rob the inconsistencies you've both experienced.
I have the 109 set they included with their re-boxing of the Dragon kit but haven't built it yet.
One of those things we have to remember is that decals and transfers all have a shelf life.  Ten years down the road, I'll bet any of these sitting in the stash won't be usable.
Beautiful surface detail Gary. I hate to say it, but Hasegawa made a mistake by positioning the gunsight too back, protruding through the edge of the IP panel cover. Sorry man I didn't see that sooner, thought you knew about that.
On 6/28/2023 at 2:37 AM, KevinM said:
Well it looks quite Nice Gary!!:unworthy:
Thanks guys.  I should have known it.  But I forgot.  Because the pit of the 190 is so simple, I rarely even look at pics any more.  But now you put a bug up my a55.  I might have to do something about it.
Eh...    gonna leave it alone.
Smart and if our Boy Martin :rolleyes: hadn't said anything I never would of known.:hsmack::lol:
More HGW Rivets...   There's nothing else...   no cool painting tricks or fancy construction.  So, if ya don't like HGW rivets or the patterns on the 190...   have a great day!
Anyway...
           .....about HGW rivets....
                                           ....Working with them is like dating two women at once.  You don't want them accidentally bumping into each other.  So you have to work in segments.  The other day, I laid down the outer upper wing panels and 1/2 of the dorsal fuselage panel aft of the cockpit, as well as the port horizontal stabilizer panel.  So, that enabled me to do flanking panels over the guns and the flaps today.  There are a couple lessons learned here...
This panel over the MG's will have a lot of rivets showing when I am done.  It was a panel that was moved often, so beat-up, it will be.
If you follow the yellow lines you'll see rivets that look a bit rough.   This is what happens if you don't get them down fast enough.  They were on a narrow piece of carrier film, and ended up not looking so neat.
Another point you may have to deal with is working with a close, but not exact version of the aircraft you're building.  The rivet set if for the A8...   so, here at the blast troughs, some fixing will be required.
Speaking of fixing...   you'll notice the yellow dashed lines.  They are where an accident occurred.  After putting on a panel of rivets, I set the cowling down, and the carrier film must have been jarred, slightly moving the panel and pushing the rivet lines up a tiny fraction.  So, the remedy was to wet sand the out-of-place rivet line with 6k grit micro mesh.  Easy.  I'll just use a free line of rivets later.  I'll have to do the same process around the blast troughs.
Anyway...   thanks for looking!
😂 it's looking good Gary even if you are no longer of any sanity.:rolleyes:
Spent most of my time at the club meet painting this guy's uniform with acrylics yesterday.  Will do a pinwash later.
Thank you, Peter!  He was a good figure to paint.  But the more I look at him, I think he is greatly out of proportion.  A smallish head on a giant body with extra long legs.
Welcome back.  I'm ready to call the riveting done.
I probably could have omitted many of the rivet decals.  I don't want them all to show, and I did skip some.  The ones that will show will be in areas where the crew have frequented.  But I thought I would use a lot of the set anyway.
You'll notice a few spots where the paint has been removed in dots and odd places.  I reckon this comes from two causes.  A:   I sand it smooth and the paint may have been very thin.  And B:  The acids in Mr. Mark Softer ate through the thinned paint.  Of course, decals don't stay attached to places where paint has been removed.  Luckily it mostly happened on the underside.
Thanks for looking!
  • Confused 1
Seeing your progress with the rivets makes me wonder, if I should go that tedious route with my P-38. Anyway, the result is looking great and I cant wait to see them under paint. The figure looks fantastic, I especially like the slight gloss on the leather jacket.
It really depends on what your goals are, Rob.  I intend to only show the rivets in areas highly frequented by pilot and crew.  If they all show, it won't look right.  I'm leaning toward a Schlachtgruppen on the Ost Front.  I read a book by a pilot who was in such a unit, and he flew multiple missions every day, dawn till dark trying to provide support for the ground troops.  It sounded like their machines had little time for intense cleaning.
Thank you, Peter.  If it weren't for the extended drying times, it would be a breeze.
