DocRob Posted November 13, 2024 Author Posted November 13, 2024 16 hours ago, HubertB said: Getting progressively there, Rob. For the transparency, I would try either good’ol CA fog, or alternatively, stippling the blasted side with a hard brush dipped either in lacquer thinner or extra thin glue. I assume it is polystyrene ? 11 hours ago, BlrwestSiR said: Rob, try flat clear paint on the clear parts. If you use acrylic, if you don't like it you can strip it off. Otherwise, the suit is looking amazing. 11 hours ago, PanzerWomble said: Flat clear , maybe with 3% earth brown to give a faded frosty look . I do similar on vehicle windscreens for that minging look You'll only get one chance though . Muchas gracias for the suggestions, Hubert, Carl and PW. The clear parts are indeed polysyrene. I thought about using CA as well, but fear a not very controllable application. I will try thinner and matte clear on some spare parts. One side window should look blinded, the opened windshield only on the side, which calls for a faded effect. All will be followed by dust and sand deposits. Cheers Rob 4
DocRob Posted November 13, 2024 Author Posted November 13, 2024 After evaluating different methods on clear spare parts, I decided to use Tamiya Extra Thin for my sand blasted windows. I used the supplied brush nearly dry and applied the cement very carefully. This is only preliminary, to check the effect and more effects will be added, especially for the front window. Cheers Rob 9 1
belugawhaleman Posted November 13, 2024 Posted November 13, 2024 Looking great Rob! It looks like it went through hell....as for the driver R.I.P... Poor devil. BTW my Maschinen Krieger Camel Arrived today! 2 1
DocRob Posted November 13, 2024 Author Posted November 13, 2024 57 minutes ago, belugawhaleman said: Looking great Rob! It looks like it went through hell....as for the driver R.I.P... Poor devil. BTW my Maschinen Krieger Camel Arrived today! Thank you Paul, indeed, he hadn´t the easiest of times. Good to hear, that your Camel arrived. I ordered my Neuspotter and other items from Plaza Japan in the beginning of October and it still is a no show. Cheers Rob 3
CANicoll Posted November 14, 2024 Posted November 14, 2024 Rob, the sand effect is very cool and I'll have to keep that in mind. But despite the problems with the hairspray, I think your plan B looks AWESOME. The Metal looks perfectly worn. Also like what you did with the clear window - not sure I would have thought about using Tamiya Extra Thin like that but perfect effect. I was wondering if the glass would have been penetrated? Regardless, the total effect is terrific. You have a real talent. Love the look. 5 1
DocRob Posted November 15, 2024 Author Posted November 15, 2024 Thank you Chris, I´m blushing. I´m also lucky, that second effort worked better than the hairspray, which never failed me before. Suggestions for the window treatment came through some of our knowledgeful regulars and I tested the different methods on spare parts. The effect, I´m after is a sandblast through a storm, therefore the undoubtedly very robust windows of the Kampfanzug wouldn´t be penetrated, just blinded. Cheers Rob 4
DocRob Posted November 15, 2024 Author Posted November 15, 2024 Let me introduce you to this sinister looking drone. The Neuspotter is also based on a design Kow Yokoyama for the MaschinenKrieger universe. The kit was first issued by Nitto 40 years ago and my Wave boxing marks the 40th anniversary. Still it looks cooler and somehow more frightening than modern drones. I started with the sensor unit, which besides the strange colored plastic features coil springs, vinyl tube and different wire diameters for the numerous antennas. The age of the mouldings is visible, but everything fits as it should. I will quick build the Neuspotter and then decide, if I add him in my scenery. To get a better idea about how the Neuspotter looks, I add this illustration, which comes with the kit. Cheers Rob 6
DocRob Posted November 16, 2024 Author Posted November 16, 2024 The huge Neuspotter drone is nearly finished. Not shown on the pic are the antigrav unit and the exhaust nozzles, which will be added after painting. If I use the Neuspotter in my dio, I have to find a way to let it hover. I guess, I will use slide fit brass tubes for that, epoxied to the base and the drone. Cheers Rob 6
BlrwestSiR Posted November 16, 2024 Posted November 16, 2024 Definitely a mean looking drone there Rob. The red plastic is an interesting choice too. 3
HubertB Posted November 16, 2024 Posted November 16, 2024 If the front window was opened before the sand blasting took place, wouldn’t the inside wear effects of this (possibly on the opposite side to take into account the aerodynamic effect )? Mean looking drone. Reminds me of the drones in « The Empire strikes back » Hubert 4
belugawhaleman Posted November 16, 2024 Posted November 16, 2024 Cool! Lot's of possibilities there. How about a derelict drone, half buried, suggesting the figures had a final battle in which both were destroyed? BTW My other Ma.K kit came today, It's over in What did you get thread. It's the P.K.A Ausf HO from Wave. 2
DocRob Posted November 17, 2024 Author Posted November 17, 2024 15 hours ago, BlrwestSiR said: Definitely a mean looking drone there Rob. The red plastic is an interesting choice too. It looks somehow sinister with it´s long spindly probing arms. The plastic is a redish brown, maybe because one of the suggested paint schemes looks like red primer and when the kit hit the marked first, 40 years ago, not everybody painted the kits. The original kit had a tiny bulb included for lightening the front section, as well as the arms were mostly made from metal rods instead of plastic with mine. 13 hours ago, HubertB said: If the front window was opened before the sand blasting took place, wouldn’t the inside wear effects of this (possibly on the opposite side to take into account the aerodynamic effect )? Mean looking drone. Reminds me of the drones in « The Empire strikes back » Hmmh, aerodynamics, so many questions. When was the front window opened and by whom? Was it the then still living pilot or the drone? Was it one storm causing the sandblast or continuous wear? Was all that happening on earth or on some deserted planet with different conditions? Let´s wait, how the story unfolds, Hubert There are really some similarities to the drones used in the Empire Strikes Back, but the Neuspotter was a bit large for being used for interrogations in tiny cells inside the death star. 10 hours ago, belugawhaleman said: Cool! Lot's of possibilities there. How about a derelict drone, half buried, suggesting the figures had a final battle in which both were destroyed? BTW My other Ma.K kit came today, It's over in What did you get thread. It's the P.K.A Ausf HO from Wave. No Paul, there is another story behind it. The Neuspotter has no weapon systems, it would have needed a Krachenvogel for your scenario. BTW, I love the use of pseudo German names for many of the MaK subjects. These are no real words, but build from German parts of words. I always have to smile when I read them. Good find on the P.K.A., you will enjoy the build. My teenage favorite was always the Hornisse, a Kampfanzug with a hover jet attached. It was re-released by Wave some years ago and I definitely have to find one. Cheers Rob 3
PanzerWomble Posted November 18, 2024 Posted November 18, 2024 These are not real words, but built from German parts of words. I thinks that's known as Ersatzbabble ? My name is the same . 2
DocRob Posted November 18, 2024 Author Posted November 18, 2024 2 hours ago, PanzerWomble said: My name is the same . So you are also a Kow Yokoyama design, PW, hopefully in 1/1 scale . Cheers Rob 2
PanzerWomble Posted November 18, 2024 Posted November 18, 2024 I’m more of a plus size model these days 😉 4
DocRob Posted November 20, 2024 Author Posted November 20, 2024 My base will be "framed" by a plastic tub, which I sprayed in sand color. For the hovering drone, I added a threaded rod, epoxied onto the base and a nut also epoxied into the lower part of the Neuspotter. I hope, I can cover the rod with some dried grass later. I used it, because it allows to adjust the height of the drone over the surface as well as the angle, because the nut is not glued in in a right angle. The bowl was then filled with plaster of paris. Meanwhile, I primed the parts of the Neuspotter in black and white, black for the pure metal parts, like arms and exhausts and white for the rest. Cheers Rob 6
KevinM Posted November 20, 2024 Posted November 20, 2024 I missed the dust effects Rob came out really great thinking like others you found away to bypass plan A with plan B being all the better! 3 1
GusMac Posted November 20, 2024 Posted November 20, 2024 Nice idea for the base Rob. Should look great as the drone is an imposing size. 3
DocRob Posted November 21, 2024 Author Posted November 21, 2024 18 hours ago, KevinM said: I missed the dust effects Rob came out really great thinking like others you found away to bypass plan A with plan B being all the better! Thank you Kevin, I´m not the plan B kind, as usually my plan a is profound and if not, I often bin the project, because, it will not be like I desired. With the Kampfanzug, I thought, I give it a chance. Cheers Rob 3
DocRob Posted November 21, 2024 Author Posted November 21, 2024 16 hours ago, GusMac said: Nice idea for the base Rob. Should look great as the drone is an imposing size. Thank you Gus, I wanted to use mostly natural products for the base and searched the garden for fitting volcanic stones, which add to the strange sensation of the setting. I wanted to use beach sand, but our only sand colored beach is not accessible at the moment and the sand might have been too coarse anyway, as it´s only ground clam shells. I have a bag of fine sand here for decoration and a Mig paste for desert sand. Cheers Rob 3
Martinnfb Posted November 21, 2024 Posted November 21, 2024 Nice work Doc, very imaginative. Few motivational pictures to go with the theme 2 2
DocRob Posted November 21, 2024 Author Posted November 21, 2024 2 hours ago, Martinnfb said: Nice work Doc, very imaginative. Few motivational pictures to go with the theme Thanks Martin, you got it right. This dio will be about how weird technology fails to always save you. Cheers Rob 3
belugawhaleman Posted November 21, 2024 Posted November 21, 2024 3 hours ago, Martinnfb said: Nice work Doc, very imaginative. Few motivational pictures to go with the theme That first image... Was that an Ebay listing? Looks very familiar. Coincidence? 1
Martinnfb Posted November 21, 2024 Posted November 21, 2024 Paul, I believe that’s a part of some museum exposition. Just a bunch of random , creepy antique objects.
HubertB Posted November 21, 2024 Posted November 21, 2024 6 hours ago, Martinnfb said: Nice work Doc, very imaginative. Few motivational pictures to go with the theme When I was a kid in Elsass, I met an old doctor in his mid-seventies (he was the grandfather of a classmate). He was a pioneer in X-ray exams during his medical career. No wonder he finished blind when you see the contraptions of the time… these ones have definitely a German or Soviet feel to them 🥶 Hubert 1
