Wingco57 Posted January 1, 2016 Posted January 1, 2016 Hi all, Although this project has been started in the work in progress section recently, I thought it fitting to continue it here. For the previous work done, see here: http://forum.largescalemodeller.com/topic/4248-from-lancaster-to-manchester-a-tale-of-two-cities-lsm-exclusive/ I have been concentrating on the interior structure, which has almost be finished. the two oblong windows typical for the Manchester have been opened up carefully, which went surprisingly easy. Thankfully as some 18 or so more need to be opened up in the fuselage, and need to be uniform too. The skinpanels have been pencilled in before rescribing. Also have made a start converting the Lancaster tailfin into the shorter Manchester triple tail version. Hope you like. Cheers Cees
Administrators JeroenPeters Posted January 1, 2016 Administrators Posted January 1, 2016 Nice-ness! You know what you should do? Install small led lights in the interior.... While you're at it! 2
Thomas_Lund Posted January 1, 2016 Posted January 1, 2016 Jeeezzzz, I'm apprehensive about cutting up a 1/32 fighter, but you're cutting up a friggin Lancaster He he, extremely cool and a great idea - will look forward to following it
Administrators JayDee Posted January 1, 2016 Administrators Posted January 1, 2016 ...and the real crux here is that if he screws it, he can't go to the shop or HK for new parts! 1
Wingco57 Posted January 1, 2016 Author Posted January 1, 2016 Yes I can, but will have to wait six months hehe. I'm on a roll here and enjoying this kit immensely. Have been experimenting with rivetting the cockpitfloor. The Lanc used dome headed rivets in the fuselage and due to the greenhouse canopy will be very visible. Weathering will bring out the detail too later. using rosie the rivetter tool I got from Jeroen the panellines were recreated. Cheers Cees 2
Wingco57 Posted January 3, 2016 Author Posted January 3, 2016 Goodmorning, Made a start rescribing the panellines. Having pencilled them in first gives very good reference. Cees
Wingco57 Posted January 3, 2016 Author Posted January 3, 2016 another instalment, This will be an early triple tail manchester which had a span smaller than the Mk Ia and later Lancaster. So some more surgery was needed. the other tailfin was also shortened. The endplates need to be fitted to the tailplanes and the fins need an aerofoil sanded, but the basic Manchester tail is shaping up very well. Cheers Cees
Administrators JeroenPeters Posted January 3, 2016 Administrators Posted January 3, 2016 Sweetness! Question: Do you spray the mr surfacer on with your airbrush?
Wingco57 Posted January 3, 2016 Author Posted January 3, 2016 Hi Jeroen, this is still the grey paint HK Models sprayed the prototype with. Cees
Wingco57 Posted January 4, 2016 Author Posted January 4, 2016 Update, The tailfeathers have been set in place using tape with the central fin still a plastic card template. Shape of things to come. Also the elevators have been removed so these can be set at an angle. These still need detailing. Cees
crazypoet Posted January 5, 2016 Posted January 5, 2016 I love watching you work, particularly as you do wholesale changes from the original kit limits. You're an inspiration! 1
Wingco57 Posted January 5, 2016 Author Posted January 5, 2016 No I am just peculiar When my nose itches I use my elbows to scratch. Cees 1
Administrators JeroenPeters Posted January 5, 2016 Administrators Posted January 5, 2016 No I am just peculiar When my nose itches I use my elbows to scratch. Cees I can confirm that.
crazypoet Posted January 6, 2016 Posted January 6, 2016 So why am I not in the least surprised by this?
Wingco57 Posted January 6, 2016 Author Posted January 6, 2016 Thanks Fran, Before diving headfirst into cockpit detailing I decided to get the basic components roughly ready. The wingtips were removed from the outer wings. The wings themselves will be radically converted by reducing the span chord and taper of the outer wings. The aileron position need to be changed as well. Lust u nog peultjes? But that will come much later to preserve my sanity. I also managed to re-use the tailwheel fork and tyre. The latter had the anti-shimmy groove sanded off and the edges will be rounded off to create the earlier balloon tyre. (shimmy is similar to your shopping trolley where one wheel doesn't want to keep straight but keeps on spinning around its axis). Hope you like. Cheers Cees 2
GusMac Posted January 6, 2016 Posted January 6, 2016 Hi Cees, looking great. Can't imagine chopping up something like this without stressing so much about screwing it up. You're a brave man! As a pedantic physicist the proper name for the shimmy is precession and it is also a pain in the a**s with our hospital trolleys and wheelchairs! Cheers Gus 1
woody37 Posted January 7, 2016 Posted January 7, 2016 Hi Cees, Thanks for sorting out access, I can now finally post and say how inspirational your build is, the next best thing to seeing a real one! Can't believe how fast you're moving through it either, can't wait to see more 1
Wingco57 Posted January 7, 2016 Author Posted January 7, 2016 Thanks Neil, Good to see you here, your build on Britmodeller was the inspiration for this one. Working on seats and sofa's at the moment. Cheers Cees 1
Wingco57 Posted January 15, 2016 Author Posted January 15, 2016 Work is continuing with the tedious stuff, engraving the panellines. Using dymotape and a Tamiya scriber. Also noted that the bombbay was too short so cut that part out too. Have to stick that bit back on the bombdoors later. Cheers Cees 1
Wingco57 Posted January 17, 2016 Author Posted January 17, 2016 The main fuselage has been rescribed. Very pleased about the strakness of the lines. Note to self: mark out entrance door first before rescribing. Saves me some filling. Mr Surfacer will take care of that one. Glad that major bit is out if the way. Marking out the apples....errr windows next. Cees 1
