FME erk Posted May 8, 2019 Posted May 8, 2019 I am seriously considering building this as part of my (eventual) Lancaster dispersal diorama . . . I am gathering some pieces before I start and at the mo I am trying to source something that looks like transmission housing etc for the wheel drives. I'm relatively new to this scratch building despite having done a few other items for this planned diorama, OIL bowser & pneumatic trailer. I know it wont be perfect but it will look something like it should be but rivet counter accurate it wont be. I'll try my best. I will be sure to post here once I start 7
Martinnfb Posted May 8, 2019 Posted May 8, 2019 AEC makes one in 1/48 scale , that would be a good striating point to scale up stuff . Or to scale down AFW Matador ? useful handbook here :) EDIT: just noticed the box on your picture :), ops 2
Ryan Posted May 8, 2019 Posted May 8, 2019 Not to stifle your creativity, but AFV club make some nice Matadors in 35th, I wonder how noticeable it would be to use those. 4 1
Bomber_County Posted May 8, 2019 Posted May 8, 2019 Ryan, I was thinking the same. Thunder Models also do some cool Scammells......... 3
FME erk Posted May 8, 2019 Author Posted May 8, 2019 Thanks gents for pointing a few kits in my direction. Currently researching this particular AEC vehicle so it will be a while before I start, just finishing a Ford WOT crew bus. Many thanks Martin for the handbook link, it looks to be very helpful, cheers. I thought about the AFV kit(s) but there are only 4 wheels and transmission drive to the rear axle whereas I need potential 6/7 wheels and the associated axles and shafts for the two sets of rear axles. Can you obtain spares from AFV I wonder to expand it to a six-wheeler ?? Where are AFV ? I have built the 35th IBG Bedford QL so the scale isnt that imperative. I have scaled up the Airfix drawing to 32nd and cross reference with some old John Church drawings. As I stated earlier, I am new to this scratch building so would like to attempt it but I hope to find odds and sods that I can utilise. I am on the lookout for a ladder that was used to climb up onto the tank but I think I could build that reasonable well . . . . 4
FME erk Posted May 23, 2019 Author Posted May 23, 2019 I opted to purchase these kits in order to obtain a third axle along with the prop shaft and wheel/tyres should i decide to go 35th scale. I have the AEC 6w refueller plan(s) in both 32nd & 35th scale. In both cases I would have to build a tank and associated pump housing at the rear. I still fancy the 32nd scale as the cab is basically a box. I was unaware that you got TWO cab fronts and roof in each boxing of the kit so I can readily build a couple of vehicles in 35th (an RAF 3-tonner & 6w Crane). If I turn to the 32nd I would need to source something to represent three axles, drive transmission and prop shafts . . . anybody know of such for a WWII lorry ? Decisions to be made David 4
Ryan Posted May 23, 2019 Posted May 23, 2019 GMC 2-1/2 tonner will have 3 live axles. (Italeri, Tamiya...perhaps Heller) 5
Jeff Posted May 24, 2019 Posted May 24, 2019 On 5/23/2019 at 5:17 AM, Ryan said: GMC 2-1/2 tonner will have 3 live axles. (Italeri, Tamiya...perhaps Heller) Yeah, but doesn't the Duece have "Mack" style crown and pinion sections...... not conventional ones, the Mack Crown and pinion are horizontal, and the conventional is vertical.... second pic is a Matador rear end........ I know some of this stuff, after 38 years operating heavy iron, not trying to be difficult, just accurate... correct me on the Duece rear axle..... not an expert there...... 3
FME erk Posted May 24, 2019 Author Posted May 24, 2019 I think that is the axle off the front on the Matador. The drive is off-centre and I think that is the steering rack seen at the back in the photo . . . (I'm not an expert either ) 1
Jeff Posted May 24, 2019 Posted May 24, 2019 On 5/24/2019 at 7:13 AM, FME erk said: I think that is the axle off the front on the Matador. The drive is off-centre and I think that is the steering rack seen at the back in the photo . . . (I'm not an expert either ) Yes most likely, you are right, but I am wondering if the Matador has more of a conventional axle system..... 3 1
Jeff Posted May 24, 2019 Posted May 24, 2019 https://survivor79.smugmug.com/MILITARY-VEHICLES/MATADOR 3 1
Ryan Posted May 24, 2019 Posted May 24, 2019 You might try some 24th Scale big rig parts, these are usually littered all over eBay. 4
Jeff Posted May 24, 2019 Posted May 24, 2019 8 minutes ago, Ryan said: Yes I had not considered that. I'm not totally sure about that...................but it's fun to look...... for 1/25 scale stuff there is KFS in the UK, his stuff is unbelievable https://www.kitformservices.com 1 1
FME erk Posted May 26, 2019 Author Posted May 26, 2019 I shall be in receipt of the Heller GMC 2.5t kit very soon. I purchased it for the items mentioned above but If the axles are not wide enough I shall put it back on Ebay site. If they are, for the 32nd scale version, then I think I shall be running with them. I also looked at the KFS stuff and I particularly liked a couple of the WWII vehicles but then I am drifting away from the 32nd scale and who knows where I might end up ?? David 4
Bomber_County Posted May 26, 2019 Posted May 26, 2019 Here’s an idea, probably thought of it before, the old Airfix Refuelling set had a matador as part of assemble. Is scale-ing up an option? 4
FME erk Posted May 26, 2019 Author Posted May 26, 2019 Phil The Airfix Refueller Set plan, see the first post, in their instruction sheet is the only 'plan' I have seen of the AEC Matador refueller so to that end I have scaled it up to both 35th and 32nd scale. There is a noticeable difference in the two scales so I couldnt use the 35th AFV Club kit in parts for the 32nd build, sadly. I am rather hoping that the American GMC lorry has a wider axle in 35th than the AFV Club Matador of the same scale so that I could adapt it for the 32nd build ?. 4
FME erk Posted June 11, 2019 Author Posted June 11, 2019 THE GMC lorry wheels are not ideal so I shall press on with using the AFV kits. I've not been to well of late but I do intend to make a start pretty soon, I am having withdrawal symptoms I gotta make a start soon 3
Bomber_County Posted June 11, 2019 Posted June 11, 2019 Hope your on the road to recovery, bench time is always good I find..... 3
CrankyCrafstman Posted June 11, 2019 Posted June 11, 2019 6 hours ago, FME erk said: THE GMC lorry wheels are not ideal so I shall press on with using the AFV kits. I've not been to well of late but I do intend to make a start pretty soon, I am having withdrawal symptoms I gotta make a start soon Hey FME Try looking for one of these kits, they are 1/32 scale. I think they might fill your need. Ron G 5
FME erk Posted June 13, 2019 Author Posted June 13, 2019 Thanks Ron. I have never heard of that name so I shall start browsing to see what I can find 3
FME erk Posted June 26, 2019 Author Posted June 26, 2019 I have been doing a touch of research on this and I have made a tentative start. taken from the book for reference only, 'Taking the Rough with the Smooth', is this photograph upon which I shall base my model . . . Caption reads "The MK2 (model 0854) refueller had the diesel engine fitted. Visible on the roof are the runners for the sliding roof panel". Started with the chassis which needs to be extended and modified . . . On the 4 x 4 tractor unit I found it necessary to remove the top section of the chassis. I have only made this initial template for the tank . . . there will be five such for the tank A slight cheat perhaps but I enlarged the Airfix parts up to 1/35th to give me a better idea of sizes . . . I also did the same with the Airfix chassis and now I have received some Super Styrene 'C' section I can start cutting up the chassis and extend it . . . More to come David 4
Jeff Posted June 27, 2019 Posted June 27, 2019 Can't remember where I snagged these, and maybe you have seen them before if so sorry but if not, it may be of some help... very cool project, I'm really watching this.... Jeff 3 1
