18 hours ago, Ryan said:
Ok it’s a bulge.
It’s actually a bulge followed by a depression .... Having done this kind of mistake, it looks like some f#@%-up 3D design ...
Not sure if I'm going there, but I guess you could make some cross cuts in plastic from behind and glue some brass rod in to hold the shape.
Ryan
1 minute ago, Ryan said:
Or is the answer to reduce this part?
That looks more like the solution... if you reduce the bulge, you will more or less align the rear end of the fuse with the opposite end near the cockpit ...at least it looks like it.
Looking good Ryan. Did you check to see if you can get a different fuselage from Trumpeter? My F6F-3 isn't warped like that. It's fine except for the improper shape of the rear fuselage that everyone complains about.
Ron G
Well both side feature the problem, I think it’s in the mold.
Good news to report I can eliminate the depression and ease the bulge. The only pain was re drilling the rivets as I block sanded the fuse down. The deepest part of the depression was forced out with the handle of my razor saw. All this was done with sanding and bending.
Me too, the scheme will be GSB and was worried how the waist star would look with that wave.
Will see tomorrow if the bend held, if not I may need to make a bulkhead to hold the shape.
The funny part of this is I used a Trumpeter brand sanding block to finesse!
Ryan
It's definitely a moulding flaw. It's too perfect with regards to the rivet pattern not being distorted and it being in the same spot on both sides.
18 minutes ago, Ryan said:
I knew I wasn’t crazy!
Oh your crazy...just not about this......harv
Nice motivational pic from the back cover from the Maru Mechanic on this bird.
Definitely no bulge nor depression ;)
