1to1scale Posted February 25, 2020 Posted February 25, 2020 Well, I had planned on starting my F-117, but I actually am building a pair of Blackhawks for some pilots, and since they are going on deployment in a couple months, I’m moving these in front of the Nighthawk. I'm doing a OOB build without any PE, although I need to figure something out with seatbelts. I started dry fitting one bird, to see what needs fixing, and the passenger cabin is a terrible fit so far, I have had to attack it in anger with a 150 grit sanding stick already. 2 1
shark64 Posted February 26, 2020 Posted February 26, 2020 2 in a couple of months, sounds like you are going to be busy. 3
1to1scale Posted February 26, 2020 Author Posted February 26, 2020 Work started, the interior has “challenges”, so I am having to take up large gaps with styrene. 4 1
1to1scale Posted February 26, 2020 Author Posted February 26, 2020 6 hours ago, shark64 said: 2 in a couple of months, sounds like you are going to be busy. I am doing two, possibly 3. 3 is my limit for anything. 3
1to1scale Posted February 26, 2020 Author Posted February 26, 2020 Started poisoning myself with lacquers today, I mean painting...did I say poison? I also learned that 30 ml or MRP paint does not go as far as a bottle of a 10 ml Tamiya jar. 5 1
DocRob Posted February 27, 2020 Posted February 27, 2020 Nice work on the cabin floor. 10 hours ago, 1to1scale said: I also learned that 30 ml or MRP paint does not go as far as a bottle of a 10 ml Tamiya jar Never used MRP, but experienced the same using Alclads. These very liquid Colours seem to rush through the airbrush on the other hand they spray well and trouble free. Cheers Rob 3
1to1scale Posted February 27, 2020 Author Posted February 27, 2020 5 hours ago, Bomber_County said: Must do a helo one day Do yourself a favor, don’t build an academy one. Fit was so bad, I kept rereading the instructions to understand what was wrong. The cabin does not fit the fuselage, parts protrude that interfere, yet they serve a purpose, and you still have gaps all around in the doorways. Then things just don’t line up when you do get it together, and you need to sand 2mm off some parts just to get it close. (This is even in the Eduard PE instructions). 4
shark64 Posted February 28, 2020 Posted February 28, 2020 7 hours ago, 1to1scale said: Do yourself a favor, don’t build an academy one. Fit was so bad, I kept rereading the instructions to understand what was wrong. The cabin does not fit the fuselage, parts protrude that interfere, yet they serve a purpose, and you still have gaps all around in the doorways. Then things just don’t line up when you do get it together, and you need to sand 2mm off some parts just to get it close. (This is even in the Eduard PE instructions). yes a lot to fix but it is possible to turn out a decent model. 2
1to1scale Posted February 28, 2020 Author Posted February 28, 2020 8 hours ago, shark64 said: yes a lot to fix but it is possible to turn out a decent model. True, I turned down an opportunity to get a KH Blakhawk, now I wish I had one to compare. I don't build many Academy kits at all, so this is a first for me. But to be honest, not many manufacturers deliver Tamiya quality, so, you just have to deal with it, and do your best. 2
1to1scale Posted July 23, 2020 Author Posted July 23, 2020 This was a commission build, but the people backed out, so I am building it for myself. After finishing the A-7E, I decided to start working on this again. I collected a few bits and bobs like PE, a resin transmission, and a mask set. Back to it... 6
GazzaS Posted July 24, 2020 Posted July 24, 2020 I love when PE looks great like yours! Alas...mine never does. 4
DocRob Posted July 28, 2020 Posted July 28, 2020 That pit s looking great. The wear and tear is hinting, heavy used air tractor. Cheers Rob 3
1to1scale Posted July 28, 2020 Author Posted July 28, 2020 Thanks guys, since everything is 4 shades of black and dark gray, I had to use the flash....and it greatly exaggerated the pigment dust. I’m probably going to have to add detail to the collectives, as they look terrible as-is. 3
1to1scale Posted July 29, 2020 Author Posted July 29, 2020 I found this little gem on eBay, if I find them for sale again, I’m going to pick up two more. These fit perfect, no sanding, no flash, nothing, ready to install. 5
1to1scale Posted July 29, 2020 Author Posted July 29, 2020 Adding switches to the blank collectives, right side done. 4
1to1scale Posted July 30, 2020 Author Posted July 30, 2020 Looks like I need to do some touch ups still. I also got the rotor head assembled, not super accurate, but I tried to get the colors right...and the new resin transmission helps a lot. I researched the colors to make sure, but I have a few pictures that show the components are painted Helo Drab. Still need to weather it up. 3 1
1to1scale Posted August 1, 2020 Author Posted August 1, 2020 17 hours ago, Martinnfb said: Fantastic work. Thanks, this kit is a nightmare, poor fit and major misalignment everywhere. To top it off, academy has chosen to to as few alignment pins and tabs as possible. I have had to add quite a few extra alignment tabs myself. I almost feel like this is a vac kit. The gunner station support walls don’t come close to the fuselage in the rear, but butt up to it in the front, so I hade to make fabricated plastic sheet ends to mate it up. The seats are a study in fragile assembly. They could have made them 100% better by including pins instead of butt joints everywhere. And then, when you finally get the interior floor and ceiling glued together, you have hang the seats from little hooks in the ceiling and attach the fragile legs to the floor, to imaginary locating holes that don’t exist...at least not even close to where they should be. There is no way this will ever be a show entry, there is so much wrong that you have to cut your losses and just get it finished so the SOD has one less casualty. This kit has gone from fun to a challenge, the only thing keeping me going is that it will end up in the hands of a TN Guard pilot. ok, I’m done with my Saturday morning rant. 4
