Administrators JeroenPeters Posted December 29, 2020 Author Administrators Posted December 29, 2020 4 hours ago, Kaireckstadt said: That looks great, Jeroen! Your diorama is based on a photo I know of the Watson Whizzers capturing a single seat aircraft in Germany at the end of WWII, isn‘t it? Good Question! Yes and no. I know what photo you are referring to, but my inspiration came from a different photo. Namely this one. You can see a Willy's right next to the Do-335A-12 number 112, which I'm making. Oberpfaffenhofen had numerous Do-335's on it's field when found by the US Army. Both single seat and trainers. 3
Kaireckstadt Posted December 29, 2020 Posted December 29, 2020 3 hours ago, JeroenPeters said: Good Question! Yes and no. I know what photo you are referring to, but my inspiration came from a different photo. Namely this one. You can see a Willy's right next to the Do-335A-12 number 112, which I'm making. Oberpfaffenhofen had numerous Do-335's on it's field when found by the US Army. Both single seat and trainers. I‘ve never seen these pictures! Very interesting! Is „World War Photos“ a source in the internet? So your Twin-Seater will receive Natural metal cowlings for the front engine? This will be an eye-catcher together with the Jeep and the map they will be standing on! Where do you store all the Models you build? 2
Administrators JeroenPeters Posted December 30, 2020 Author Administrators Posted December 30, 2020 First markings sprayed on: 6
Administrators JeroenPeters Posted December 30, 2020 Author Administrators Posted December 30, 2020 7 1
krow113 Posted December 31, 2020 Posted December 31, 2020 Very nice! Looks like it was too late for the wire cutter on the jeep! 2 3
Administrators JeroenPeters Posted December 31, 2020 Author Administrators Posted December 31, 2020 More masking and spraying done. Now measuring out the kreuz that goes over the engine compartment. 9
levier Posted January 1, 2021 Posted January 1, 2021 That is looking most excellent. I spent a little time with NASM's A-0 "102" a few years back documenting the engine installations and cockpit. Truly a remarkable machine! You have rendered it well. 4
MattFoley Posted January 1, 2021 Posted January 1, 2021 Very nice work. I have been contemplating building the Zoukei Mura A 12. Is the HK series as accurate as the ZM? 4
Administrators JeroenPeters Posted January 1, 2021 Author Administrators Posted January 1, 2021 2 hours ago, MattFoley said: Very nice work. I have been contemplating building the Zoukei Mura A 12. Is the HK series as accurate as the ZM? Both kits are great. The HK kit has better fit and better after market options available. In terms of accuracy both kits are on the mark. Out of the box ZM might be better but there is hardly any after market available for it. 2 1
Administrators JeroenPeters Posted January 1, 2021 Author Administrators Posted January 1, 2021 More masking fun. 8
Administrators JeroenPeters Posted January 10, 2021 Author Administrators Posted January 10, 2021 Panel lines done witg a Mig black panel line wash. Matt varnish down. Now on to my favorite part: weathering. 8
Bomber_County Posted January 10, 2021 Posted January 10, 2021 Stunning Jeroen, do you gloss coat or Matt coat before doing the panel washes? I love weathering AFV’s, aircraft scare me....... 2
Bomber_County Posted January 10, 2021 Posted January 10, 2021 On 1/1/2021 at 5:08 PM, MattFoley said: Very nice work. I have been contemplating building the Zoukei Mura A 12. Is the HK series as accurate as the ZM? Matt......great to see new faces,............ 4
Kaireckstadt Posted January 10, 2021 Posted January 10, 2021 1 hour ago, JeroenPeters said: Panel lines done witg a Mig black panel line wash. Matt varnish down. Now on to my favorite part: weathering. That looks really stunning, Jeroen! Especially the fading of the panels looks very convincing. Lots of work to lighten up all the panels! Do you also have a picture from the bottom of the plane? Would be great to see! 2
Administrators JeroenPeters Posted January 10, 2021 Author Administrators Posted January 10, 2021 7 minutes ago, Kaireckstadt said: That looks really stunning, Jeroen! Especially the fading of the panels looks very convincing. Lots of work to lighten up all the panels! Do you also have a picture from the bottom of the plane? Would be great to see! Thnx! Here’s a pic in mid panel wash stage. The underside of this plane was bare aluminium. 5
Kaireckstadt Posted January 10, 2021 Posted January 10, 2021 12 minutes ago, JeroenPeters said: Thnx! Here’s a pic in mid panel wash stage. The underside of this plane was bare aluminium. Looks beautiful and perfectly shaded too! Is this Alclad or what did you use ? 3
Administrators JeroenPeters Posted January 10, 2021 Author Administrators Posted January 10, 2021 1 minute ago, Kaireckstadt said: Looks beautiful and perfectly shaded too! Is this Alclad or what did you use ? Yes, Alclad. Still much more shading and weathering to do.. 4
Administrators JeroenPeters Posted January 13, 2021 Author Administrators Posted January 13, 2021 Some fun with shaders 4
MattFoley Posted January 14, 2021 Posted January 14, 2021 14 hours ago, JeroenPeters said: Some fun with shaders Interesting. What's your opinion of them? These are airbrushed correct? 2
Kaireckstadt Posted January 14, 2021 Posted January 14, 2021 20 hours ago, JeroenPeters said: Some fun with shaders Looks very convincing to me 2
GusMac Posted January 14, 2021 Posted January 14, 2021 Nice result with the Shaders Jeroen. I tried them on my AMX-13 build but the effect is seen a lot more clearly on the metallic surface. 3
Administrators JeroenPeters Posted January 16, 2021 Author Administrators Posted January 16, 2021 On 1/14/2021 at 1:15 PM, MattFoley said: Interesting. What's your opinion of them? These are airbrushed correct? Yes they are but you need to spray at low pressure. Very lightly and build it up. 5 1
