Wondering i should even bother with the wheelwells. For one thing they are to shallow. All wrong......harv
On 2/6/2021 at 8:52 PM, Martinnfb said:
No glue ? :)
Challenge accepted Martin ! Here is the plan. The entire floor will be removed and a plank piece of card will be fitted. From there I will attempt to add a modified version of detail. I can't make it deeper because it will interfere with top wing and fuselage.  Any advice is more than welome....harv
That’s a lot of work to do, Harv!
Good idea to insert a plain sheet.
Another idea would be to use the upper wing as a floor for the wheel-well, but regarding the other problems that it causes it may be too much effort.
But it would make the building up of the details in it much easier because of the space for working.
Yes, but whats the fun in that ? Really though, I'm trying to stretch my skills. I'm liking the challenge..Besides Martin, when have you built anythingout OOB ?...harv
  • Haha 4
Guest krow113
Grind out the spurious lines.
That would provide a spurious base to begin some less spurious detailing.
A semi-decent compromise.
Good luck!
  • 4 weeks later...
2 hours ago, harv said:
Well, l think this is as far as I'll go with it. One side done....harv
Good idea to do it this way Harv!
Looks really good and convincing and is enough from my point of view!
Harv
just came across this thread and I do remember the kit when it was first issued. Will be following, enjoying your work as it.s a golden oldie from back in the day
Keep ‘em comin
Thanks Peter. Glad you stopped by. I'm happy you are enjoying it......harv
I'm calling the wheelwells done. Waiting for the engin that Bill was gracious enough to send.....harv
Great addition to the wheelwell Harv!
You can really call it done now!
Thanks to Bill, I now have an engine to play with . Kit on the left, Engin an Things on the right.  I won't need the back half....harv
Thats a good start with the engine.
Will be looking great when finished...
Stark contrast between the engines, eh? Looking good Harv...... how do you like those new cutters you bought a month or so ago? Have you had a chance to give them a go?
Thanks Jeff ! Haven't tried them yet. But I will on push tunes on the engine.....harv
Once you try them , I'm sure you will never go back to anything else....  lovin the progress on your work , Harv.....
