Kaireckstadt Posted June 21, 2022 Author Posted June 21, 2022 Thank you all for your feedback and sorry for the late reply. I’ve been at the 41st celebration of my Highschool exam (41st because of the Covid-restrictions last year) in my hometown in northern Germany. I will continue with the build next week. 1 1
Peterpools Posted June 21, 2022 Posted June 21, 2022 Kai Glad to see your doing well and the Highschool exam reunion was a nice bonus. 41 years ago, where does the time fly? Looking forward to your next build in a weeks time. Keep 'em comin Peter 1 1
Kaireckstadt Posted July 2, 2022 Author Posted July 2, 2022 Today I managed to paint and assemble the engines. Only painting of the compressor wheel and inner parts of the turbines necessary. I used AK Extreme Metal, Alclad II and Tamiya Weatherine Sets to achieve the results. This is how the original looks like: And my interpretation: Exhaust tubes: Impossible to remove these ejector-pinmarks. Luckily not visible when assembled. Afterburner-rings: Exhaust-nozzles from the inside: Turbine-wheel and afterburner-ring assembled: Compressor wheel assembled: Exhaust tube assembled: Next step now will be the assembly of the fuselage mid-section. 5 2
GazzaS Posted July 2, 2022 Posted July 2, 2022 Wow! Great looking afterburner, Kai! Looks like the real thing! 2
mark31 Posted July 3, 2022 Posted July 3, 2022 Looks great to me the exhausts Just a small heads up on the light set I have taken a good look on my set and iff i see it right the landing lights and taxi light are on at the same time. So far what i can tell is its taxi light on landing light off ore the otherway. Thats what i found in my references Keep up the great work 2
Peterpools Posted July 3, 2022 Posted July 3, 2022 2 hours ago, mark31 said: Looks great to me the exhausts Just a small heads up on the light set I have taken a good look on my set and iff i see it right the landing lights and taxi light are on at the same time. So far what i can tell is its taxi light on landing light off ore the otherway. Thats what i found in my references Keep up the great work Hi Mark Doesn't sound right that both the taxi and landing lights would be on at the same time or both off. 1
mark31 Posted July 4, 2022 Posted July 4, 2022 8 hours ago, Peterpools said: Hi Mark Doesn't sound right that both the taxi and landing lights would be on at the same time or both off. What i mean is landing lights on and taxi light off Taxi light on . Landing light off 1 1
Kaireckstadt Posted July 5, 2022 Author Posted July 5, 2022 Thank you all for your nice feedback. I investigated a little bit regarding the landing- and taxi-lights, Mark. They can be switched on separately by the crew. It depends on the rules of the wing where the aircraft is operated (at least valid for the Tornados of GAF Wings). In some wings the procedure is given to light both when taxiying to the runway (e.g. when it’s dark outside). Others have different procedures for ground operation. When in flight you are right: only landing-lights used. 1 1
mark31 Posted July 6, 2022 Posted July 6, 2022 18 hours ago, Kaireckstadt said: Thank you all for your nice feedback. I investigated a little bit regarding the landing- and taxi-lights, Mark. They can be switched on separately by the crew. It depends on the rules of the wing where the aircraft is operated (at least valid for the Tornados of GAF Wings). In some wings the procedure is given to light both when taxiying to the runway (e.g. when it’s dark outside). Others have different procedures for ground operation. When in flight you are right: only landing-lights used. thanks for that info Mark 3
Peterpools Posted July 6, 2022 Posted July 6, 2022 Kai Right with Mark .. always nice to learn more of procedures and ops, as it ads so much to the build. 1
Kaireckstadt Posted July 17, 2022 Author Posted July 17, 2022 IMG_9079.MOV IMG_9079.MOV IMG_9079.MOV IMG_9079.MOV Thank you Kevin! After a small pause I was able to continue with the build. Made greater progress with closing the fuselage rear, gluing the fuselage front to the rear, assembling the intakes and the preparing the thrust-reverser flaps. Gluing the fuselage front to the rear was a little more demanding since I had to integrate the platine with all plugs attached. I was very happy that the test of the electronics after the assembly was successful. Maintenance board my Interpretation Sensor on top of the fin (scratched because I lost mine during assembly) marriage of upper and lower part fit of fuselage front and rear not too bad The „cable salad“ in the fuselage intakes assembled. Tailerons not glued. Starts looking like a Tornado… intake from the inside IMG_9079.MOV Video of working lights assembled thrust-reverser flaps. Guiding sheets not glued because they are invisible after assembly in closed position. pencil marking on the lower parts for the painting process where heat-markings of the guiding sheets of the inside are visible thrust-reverser mechanism prepainted flaps with AK extreme metal steel Still some rework to be done on the underside… test fitting of the thrust-reverser-flaps ok rework of the panel behind the cockpit. Gap was too big. Now I can go on with the rework of the model: filling, sanding and rescribing. Not one of my favorite tasks…😉 4 1
Peterpools Posted July 17, 2022 Posted July 17, 2022 Kai Amazing progress - just so many individual details and parts you had to orchestrate and come together. Amazing work. And now add in again all the electronics ... a boat load of work successfully accomplished. 1 1
GazzaS Posted July 18, 2022 Posted July 18, 2022 Great update, Kai! Glad to see you're getting so much done. 2 1
Kaireckstadt Posted July 19, 2022 Author Posted July 19, 2022 On 7/17/2022 at 10:09 PM, Peterpools said: Kai Amazing progress - just so many individual details and parts you had to orchestrate and come together. Amazing work. And now add in again all the electronics ... a boat load of work successfully accomplished. Thank you Peter. Fitting of the front fuselage to the rear part with fit problems and the electronics to include was a demanding task. I’m happy that this is behind me now. 2
Kaireckstadt Posted July 19, 2022 Author Posted July 19, 2022 21 hours ago, GazzaS said: Great update, Kai! Glad to see you're getting so much done. Thank you Gary. I hope that I can keep the speed. Not as fast as John …😉 but I do my best… 3
mark31 Posted July 19, 2022 Posted July 19, 2022 wonderfull work. nice to see the lights working. Mark 3
Kaireckstadt Posted July 22, 2022 Author Posted July 22, 2022 On 7/19/2022 at 8:33 AM, mark31 said: wonderfull work. nice to see the lights working. Mark Thank you Mark. I‘m happy that all lights work after the assembly. No more chance now to correct without big effort. 2
Bomber_County Posted August 4, 2022 Posted August 4, 2022 Stunning Kai, I’ll show my brother in law as here spent 10 plus years working on these at RAF Leauchars 2
Kaireckstadt Posted August 6, 2022 Author Posted August 6, 2022 Thank you Carl. Interesting that your brother in law worked on Tornados. Curious to hear about his feedback! 1
Kaireckstadt Posted August 6, 2022 Author Posted August 6, 2022 The Tornado is in the rework station at the moment. That’s why I didn’t post an update here for a longer time. Also a bigger problem occurred when the LED in the left wingtip didn’t work anymore. Luckily I had 2 spares left over from the set which I didn’t use. I had to make a cutout on top of the wing as far as possible along panellines and remove the LED and solder the replacement one to the cables. I’m happy that the surgery worked and that the problem appeared already in this stage of the build. Now I have a another section with a bigger rework necessary. This is how it looks like: LED changed and cutout refitted cutout sanded and rescribing still to be done light working again. Will look more red in the end when the glass is also painted red. The underside of the wing. Position lights colored and glass added. HUD-light toned down with translucent green Thats it for today. Will post an update when all rework on the complete model is done. 2
Peterpools Posted August 6, 2022 Posted August 6, 2022 Kia Outstanding work and a modeler after my own heart - backtracking and re-doing what needs to be done. The replacement of the two in-op LEDS looks perfect and when you finish up with the re-scribe; perfect! Always seems to be something that might need a rework and sometimes it seems never ending. I try to pick a point of it's good and blends in well the build and call it a day. Looking so good . 1
Kaireckstadt Posted August 14, 2022 Author Posted August 14, 2022 Thank you Peter. I hope the Tonka won’t be a never ending story! 😉 So here is a small update: The rescribing process is ongoing and I’ve assembled the in-flight-refueling boom and 2 sensors at the front of the model: Today I will go on with the painting of the zones on top and bottom of the wing where the wing moves: This is necessary before gluing the housings at the wingroot. 2
