JohnB Posted April 15, 2023 Posted April 15, 2023 Revell Bf-109K-4 that I had started a while back but put on the SOD. Rescued and completed! Painted with MM, Mr. Color, Gloy and AeroModel. Belts are FineMolds. Cockpit, spinner/prop, and decals are EagleCals, etc. I'm glad to have finally finished this one and I hope y'all like it. 8 3
KevinM Posted April 15, 2023 Posted April 15, 2023 Did you have this delivered an pre-built?Excellent!! 1 2
JohnB Posted April 15, 2023 Author Posted April 15, 2023 2 hours ago, KevinM said: Did you have this delivered an pre-built?Excellent!! Not quite Kevin. 😐 1 1
Peterpools Posted April 15, 2023 Posted April 15, 2023 John Beautiful work and a spectacular finish - looks tremendous. 1
JohnB Posted April 15, 2023 Author Posted April 15, 2023 2 hours ago, GazzaS said: VEry nice, John! Glad you saved this one. Thank you Gaz. I am too!
JohnB Posted April 15, 2023 Author Posted April 15, 2023 1 hour ago, Peterpools said: John Beautiful work and a spectacular finish - looks tremendous. Thank you Peter. I'm pleased with the way it turned out.
PanzerWomble Posted April 16, 2023 Posted April 16, 2023 So compared to the ZM one , is there any comparison or is it just "Revell" ?
JohnB Posted April 16, 2023 Author Posted April 16, 2023 2 minutes ago, PanzerWomble said: So compared to the ZM one , is there any comparison or is it just "Revell" ? A much easier build with none of the headaches. I don't think it appears much different from the ZM except for the engine compartment. 1
PanzerWomble Posted April 16, 2023 Posted April 16, 2023 20 minutes ago, JohnB said: A much easier build with none of the headaches. I don't think it appears much different from the ZM except for the engine compartment. Thank you , so... the 109 is better than the Revell Spitfire ? I think you reckoned not much to that one ( apologies if it was someone else )
JohnB Posted April 16, 2023 Author Posted April 16, 2023 13 hours ago, PanzerWomble said: Thank you , so... the 109 is better than the Revell Spitfire ? I think you reckoned not much to that one ( apologies if it was someone else ) The Spitfire has fit problems.
Administrators Clunkmeister Posted April 16, 2023 Administrators Posted April 16, 2023 That looks quite decent, John. I was unsure of your paint choices, but it looks great 1
DocRob Posted April 16, 2023 Posted April 16, 2023 That one was worth the save John, the paintjob comes out particularly nice and super smooth. The Fine Mold belts look the part, seems like I have to give them a try, less tedious than HGW ones. Cheers Rob 1
JohnB Posted April 16, 2023 Author Posted April 16, 2023 11 hours ago, Clunkmeister said: That looks quite decent, John. I was unsure of your paint choices, but it looks great Thanks Ernie. I was a little unsure too but thought, WTF, give it a shot. Turned out pretty well I think.
JohnB Posted April 16, 2023 Author Posted April 16, 2023 5 hours ago, DocRob said: That one was worth the save John, the paintjob comes out particularly nice and super smooth. The Fine Mold belts look the part, seems like I have to give them a try, less tedious than HGW ones. Cheers Rob Thank you Rob. Those FineMolds belts can be tricky to use since they are hard to bend without breaking them. I found that holding them up to a hot incandescent light bulb with a pair of tweezers enables one to bend them to shape without breaking them (usually!). I nearly always use them since they are so much easier to use than threading buckles, etc through fabric/paper belts. 1 1
JohnB Posted April 16, 2023 Author Posted April 16, 2023 1 hour ago, Bomber_County said: Great save, flawless finish as ever… Thanks Phil!
