SH Whirlwind is next
13 minutes ago, Peterpools said:
John
You're sailing through the Whirlwind - looking mighty good.
I'll start on the landing gear today Peter. Hopefully I won't have the problems that you encountered. We will see! :)
2 hours ago, Peterpools said:
John
Hoping you sail right though it and the difficulties I encountered where my own doings.
I wouldn't say "sailing right through it" but enduring the process! Getting those gear parts together is a test of patience to say the least! Very high cuss-factor for sure.
29 minutes ago, Peterpools said:
John
These days and at our age, avoiding high cuss factor models should be mandatory. :wallbash:
Good idea Peter! We'd have to stick to Tamiya and Hasegawa. :)
What's happening John do the Churchill thing "never give up" ;)
Is it cracked? Or just a paint run? If it's only the paint, you can try using Tamiya lacquer thinner to remove it. Strip it back and then give it a polish with rubbing compound to remove the last of the residue and it should be good as new. I've done this a few times on canopy parts without any issues. But maybe test the plastic just in case.
No it's not cracked. I managed to get glue on the clear area when I was trying to attach the 2 rear "braces" (?). Both sides. I sent a email to the folks at Special Hobby so maybe they will send me a replacement. The front left side had a molding blemish right out of the box but I decided to work around it. Doesn't matter now.  Thanks anyway Carl. 🤪
1 hour ago, Spitfire said:
Hope Special Hobby come through for you because it is looking really good.
Dennis
Thanks Dennis! Me too! Until they do I will go on and use the messed up one. :)
