ScottsGT Posted August 16, 2023 Share Posted August 16, 2023 Well, I’m getting in deep building this and thought I’d post a few pics of what I’ve done. First off, Carl offered up a Fisher folded wing and I gratuitously jumped on that offer since the kits fixed wing’s airfoil is molded in upside down. Besides, always wanted to add a folded wing project to the display case. To start off, the very sparse cockpit wasn’t even wide enough to fit inside. I also cut the opening back about 3/16” and moved the headrest back as well. The wing arrived and I started carving away. Remember how the airfoil is upside down? That means the wing saddle is too flat for the Fisher wing to fit even after getting parts out of the way. This is after trimming everything. I filed the top of the wing some where it fits in the fuselage, but stopped when I realized I would be into the wheel wells if not careful. I built up the back of the “saddle” to fill the gap. In retrospect, I should have kept sanding into the fuselage just a little deeper. I was afraid if I went too far I would have ruined the only good kit parts that came in the box. Had a gap at the front I had to fill with Evergreen stock. Landing gear. Ugh….. Paul designed this wing correctly and even the Hobby Crap, err…Craft gear needed heavy modding. Way too short. I cut the receiver holes out of the kit wheel wells and glued them to the struts. 7 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 16, 2023 Author Share Posted August 16, 2023 Now I did forget to get pics of how I mounted the gear. I’ll try to explain. Once the glue set up overnight on the pieces I added from the wheel housing, I cut a slot in the top and glued in a strip of Evergreen stock that would fit into the receiver holes for Paul’s gear. Epoxied that assembly into the wing. 5 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 16, 2023 Author Share Posted August 16, 2023 Almost forgot, at the TE of the wing I had to cut the kits wing and make a filler. As you can see, wing is a little low in the back and I had to transition it into the fuselage. 5 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 16, 2023 Author Share Posted August 16, 2023 Another angle. 4 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 16, 2023 Author Share Posted August 16, 2023 9 Link to comment Share on other sites More sharing options...
KevinM Posted August 16, 2023 Share Posted August 16, 2023 Look's like a good representation of a Sea Fury is about to follow. 5 Link to comment Share on other sites More sharing options...
Peterpools Posted August 17, 2023 Share Posted August 17, 2023 Scott Way to go .. some mighty fine modeling. 2 1 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted August 17, 2023 Share Posted August 17, 2023 Lots of work there Scott. Great problem solving on making the gear fit. 3 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 17, 2023 Author Share Posted August 17, 2023 Thanks Carl. I was feeling a little cocky after making those Tamiya gear fit the Revell Tomcat. 4 Link to comment Share on other sites More sharing options...
Martinnfb Posted August 17, 2023 Share Posted August 17, 2023 Oh, I love this kind of butchery, she looks amazing Scott. 4 Link to comment Share on other sites More sharing options...
Landlubber Mike Posted August 17, 2023 Share Posted August 17, 2023 Great work Scott! 3 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 22, 2023 Author Share Posted August 22, 2023 Wow. Big difference between the kit canopy and the Squadron vacuum Tempest canopy. 3 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 22, 2023 Author Share Posted August 22, 2023 Of course I had to go ham fist it up and accidentally hit the wrong spot with sanding sticks. A little 2000 grit and some spit took them right out. But the vacuum material is harder to polish. Had to break out the Milwaukee tools! 4 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 22, 2023 Author Share Posted August 22, 2023 And the kit canopy is molded to fit the cutout for the fuselage opening. So I had to add stock to that and shape it. I like it! 6 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted August 22, 2023 Share Posted August 22, 2023 Big difference in the canopies that's for sure. Nice job getting it to work. Link to comment Share on other sites More sharing options...
Peterpools Posted August 22, 2023 Share Posted August 22, 2023 Scott Looking mighty good Link to comment Share on other sites More sharing options...
ScottsGT Posted August 22, 2023 Author Share Posted August 22, 2023 Thanks guys. I shot some primer on a few things this morning. I have a long way to go yet. Longer now that I’m seeing it in primer. 2 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 22, 2023 Author Share Posted August 22, 2023 Had to make up some underwing light lenses since I’m sure Carl needed his for his fixed wing build. LOL! Pulled out the circle cutter and used it on clear sheet plastic I had. Supposed to be almost pear shaped, but I’m going to have to settle for round. I used some .010 Evergreen to make a lip the lens can sit on. And off to fitting and gluing the inner gear doors. 9 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted August 23, 2023 Share Posted August 23, 2023 Scott, I didn't notice if there were lenses. So hopefully they're in the box or I'll need to make some too. 3 Link to comment Share on other sites More sharing options...
Bomber_County Posted August 24, 2023 Share Posted August 24, 2023 Scott, not a shake and bake then……….stunning modelling….. 2 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 24, 2023 Author Share Posted August 24, 2023 17 hours ago, BlrwestSiR said: Scott, I didn't notice if there were lenses. So hopefully they're in the box or I'll need to make some too. Look for a clear casting with these lenses and the wing tip lights along with the landing light on the wings LE. I’ve seen them in pics on reviews. Those goobers at Hobby Craft made the kit lenses on a regular gray sprue and not with the canopy. 1 1 1 Link to comment Share on other sites More sharing options...
ScottsGT Posted August 24, 2023 Author Share Posted August 24, 2023 Primer day! Got a few more boogers to smooth over then it looks like paint will follow soon. 7 Link to comment Share on other sites More sharing options...
Martinnfb Posted August 25, 2023 Share Posted August 25, 2023 Looking really good Scott. I like the correct orientation of the ailerons that correspondents with the fold up position. Nice! 4 Link to comment Share on other sites More sharing options...
Irishman1 Posted August 25, 2023 Share Posted August 25, 2023 Nice fabrication going on, what a challenge.. 4 Link to comment Share on other sites More sharing options...
Peterpools Posted August 25, 2023 Share Posted August 25, 2023 Scott Awesome work for sure and one tough build. Incredible how they screwed up the landing light lenses. 3 Link to comment Share on other sites More sharing options...
