polsen Posted February 4, 2016 Author Posted February 4, 2016 That's what my wife said "Ba-boom ching !"............. but thanks Ralph, yeah, hopefully I'll have less trouble with the Quickboost replacement. How's the P-51 going ? 1
Mish Posted February 24, 2016 Posted February 24, 2016 Just caught up with this one, excellent work Peter
polsen Posted February 25, 2016 Author Posted February 25, 2016 Thanks Mish, I'm working on the fitting the Quickboost cowl at the moment and it seems to be coming along nicely. Other than that life is a bitt demanding at the moment so sorry for the lack of updates. Cheers, Peter 1
Members Mikester Posted February 26, 2016 Members Posted February 26, 2016 Coming along nicely, Peter! The fit on my EagleParts upper cowl was so-so, and as you noted the detail is a little soft. Interested to see of you have the same issues with the QB part that Ralph encountered.
polsen Posted February 26, 2016 Author Posted February 26, 2016 Thanks Mikester, yes I've encountered most of the same fit issues as Ralph. In all honesty mine wasn't that bad really - just a few plastic strip shims with CA and accelerator then file, sand and polish where appropriate. I definately think the Quickboost part is the better solution if the Hasegawa cowl shape if it bothers you. I'll have to put some WIP pics up soon but I've run out of space with photobucket and I'm wondering if its worth switching to a different image hoster.....Can anyone recomend one? Peter
Wouter Posted March 1, 2016 Posted March 1, 2016 You could use imgur. As far as I know there's no picture limit.
polsen Posted May 24, 2016 Author Posted May 24, 2016 Hi folks, I must apologise for the lack of updates on this build, life throws you in the back seat a bit at times. I did get that cowl to fit BTW and its almost ready for paint. Thanks for your interest, Cheers, Pete. 3
polsen Posted June 10, 2016 Author Posted June 10, 2016 Cowl on ! It needed a bit of shimming and some filler but now It looks like it should fit the bill. DSC_0819 by Peter Olsen, on Flickr I used plastic strip to shim in the gaps and I attached them with CA glue and accelerator. Then, all that was needed was some careful sanding with a file and fine grit sandpaper to make the cowl fit perfectly. DSC_0818 by Peter Olsen, on Flickr I also purchased Quickboost's supercharger air scoop but it looks a little undersized so I'll stick with the kit one instead. DSC_0816 by Peter Olsen, on Flickr Thanks for looking, cheers, Peter 2
BevanBrooks Posted June 11, 2016 Posted June 11, 2016 Looking good Pete. Good to see some more progress. Cheers Bevan
kahunaminor Posted June 12, 2016 Posted June 12, 2016 Looking good Peter, Well worth the work in getting that cowl just right. Regards,
polsen Posted June 12, 2016 Author Posted June 12, 2016 Thanks guys for following along, I appreciate it. Things are pretty full on for me at the moment so bear with me, I'll update when I can. I just have to clean up a few more seams and random spots around the airframe, add a few missing rivets here and there; mask and attach the canopy and........ it will be ready for paint.
polsen Posted July 20, 2016 Author Posted July 20, 2016 Something to keep things rollin' along a bit. Painted with my own 'off black' mix of Tamiya and Gunze acrylics and weathered with Burnt Sienna and Lamp black artist oils. I also applied some highly thinned dustings of Tamiya Buff. quite simple wheely.........ah really. DSC_0841 by Peter Olsen, on Flickr DSC_0844 by Peter Olsen, on Flickr 4
BevanBrooks Posted July 26, 2016 Posted July 26, 2016 Come on Pete, hurry up and paint this bird lol. Scheme?
polsen Posted July 28, 2016 Author Posted July 28, 2016 Thanks guys. Sorry Bevan, you'll have to be patient, I've got a heck of alot going on at the moment. My scheme choice is "White 7" 1
polsen Posted August 4, 2017 Author Posted August 4, 2017 Hi folks, its been a while but I've got some paint on now. I chose " White 7" of JG 51 and my main inspiration was the black and white picture and the colour profile in the JaPo camouflage and marking book, page 361. I found it quite interesting that they suggested the possibility of a RLM 76/83 finish on the wing upper surfaces. looking at the existing photograph of this machine there is a small section of the upper wing surface that's visible along the leading edge. I'm not sure if its just the way the sunlight was hitting it or the way the photo turned out or the possibility of a high contrast scheme. While the Jerry Crandall book suggests 75/74 or 75/83 amongst other possibilities; I thought 76/83 would be quite a unique looking finish and since there is evidence of other FW 190 d-9's in these colours I decided to run with it. I used Gunze acrylics for all of the airframe airframe colours except for the mottling on the fuselage which was my own custom mix of Testors and Humbrol enamel paints. I find that I can get enamels to spray much finer then acrylics. DSC_1021 by Peter Olsen, on Flickr Here's a shot of the underside and you can see that I've started weathering in selected areas, whilst other panels such as forward of the wheel bay are still waiting to receive treatment. There is still a lot of work to be done and I haven't even started on the top side weathering yet. DSC_0844 by Peter Olsen, on Flickr Thanks for looking everyone, I would love to post some more pics but unfortunately for the time being I'm saving this model for publication. Actually, I'm in the process of writing my own book so all my techniques and info on this model will be available sometime in the future. I would love you to pick up a copy when its available. Ok, see you later ! Happy modelling, Cheers Peter. 8
Wingco57 Posted September 8, 2017 Posted September 8, 2017 Hi Peter, Sorry for the delay, but that paintwork looks fantastic, very realistic.
Administrators JeroenPeters Posted September 15, 2017 Administrators Posted September 15, 2017 Oh wow.... I missed this one but this is the bomb!! Lovely work..
Wumm Posted September 15, 2017 Posted September 15, 2017 Cracking paintwork and weathering Peter. Keep us posted as to publication details... S 1
polsen Posted October 9, 2017 Author Posted October 9, 2017 I'm waiting on some replacement parts as both my airbrushes are out of action plus I have alot on my plate at the moment but I'll update when I can. 3
Martinnfb Posted November 4, 2018 Posted November 4, 2018 Very impressive work, any updates ? Cheers Martin
