JohnB Posted September 18, 2018 Posted September 18, 2018 I've used Testor's tube glue for many years. The only gripe I have with it is it's so stringy. I've looked around on several suppliers sites for a alternative but haven't found anything that looks like a good replacement. Any suggestions? 2
Administrators Clunkmeister Posted September 19, 2018 Administrators Posted September 19, 2018 My gripe is when you open a new tube, half the contents ejects itself out of the tube. But I have no clue, other than thick CA, what would be a good alternative.
JohnB Posted September 19, 2018 Author Posted September 19, 2018 Thick CA is one thing I do use. I was hoping someone made a non-stringy polystyrene glue but I guess we'll have to be happy with Testor's stuff.
Administrators Clunkmeister Posted September 19, 2018 Administrators Posted September 19, 2018 I’m sure it exists, I just don’t know where.
Bill_S Posted September 19, 2018 Posted September 19, 2018 I gave up on tube glue long ago. Try the Testors glue in the black plastic bottle. It's thinner than the tube stuff, but works very well. A caveat, though - the tip likes to clog, and there's an internal plug that won't allow you to stick a needle all the into the reservoir. 3
Jeff Posted September 19, 2018 Posted September 19, 2018 John, I have some tube glue in my tool box, I've had for years, it is probably all dried up by now, but in my humble experience with it, and this goes way back, it was stringy, and also I thought it dried out some and parts used to fall off my models after a while... I use the Testors liquid stuff in the black squeeze bottle , you know the stuff, and I have had excellent results with that stuff, it is thicker than the liquid stuff in the bottle , but a tad thinner than the tube stuff. For a while Testors only packed it in the squeeze bottle with a crappy plastic applicator, now you can get it with a fine metal tube applicator again, I think it's great stuff........ just my 2c worth.... 4
Bill_S Posted September 19, 2018 Posted September 19, 2018 1 minute ago, Jeff said: John, I have some tube glue in my tool box, I've had for years, it is probably all dried up by now, but in my humble experience with it, and this goes way back, it was stringy, and also I thought it dried out some and parts used to fall off my models after a while... I use the Testors liquid stuff in the black squeeze bottle , you know the stuff, and I have had excellent results with that stuff, it is thicker than the liquid stuff in the bottle , but a tad thinner than the tube stuff. For a while Testors only packed it in the squeeze bottle with a crappy plastic applicator, now you can get it with a fine metal tube applicator again, I think it's great stuff........ just my 2c worth.... That's the stuff!
Jeff Posted September 19, 2018 Posted September 19, 2018 Yeah, that's what I thought you were talking about, I have had great success with it, but one must make sure the applicator part is the little metal tube not that gross plastic thing..... I use this pretty much exclusively and the liquid for long seams........................... works for me..... 1
JohnB Posted September 19, 2018 Author Posted September 19, 2018 14 hours ago, Bill_S said: I gave up on tube glue long ago. Try the Testors glue in the black plastic bottle. It's thinner than the tube stuff, but works very well. A caveat, though - the tip likes to clog, and there's an internal plug that won't allow you to stick a needle all the into the reservoir. Thanks Bill.
JohnB Posted September 19, 2018 Author Posted September 19, 2018 6 hours ago, Jeff said: John, I have some tube glue in my tool box, I've had for years, it is probably all dried up by now, but in my humble experience with it, and this goes way back, it was stringy, and also I thought it dried out some and parts used to fall off my models after a while... I use the Testors liquid stuff in the black squeeze bottle , you know the stuff, and I have had excellent results with that stuff, it is thicker than the liquid stuff in the bottle , but a tad thinner than the tube stuff. For a while Testors only packed it in the squeeze bottle with a crappy plastic applicator, now you can get it with a fine metal tube applicator again, I think it's great stuff........ just my 2c worth.... Thanks Jeff. I take a look at it. 1
JohnB Posted September 19, 2018 Author Posted September 19, 2018 I've decided to give this one a try. I've used IC Gel for a while but it looks like this might be just the ticket. 1
Jeff Posted September 19, 2018 Posted September 19, 2018 Stupid question time John... is that stuff 'regular ' tube glue? and if so, can you give me some details on it, I have never seen it before......
JohnB Posted September 19, 2018 Author Posted September 19, 2018 No it's CA gel. Scale Hobbyist has it. I think using it will be more convenient than the IC Gel I have used. It won't replace the Testor's tube glue though.
Jeff Posted September 20, 2018 Posted September 20, 2018 ok, thanks , John, I am not checked out on that stuff, may have to see about it.....
1to1scale Posted September 20, 2018 Posted September 20, 2018 you also have orange top Tamiya glue in a bottle with a brush applicator. 2
JohnB Posted September 20, 2018 Author Posted September 20, 2018 4 hours ago, 1to1scale said: you also have orange top Tamiya glue in a bottle with a brush applicator. Yes, I have some of that and it's good stuff.
Bomber_County Posted September 20, 2018 Posted September 20, 2018 Always use MEK these days but bought some Gorilla CA with integral brush plus screw top to keep it air tight. Very impressed...... 2
Peterpools Posted September 20, 2018 Posted September 20, 2018 Hi John Tube glue - use to love the stuff but it had to be the original Revell glue in the yellow and black tube. I have a tube of the Testors glue on my bench for years and just almost never use it. I do have to admit, when tube glue works well, you can't snap the pieces apart as you can with tamiya Extra Thin. But with good old government regulations the glues of our past, that worked beautifully are gone for good. Will be looking for your comments on the ZAP gel. Keep 'em comin Peter 2
