Hi all,
I've started on the cockpit pipework.
The pipe connections under the fuel tank.
Behind the instrument panel is the fuel valve manifold (made of micro-tube) connected to the pilot's four selectors. Two pipes out are for connecting the supply from the main and auxiliary fuel tanks.
From the bottom of the manifold will be the two supply pipes to the engines duel carburetor.
Electrical cables added to the rear faces of the starter magneto and ignition switch.
Mike
Hi all,
It might make it on the Great War SIG display.
The pilot's hand operated fuel pressure pump pipe is done.
Also the rear gun support frame and the instrument panel are fitted,
Mike
I love to see you guys detail interiors.  Hoping someday mine will catch up.
Nice work!
Gaz
Hi all,
A few more things added:
Fuel lines from the underside of the fuel tank to the fuel gallery behind the instrument panel.
Grease line from the pilot's 'screw down' pump to the engine mounted water pump.
Fuel drain line from the underside of the fuel tank to outside of the fuselage bottom.
Oil line from the oil tank (in the fuel tank) to the engine driven oil pump.
Now it's onto the wiring up the magnetos and adding the throttle and spark advance (ignition timing) controls,
Mike
Hi all,
Tachometer drive added from gun synchronization mechanism.
The two carburetor fuel feed pipes from the gallery behind the instrument panel,
The two machine gun trigger cables from the control column to the gun synchronization mechanism,
Mike
Mike, this is more than museum quality...................... so precise, what are you using for reference?? This is absolutely spectacular.....................
Thanks Jeff - I try :blink:
I use the internet and various publications:
Osprey Aircraft of the Aces - Fokker D.VII aces Part 1-2 (Norman Franks/Greg VanWyngarden).
Albatros Productions - Windsock - Data file No.9 - Fokker D.VII (P.M. Grosz).
Albatros Productions - Fokker D.VII Anthology 1, 2 and 3 (Ray Rimell).
Kagero Publishing - Fokker D.VII The Lethal Weapon (Tomasz J. Kowalski and Marek Rys).
Wingnut Wings - Instruction manual (Kit No.32027).
Windsock Modelling Special No.3 - Building the Fokker D.VII (Ray Rimell).
Various online resources (e.g. Wikipedia and the Aerodrome forum).
Albatros D.III - Osprey Publishing (James F. Miller).
Mike
Hi all,
'Spark Advance' control (Ignition Timing) fitted from cockpit lever to engine magnetos linkage rod.
Made from 0.3 mm brass tube, 0.1 mm Nickel-Silver rod and scratch link.
Mike
HOLY Rat Dung  ............... this is good..... I'm lovin this, and yes your resources are the good ones, I have some of them as well.....
Hi all,
Throttle control run added from pilot's throttle lever to the linkage on the dual carburettors.
Scratch made from 0.1 mm Nickel-Silver rod and 0.3 mm brass tube with the pivot lever created from 'spare' photo-etch,
Mike
Hi all,
Control cable for the hand operated throttle added.
Lead wire 0.2 mm diameter, from hand throttle on the control column, down and under the floor, up side frames and across the throttle quadrant.
Then down the other side, under the floor and back up to the hand throttle.
Mike
Hi all,
Generator lead and seat connector fitted.
Generators were not standard fit, but were installed to some aircraft to power heated flying suits later in WW1 and if carried, wireless transmitters.
Made from 0.4 mm diameter Nickel-Silver micro-tube and 0.148 mm diameter match line.
Mike
