Ok I got a little more done. I started on the interior walls and the floor. I also decided to cut out the two upper windows.
20191202_173352.jpgview showing upper windows and interior.
20191202_173523.jpgupper windows, they need a little refining.
20191202_173453.jpganother view of upper windows.
20191202_173307.jpginterior rear wall and floor.
20191202_173805.jpgfloor runs all the way to the firewall. I  still have some more stuff to add. Thats it for know.
Ron G
On 11/26/2019 at 5:24 PM, CrankyCrafstman said:
Small update
I got the motor and prop primed in black. I got the wing support struts made, I did use the large airfoil the small one looked wrong compared to photos of the real plane. I temporarily assembled it to see how big it is...its BIG! And I don't even have the floats on.
20191126_181407.jpgfront view showing the wing support struts in place
20191126_181333.jpgveiw showing the  tail planes.
20191126_175942.jpgcloser view of the engine and prop
20191126_112842.jpgI'm kind o leaning towards something like this for a paint scheme. What do you guys think?
Ron G
Hey Ron, so far an awesome build, but may I point out one little thing...
You got the prop rotating the wrong way. Pratts all rotate clockwise as seen from the cockpit, counter clockwise as seen from outside.
I hate to be a party pooper, man, but you should be able to fix it quick enough.
2 hours ago, CrankyCrafstman said:
Hey Ernie
 Yeah I know I noticed that just as I finished it. I'm just going to let it go for now. I my fix it later if I have time left over.
Ron G
Just say it’s powered by a British radial. :)
Hey all
I might be using this for the engine.
P&W R-985.pngIt all depends on how the 3D model will print. I'm going to try doing it in one piece and also in individual parts. I won't be doing the spark plug wires, oil cross-over tubes or the push rods. I will be adding those using ANYZ plugs and wires along with small Albion tubing. Not sure how I will be doing the oil cross-over tubes yet. So what do you think?  I did another post on making these in different scales and maybe selling them.
Ron G
I answered in your other thread. If you need the whole rear accessories design, I have done the design for 1/32.
Cool Hubert
 This model stops at the intake tubes and  intake manifold, no carburetor or accessories, also no exhaust.
 You know that there is an excellent R-985 in 1/32 scale in the Kittyhawk Kingfisher kit.
Ron G
Got a little more done. I started on the instrument panel, right now it's just the basic shape. I scratched up some rudder pedals, tgere not perfect but there the right shape. I did some work on the lower carburetor intake scoop. Here are some pics.
20191204_173708.jpgheres a shot through the pilots door.
20191204_173647.jpgshot through the starboard cargo door.
20191204_174011.jpgthese are the pedals and the instrument panel.
20191204_173803.jpgadded the vane in the center.
20191204_173608.jpgand a filter screen. Thats it for know.
Ron G
Just a little more accomplished. I got the Starboard side of the float support struts done. Here are some pictures.
20191205_155653.jpgThese are the float support struts. Port on the right and Starboard (modified) on the left.
20191205_160523.jpgPort support strut as it comes in the kit.
20191205_160542.jpgStarboard support strut modified. I used some 1/4" wide aluminum airfoil tubes for the front three supports and a piece of 1/8" diameter aluminum tube for the rear support strut. I used 1/8" x 1/8" plastic angle, rebent to the correct angle, for the steps. Every thing is held together with CA super glue.
20191205_160601.jpgHere they are attached to the fuselage.
20191205_160629.jpgclose-up of the front support.
20191205_160648.jpgClose-up of the rear support.
20191205_160708.jpgView showing them with the float attached.
20191205_162104.jpgFirst coat of grey primer.
20191205_162524.jpgHere's another view showing the support and float. Now I have to make the other side and rig them. All for now be back when I get some more done.
Ron G
Ron, I hope this helps, there is a ton of external structure on the Edo floats, and also here is the general rudder and attachment systems.............
2 hours ago, Anthony in NZ said:
Loving this Ron!  Awesome mods you are making...might try and locate one of these kits sometime.  You are inspiring me!
Hey Anthony
 There was one on Ebay, it was the white plastic one, same model just different plastic. It was going for $60.00 US plus shipping the last I saw it. If its still available GRAB IT! They are extremely rare.
Ron G
22 hours ago, CrankyCrafstman said:
Hey Anthony
Ron G
Thanks Ron, I couldn't find it, I am guessing someone beat me to it!  Quite fancy doing an RNZAF Antarctic Flight one on ski's.
Anyway, timing probably wasn't very good for me money-wise as I have just forked out a pile of dough on parts for my Auster rebuild.  I shall enjoy watching your beautiful work and hopefully one will turn up when I can afford it LOL
Cheers Anthony
Got a little more done. I started on the rudder and some more work on the tail planes. Here are some pictures.
20191207_151128.jpgI made the pivoting part of the tail planes.
20191207_151234.jpgAnother view showing the tail planes.
20191207_151359.jpgView showing the pivoting area of the tail planes.
20191207_170625.jpgHere's the rudder.
20191207_170754.jpgView of the rear of the plane.
20191207_171001.jpgSame view with the rudder attached.
20191207_171455.jpgSame view with the rudder and tail planes.
20191207_173335.jpgI also started the cutouts for the wing landing lights. I have to make clear covers for these. I have some lights from a 1/48 scale p-47 with lenses that I'm going to use for the landing lights, there just the right size to fit inside of the wing. Well that's all for know. Be back when I get some more done.
Ron G
Well, looks like that one went PDQ! And sadly the dehavilland dreams website ( the only source of this kit?) Is permanently saying "we'll be right back"....only they aint! A real shame. Wish I'd got one year's ago! Will have to be content with reading Your great build, Ron!
Blue Skies!
Captain Boogaloo
