Oliver
Just remarkable. Hopefully at some point you will have discovered all the hidden details needed for the diorama and then off to the paint shop.
How did you meeting go with the Armor builders on painting secrets?
4 hours ago, Peterpools said:
Oliver
Hi Pete
to be honest I am about done detailing this truck in my head.  Well, not so forth coming with secrets if you ask me so it's back to modeling books.  I have to buy a bit more primer paint I think.
Oliver
The amount of work you have done really shines in these photos. Sure hope you will find he books needed and then crank up the old air brush.
On 5/19/2023 at 11:07 AM, Axeman said:
Amazing detail as always.
Thanks Buddy.
I am working on adding the inside frame to the soft cover in the front. I am debating on adding the windows halfway down on the doors since the doors will be open (it requires a bit of work). The hood is not flush with the frame  and needs a bit of superglue work. Will post photos soon.
Oliver
Like you, I find the windows a bit odd myself.
I’d probably do one door with the window fully up. It would then clearly show that the other one is down, by modeller’s choice, and not mistake (as if you could do one ;) )
Oliver
I'm right with Hubert and the right-side door window just looks too odd and out of place. Both sides should be at the same height or one fully down and the other fully up.
The windshield frame attachment had to be recreated since the kit part was sanded off.  I am working on all the little details I missed during the build. The back wheels have no space between them so I have to created a small space in between to duplicate separation.
Remade the doors and added clear windows. I will need to paint the inside of the window frames before I glue the two halves together. Still need to detail the doos.
I think this is it in detailing. Finished remaking the review mirrors, it took few days to complete. I added wipers on the small windshield windows.  I am finally ready for primer.
 Oliver
