With the rapidly rising sun behind me I took some photos to bring out the detail of the build.  I hope you like them.
132169059_1084234248709982_3442179177060
131334418_1084234255376648_5902990181087
132049809_1084234262043314_1597581717165
131937317_1084234305376643_7576849288198
131935097_1084234315376642_1172860299373
131903138_1084234298709977_2314099651871
131540760_1084234362043304_6699727034614
131929860_1084234378709969_8162827213745
...more to come....
1 hour ago, HubertB said:
Not a shake-and-bake build, Gaz, but the result is really worth it.
:thumbsup2:
Thank you, Hubert!
1 hour ago, krow113 said:
Nicely done!
Thank you ,Steve!
19 hours ago, DocRob said:
Great result, love the modulation and the careful enhanced panel lines, you nailed it.
14 hours ago, 1to1scale said:
Love it! I like the way you have some life to the black paint!
12 hours ago, harv said:
Wow, so very well done  !! The color is perfect....harv
8 hours ago, Bomber_County said:
Gaz, congrats on a stunning build, the black really does sing.........
Thank you all!  I really appreciate the great compliments!  You've made my day!
Gaz
2 hours ago, Landlubber Mike said:
Nicely done!  I love the look of the Dorniers - I've been thinking about adding a 217 to the stash but love they way you built this one!
Thank you, Mike!  If you get one of the 217’s, check out Gaspatch Models for radar aerials.  ...if you’re not keen to make your own.
Thanks for the tip!  I didn't realize Gaspatch made them.  I have some Master Barrels Neptun radar sets for a couple of Me262 kits in the stash.  The Gaspatch ones look really nice though, wow.
The Gaspatch dipoles are the correct set for the Dornier.  I don't think any if them received the FuG 220 or later sets.  Just 202 and 212 which use the same aerial.
Do you happen to know if any of the Do 217 variants had the full glass nose and radar aerials?  I'd like to build one with the full glass nose, and also find those aerials really cool, but thus far haven't seen any with both.  Seems like the ones that carried the aerials had the closed lower nose.
*Edit*  Sorry, forgot you had built the 17, not the 217.  Getting all the variants confused.  I'm also looking at the Heinkel He 111 - so many cool options out there.
Oh...  I've built the 217.  The is an N2/R22
The only 1/48 variants I know of in styrene are the Revell E (long OOP), and two night fighter variants by ICM.  If there was a ship hunting variant of the E, it might have had some dipoles in places.  But I haven't thoroughly researched the bomber variants.   ICM recently released the J nightfighter.
Both kits feature plastic aerials, but they are overly chunky.
If you want a glass nose with aerials, I'm pretty sure you'll have to build a JU-88 or 188.  They have some pretty hefty aerial arrangements, though.  Do you solder?
Gaz
Thanks Gaz, and my apologies for taking up space on your log with all these questions.  I have a soldering gun but I haven't used it yet.
What did you think about the ICM kit?  I see you can get Revell/Pro Modeler kits which have lots of aftermarket (and allow you to convert the kit to different variants), but older tooling.  ICM is newer obviously and they seem to be rolling out a ton of variants.
Sorry to keep asking questions, but approximately how long/wide is the 217 in 1/48 scale?  I'm considering maybe dropping down to 1/72 as I already have some bigger kits in that scale (a couple of Pro Modeler Ju-52s and Eduard BF110s).
No need to apologize, Mike.  A forum is for communicating.
I like the ICM kit.  Goes together nicely and the detail is acceptable for scale.  The plastic gun barrels are a little weak, so I replace them with brass.  The wingspan of the 217 is 16 inches.  The 217 is all new molds.  Clear parts are very nice.  If I could pick out any fault in the 217 is that the fuselage seams need reinforcement as the body is pretty flexible.  I used evergreen sheet to beef up the fuselage seams.
Some day I'm hoping ICM releases either the 217K or M bombers.
Thanks for that!  I read a log earlier where someone was building both the Revell and ICM versions of the 217 (or could have been the He 111, I forget).  I think he said the details on the ICM were a bit soft on the interior as if they expected folks to add an Eduard PE kit to it, but otherwise he seemed to like the ICM kit.
I'll think more on it.  Have enough to keep me busy for a while.
