CrankyCrafstman Posted January 1, 2021 Posted January 1, 2021 Hey all I guess it's been a while since I posted anything. I started work on a 1/25 scale XL Specialized HD130 drop nose lowboy trailer. I have this modelled up on Unigraphics NX16 as seen in other posts. I my add some 3D printed stuff we'll see as I go along. This one is completely from scratch, so here are some pictures of where I'm at. I have the two main beams, all the braces and the gooseneck built. I used 5/8" 'I' beams for the main beams and 1/2" 'I' beams for the cross beams. I used 1/4" 'I' beams at the rear for the cross beams under the bucket well. I used 5/8" & 1/2" beams to make the rear frame. this thing is 36" long with the Kenworth 925 it will be a lot longer with the Peterbilt 359. I made the gooseneck from 1/16" thick flat stock and 0.03" x 1/4" strip stock, also I made the pivot from 3/8" down to 3/16" telescopic plastic tube from Evergreen plastics. The pivot pins are made from 1/8" plastic tube with copper lock pins. The part of the gooseneck that attaches to the trailer is made from 1/16" thick plastic stock and various sizes of 'I' beams. King pin is a piece of 1/8" aluminum tube. this is a side view of the gooseneck area. I have the trailer posed with my AMT Kenworth 925 for the gravel train for pictures only.this will be pared with my Revell Peterbilt 359 heavy haul tridem tractor. this view shows the rear of the trailer. Wheels & tires are from Moebius. this view is looking down at the gooseneck. I still have to make the front flip portion of the gooseneck, add all the lines, finish the lift cylinders, etc., etc.... This has changed a little from my original TrailerKing concept, it's now a XL Specialized HD130 with s 28' well. I plan on making a three axle 'jeep' for this also and possibly a three axle 'stinger' too! Need to order more wheels & tires. Well back to it, be back soon with more updates. Ron G 5 1
harv Posted January 1, 2021 Posted January 1, 2021 I was wondering what happened to this beautiful build!....harv 3
CrankyCrafstman Posted January 1, 2021 Author Posted January 1, 2021 Thanks guys I'll try to post some more pictures tomorrow showing more details. Ron G 3
Jeff Posted January 1, 2021 Posted January 1, 2021 12 hours ago, harv said: I was wondering what happened to this beautiful build!....harv I was too, in fact I was going to ask the other day and got busy................ VERY Impressed , Ron , VERY ! 2
CrankyCrafstman Posted January 2, 2021 Author Posted January 2, 2021 Hey all I have done some more work on the gooseneck. I added the front flip extension and all the pins. this view shows the front flip extension, flip extension upper pivot pins and lower lock pins. this view shows the main gooseneck pivot pin and how the gooseneck base attaches to the front of the trailer. this view shows the front flip extension pivot and lock pins. You can just see the two king pins on the bottom side. this view shows the flip extension flipped up. another view of the front flip extension in the flipped position. another view of the front flip extension. Here are some more pictures of the trailer and all the individual parts. this view shows the drivers side main pivot pin & lock pin. this view shows the gooseneck in the down position and flip extension flipped up. this view shows the attachment pins for the gooseneck to the trailer. You can just see the locking cylinder. this is the whole gooseneck and the main pivot pins. this close up view shows the main pivot pins. this view shows the rear of the gooseneck and the locking cylinder. another view of the gooseneck base. front view of the gooseneck base. front view of the trailer gooseneck attachment area. another view of the gooseneck attachment area. bottom view of the gooseneck attachment area. Here are some pictures of the rear of the trailer. this view shows the 1/4" 'H' beam cross braces. this view shows the transition from the 5/8" 'I' beam to the 1/2" 'I' beam to make the rear of the trailer frame. this view shows the excavator bucket well. this view shows the 1/2" 'I' beam cross braces. this view shows the gooseneck base and locking cylinder area. I started on the hydraulic lift cylinders, I have one done need to make the other one. this view shows one of the lift cylinders, I need to replace the brass tube with an aluminum one. this view shows the cylinder with a 1/24 scale (ruler) for comparison proposes. Here are some pictures of a 1/50 scale diecast Kenworth t880 truck, XL Specialized 130 HD trailer, jeep, stinger and Cat D10T2 dozer. this view shows the complete set up, you can see my scratch built trailer in the background, it's as long as the whole set up...lol Kenworth T880 tridem tractor. 3 axle custom jeep. Cat D10T2 dozer and 130 xl hd trailer. 3 axle custom nitrogen stinger. This is what I'm going to be trying to make in 1/25 scale. Well that's it for now be back with more soon. Ron G 3 1
CrankyCrafstman Posted January 3, 2021 Author Posted January 3, 2021 Hey all Just a small update, I have the lift cylinders done now. I started on the outer trailer frame, deck boards, outriggers and "D" rings...etc. this view shows the main lift cylinders, and you can see the outer deck rail. view looking down at the lift cylinders and beginnings of the deck. Thats it for now be back with more soon Ron G 4
CrankyCrafstman Posted January 3, 2021 Author Posted January 3, 2021 Thanks Harv There's still a whole lot to do yet. Ron G 1 1
RichO Posted January 3, 2021 Posted January 3, 2021 This is some really great stuff here. Scratch building with many tires!! I love it. Hurry up with more photos........ 1
CrankyCrafstman Posted January 5, 2021 Author Posted January 5, 2021 Hey all Got more done on the lowboy trailer. side view showing the lowboy trailer and my Kenworth W925. top down view of the trailer. this view shows the rear of the trailer. The yellower white plastic is from the AMT lowboy trailer kit modified to fit. side view of the rear area of the trailer showing the AMT parts added on. rear view of the trailer showing the tail light area. Still need to do more work on this. top down view of the trailer bed. I ran out of 1/2" 'I' beams, need to go to the hobby store for more. It's getting there but still alot more needs to be done. Well that's it for now be back soon with more updates. Ron G 5 1
FME erk Posted January 5, 2021 Posted January 5, 2021 Unbelievable work so far Ron . . . . and all from scratch 2
CrankyCrafstman Posted January 5, 2021 Author Posted January 5, 2021 Well, almost all scratch built, I purchased the wheels and tires from Moebius...lol Ron G 3
CrankyCrafstman Posted January 9, 2021 Author Posted January 9, 2021 Hey all I got some more work done on the trailer. I've been working on the suspension, axles and brakes. this view shows the three axles sitting in place. this view shows the rear axle that I made from parts of the AMT lowboy kit and some plastic tube and card stock. here is another view of the rear axle. bottom view of the rear axle. I'm not really satisfied with this, so I think I'm going to replace it with som 3D printed ones I ordered from Shapways. this view shows the 3D printed axle set up. this view shows the actual 3D printed part. I'm really hoping that these work out ok. We'll see when they get here in a week. I have also been working on the hydraulic power pack set up. It will consist of a hydraulic tank (scratch built), a hydraulic pump (also scratch built) and a 3D printed 13hp Honda engine. this view shows the 3D printed Honda engine. thisi s what I'm talking about. another view of the power pack. Well that's it for now be back with more updates soon. Ron G 3 1
CrankyCrafstman Posted January 10, 2021 Author Posted January 10, 2021 Hey all Thanks for the comments. I did a little work on my Revell Peterbilt 359 custom heavy haul tractor. I have the wheels/tires pretty much done, ready for paint. I temporarily put it together to see how it fits with the lowboy trailer. here it is with my AMT D8H dozer. I think it looks assume together. What do you guys think? close up view of the tractor. closer view of the D8H dozer. view looking down on the D8H and trailer. Well that's it for now be back soon. Ron G 4 1
CrankyCrafstman Posted January 11, 2021 Author Posted January 11, 2021 Hey Jeff Yeah, wait till I add the jeep and booster(stinger) Ron G 1 1
HubertB Posted January 11, 2021 Posted January 11, 2021 Extremely neat scratchbuilding ! That really makes for a looooooooooooonnnnnnnnnnnnnnnnnng road train ! Hubert 2
Jeff Posted January 11, 2021 Posted January 11, 2021 10 hours ago, CrankyCrafstman said: Hey Jeff Yeah, wait till I add the jeep and booster(stinger) Ron G And , I meant NO disrespect by the way, it just struck me as wow what a LOOOOOONNNGG unit it will be , and if it were for real, it would probably be restricted by permit here in B.C. as to where it could go, mostly due to our curvy roads...., but we do have tridem Low Beds, with tridrive tractors with Jeeps and boosters as well, just our tractors aren't any where near as long as your model tractor, I think that is where the length shows most... are you going for the 53 foot low bed? . and my hat is off and I bow to your incredible scratch building skills, my friend.... I am enjoying every update, and it is looking every bit the part...... 1
