DocRob Posted April 7, 2022 Posted April 7, 2022 Very nice painting result Carl and the masks have worked very well. I really want to start mine soon, but there is still some wood to chuck first. Actually, I will add the Special Hobby 48 scale in Spanish livery to my stash, as I like the Cobra in dark blue with Spanish insignia. Cheers Rob 3 1
BlrwestSiR Posted April 9, 2022 Author Posted April 9, 2022 Thanks Rob! I'm quite happy with the results. I started on the decals. They're working out nicely. The ones on the tail have gone over the rivets nicely with a couple applications of Mr Mark Softer. That being said, I'm thinking of masking and painting the shark mouth. There's just too many different shapes to cover with it if I use the decals. 6
Martinnfb Posted April 10, 2022 Posted April 10, 2022 Are we there yet? :), OK this was rather fast Carl, lovely attention to detail 1 2
Drifter Posted April 13, 2022 Posted April 13, 2022 Superb work. Hopefully I can get my Mojo back now that my life is slowly coming back together again. 2 1
BlrwestSiR Posted April 13, 2022 Author Posted April 13, 2022 On 4/10/2022 at 3:21 PM, Martinnfb said: Are we there yet? :), OK this was rather fast Carl, lovely attention to detail It really had been a quick build. I'm going to get back to it tonight and see how much more I can get done. 1
BlrwestSiR Posted April 13, 2022 Author Posted April 13, 2022 2 hours ago, Drifter said: Superb work. Hopefully I can get my Mojo back now that my life is slowly coming back together again. Thanks! Hope you find it and get back to thehe bench. 1
BlrwestSiR Posted April 15, 2022 Author Posted April 15, 2022 (edited) Jimmy's been needing some extra attention since his operation so haven't been down to the bench like I hoped. I did get the main rotor blades glued together so maybe later today I'll be able to get those into paint and have something to show. Edited April 15, 2022 by BlrwestSiR Fix typo 3
BlrwestSiR Posted April 15, 2022 Author Posted April 15, 2022 As mentioned, not much time at the bench but enough to make some progress. The rotor blades were cleaned up and prepped for paint. Same with the tailplanes, tail rotor and the rotor head. After a coat of white primer, I sprayed red and yellow as required. Once they're dry, I'll move onto the black. 4
KevinM Posted April 16, 2022 Posted April 16, 2022 On 4/13/2022 at 3:24 PM, BlrwestSiR said: It really had been a quick build. When it's an ICM kit it seems to happen on it's own makes building fun.The Cobra is looking Suuuper SeSweeet!! 2 1
BlrwestSiR Posted April 16, 2022 Author Posted April 16, 2022 I got the rotor blades painted. I then assembled them onto the main shaft so that's all done. So why is it on helos they're called rotors and on a plane they're propellers? Anyways, shark mouth time. I wasn't too keep on applying the kit decals for the shark mouth so I tried making masks the old fashioned way. I photocopied the decal sheet and laid a piece of kabuki tape over it. After tracing the shark mouth onto the tape I cut it out and applied it to the model. I then sprayed AK primer in white onto the shark mouth. Once that's dry, I'll cut a mask for the teeth, mask those off and spray the red. 6
JohnB Posted April 16, 2022 Posted April 16, 2022 Nice attention to detail Carl! Gonna be a beauty! 2 1
BlrwestSiR Posted April 17, 2022 Author Posted April 17, 2022 Thanks John! This kit is going together very nicely.
BlrwestSiR Posted April 17, 2022 Author Posted April 17, 2022 I got the red onto the shark mouth. First I traced and copied the shark teeth. The turret has some too. Then I hit it with the red. Moment of truth. 6 3
DocRob Posted April 17, 2022 Posted April 17, 2022 Some very nice extra work, which paid really off. Cheers Rob 2 1
Bomber_County Posted April 18, 2022 Posted April 18, 2022 Carl, this build almost passed me by, stunning build. Having built the Ju 88 ( I owe you guys some pics of it) I also well recommend ICM. I’ve never built a helo of any sort and this may just push me….. 2 1
BlrwestSiR Posted April 18, 2022 Author Posted April 18, 2022 Thanks guys! This kit is going together quite nicely and smoothly too. Phil, I'd definitely recommend it if you've never built a help before. 1
BlrwestSiR Posted April 18, 2022 Author Posted April 18, 2022 So looking at the weapons loadout chart in the kit, they suggest a podded M134 minigun on the inboard station opposite the M35 Vulcan. There's a pair of them in the kit but the details are a bit simple. I didn't want to go overboard but decided to add a couple details. I drilled out the circular vents on either side. For the minigun, I used a Live Resin M134 I had in the spares box. I mocked up a simple drive assembly, painted it and glued it in place. I then glued the halves together and gave it a coat of paint. You can just make out the barrel inside through both the vents and the front opening. So a quick improvement. Metallic Details make a nice 3D printed set that have a removable front cover that shows the full minigun underneath. I'll probably use that on my Special Hobby kit when the time comes. 4
BlrwestSiR Posted April 18, 2022 Author Posted April 18, 2022 (edited) Next up was many of the small details on the airframe- lift rings, antennae etc. I also painted the landing skids. Finally I started finishing the fuselage by adding the stub wings, the M35 fuselage pods and hung the M134 gun pod. I think I'm close to the home stretch now. Edited April 18, 2022 by BlrwestSiR Fix typo 7
DocRob Posted April 19, 2022 Posted April 19, 2022 Wow Carl, the Cobra is coming together fast and very nice. The detail on the Minigun was a bit on the weak side, so your tweak enrichens the appearance. It's always good to have a kit with a flat bottom to sit on, I can tell you while working on a wooden ship with delicate underwater shape . Cheers Rob 4 1
BlrwestSiR Posted April 20, 2022 Author Posted April 20, 2022 Thanks guys! Almost there. Putting on the decals, and final details. 6
DocRob Posted April 20, 2022 Posted April 20, 2022 Very nice and fast build, Carl, makes me almost want to start mine . Cheers Rob 1 1
BlrwestSiR Posted April 21, 2022 Author Posted April 21, 2022 Rob, the canopy is the only fussy bit. Take your time and it goes together just fine. I got the last pair of rocket pods finished. With those mounted, time to call this one finished. I'm happy I picked the kit up and even more glad I got the Special Hobby release in the stash for later on. 5
KevinM Posted May 1, 2022 Posted May 1, 2022 Noticed but have never mentioned it but ICM does some nice glass. 1 1
