JohnB Posted September 26, 2022 Posted September 26, 2022 I managed to remove all the goo that was left on the clear parts when I removed the Scotch tape. I re-masked with Tamiya masking tape, painted with GSB and applied some Pledge with Future. Far from perfect but a lot better now I think. Now I can continue the build. 9 1
Peterpools Posted September 26, 2022 Posted September 26, 2022 John A-OK - looks mighty good and glad the panther is back on the bench and underway again 3
JohnB Posted September 27, 2022 Author Posted September 27, 2022 Hey Scott, Did your kit have these very significant gaps, etc? Far from being a snug fit. It'll take a lot of filling and sanding to make things look right. 2 1 1
JohnB Posted September 27, 2022 Author Posted September 27, 2022 3 minutes ago, Irishman1 said: Wow!! Those are some gap’s Are they ever!! I don't look forward to trying to get those sorted out. 🤪 3
ScottsGT Posted September 27, 2022 Posted September 27, 2022 The Cougar fuselage sits down into the wing, so no real gap issues there. Now the speed brakes, yes. I did build mine open but I still had to add some styrene strip to square it up. The worst was the inner landing gear doors. They are only open during gear cycling, so I built them closed. Not only was it out of square but doors didn’t sit flush. Maybe my doors were warped over time, not sure. Here’s a pic of the wing to fuse fit you can see the tiny bit of filler that was needed FWIW, my flaps were warped pretty bad too. 3 1
JohnB Posted September 27, 2022 Author Posted September 27, 2022 2 minutes ago, ScottsGT said: The Cougar fuselage sits down into the wing, so no real gap issues there. Now the speed brakes, yes. I did build mine open but I still had to add some styrene strip to square it up. The worst was the inner landing gear doors. They are only open during gear cycling, so I built them closed. Not only was it out of square but doors didn’t sit flush. Maybe my doors were warped over time, not sure. Here’s a pic of the wing to fuse fit you can see the tiny bit of filler that was needed FWIW, my flaps were warped pretty bad too. I guess it's to be expected with this type of kit but it sure is a PITA to deal with. 3
ScottsGT Posted September 27, 2022 Posted September 27, 2022 Yea, I think it’s why it took me 4 months of building to get it done. Several times I asked myself why was it on my bench. But I was damned and determined it would not wind up on the SOD. 5
Peterpools Posted September 27, 2022 Posted September 27, 2022 John When I built my Sea Fury, I has the same gap issues at the wing/fuselage seams and huge gapes to fill. The cowling also had fit issues but not as bad. Paul sent me a few replacements for both and the best fit still had their share of gaps. My guess is this type of solid resin kit has a lot more shrinkage then a more conventional style. of injected molded. 3 1
JohnB Posted September 27, 2022 Author Posted September 27, 2022 1 hour ago, Peterpools said: John When I built my Sea Fury, I has the same gap issues at the wing/fuselage seams and huge gapes to fill. The cowling also had fit issues but not as bad. Paul sent me a few replacements for both and the best fit still had their share of gaps. My guess is this type of solid resin kit has a lot more shrinkage then a more conventional style. of injected molded. I don't recall having any significant gaps, etc when I built my Sea Fury. Certainly nothing like the one's for this Panther. 3
Peterpools Posted September 27, 2022 Posted September 27, 2022 John I see the gaps and they are certainly large. I'm thinking epoxy is the way to go. Fingers crossed 3
HubertB Posted September 27, 2022 Posted September 27, 2022 FWIW, most PU resins have a standard 3% shrinkage spec. Finding a resin with less than that is really hard work. But what’s worse is that the shrinkage factor is not constant and reproduceable … So factoring shrinkage in is a dark art rather than a mathematical formula … Hubert 3 2
JohnB Posted September 27, 2022 Author Posted September 27, 2022 1 hour ago, Peterpools said: John I see the gaps and they are certainly large. I'm thinking epoxy is the way to go. Fingers crossed I probably will go the epoxy route Peter as I doubt CA would have enough holding power. I'll continue with the build for now but it may end up back on the SOD if it's too big of a PITA. 🤪 1 2
Martinnfb Posted September 27, 2022 Posted September 27, 2022 You can do it John, with your skillset it's a breeze . 2
HubertB Posted September 27, 2022 Posted September 27, 2022 I’d use plastic shims. And yes, epoxy glue is the way to go … Hubert. 4
JohnB Posted September 27, 2022 Author Posted September 27, 2022 31 minutes ago, Martinnfb said: You can do it John, with your skillset it's a breeze . I appreciate your confidence in me Martin but I'm just not sure I want to deal with it right now. 3
Martinnfb Posted September 27, 2022 Posted September 27, 2022 Fully understood, sometimes things like that can kill the excitement completely. Well, time for another , more pleasant build, perhaps Corsair ? 3
JohnB Posted September 27, 2022 Author Posted September 27, 2022 2 hours ago, harv said: Well it would keep you busy ....harv 😁 True Harv but not really in the way I'd prefer. 🤪 1
JohnB Posted September 27, 2022 Author Posted September 27, 2022 2 hours ago, Martinnfb said: Fully understood, sometimes things like that can kill the excitement completely. Well, time for another , more pleasant build, perhaps Corsair ? I'm not bailing out on it just yet but, if and when I do, it's doubtful another Corsair would be up next since I just finished 2 of them. 2 1
JohnB Posted September 28, 2022 Author Posted September 28, 2022 Status as of now. Wings attached using CA gel and epoxy resin. Dealing with those seams will likely be a large PITA. 4
Martinnfb Posted September 28, 2022 Posted September 28, 2022 If I may suggest to put Tamiya epoxy/resin putty into the gaps and rub it in there with a wet finger. It sends down smoothly and blends to resin perfectly. 5 1
